Old 10-19-2013, 09:53 AM   #1
photoman327
photoman327's Avatar
Default Mig or tig or what
Getting ready to weld a vband flange to the hot side and need to know what others are doing for the best result. Got a small miller but might get this done by a pro.
Old 10-19-2013, 09:58 AM   #2
thelostartof
unbalanced chemical
thelostartof's Avatar
While a tig is ideal using a mig will work just fine. Make sure you clean the metal really clean and preheat it
Old 10-19-2013, 10:20 AM   #3
2fast242gt
Do you have a cobalt?
i wouldn't bother preheating a v-band, there's no benefit of preheating something so thin. Not really any benefit to Tig in this application besides appearance, though Mig can have a very nice appearance as well. It alll depends on who ever welds its skill.
1983 242dl
*6.0 lq4 swaped* Build thread
Old 10-19-2013, 10:25 AM   #4
atrokz
super cage design genius
atrokz's Avatar
Might mean preheating the thicker flange prior to welding it onto the tube. Two very different thickness.
Acetone, rag, stainless wire brush for cleaning.
'06 BMW E91 3.0 DD
91 945 SE - Modded the turbobrick way
98 BMW E36 2.8 - Wife's car
92 245 DL WAS NOT TO BE -RETURNED FOR ZERO SPACE
91 745T RIP
94 850 NA RIP
95 850R GONE
Rob Ford was Canadas greatest president
atrokz is offline   Reply With Quote
Old 10-19-2013, 10:30 AM   #5
thelostartof
unbalanced chemical
I guess I should of said preheat the housing you are welding onto, For sure not the V-band, it will heat up in a few seconds once you start welding it.
Old 10-19-2013, 10:59 AM   #6
photoman327
Thanks, I understood the housing. I use to have skills but it's has been a few years since I welded and never cast. Thanks
Old 10-19-2013, 11:11 AM   #7
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
Flange that vband to its other half or itll warp like the enterprise...
Old 10-19-2013, 01:37 PM   #8
daemon2
May your hammer be mighty
daemon2's Avatar
the purpose of pre heating is important for stainless. Stainless cools faster than other metals, when the materials around the weld in the HAZ cool too quickly it traps stress and causes hardened areas in the metal. These stressed/hardened areas will crack - especially on a header that is supporting any weight like the weight of a turbo.
pre heat helps but you may want to consider post heat if working with stainless. The slowed cooling will help prevent hardening and loss of ductility in the metal.
PS I love my TIG but the learning curve is steep. Very good results can be achieved with MIG.
I post heated mine and suspend the weight of the turbo on independent supports.
You may also want to purge the tube with Argon while you weld.
B8534T2
daemon2 is offline   Reply With Quote
Old 10-19-2013, 01:46 PM   #9
mafoose
Boost Addict
mafoose's Avatar
I'm pretty sure I remember learning in school that stainless holds heat LONGER then other metals, which is why you have to be careful of overheating it.
Honestly, it's GENERALLY better to MIG cast steel, and braise cast iron. This is because you get much better penetration with MIG than with TIG. Which ever way you do it, it's best to heat up the heavier part first, in this case, the exhaust side, so that you don't melt the v-band away and not get any penetration into the housing.
Plus, cast parts outgas like crazy when heated, and could contaminate and weaken the weld.
- 84 242 - 92 740 - 72 240z - 78 280z -
mafoose is offline   Reply With Quote
Old 10-19-2013, 01:48 PM   #10
Lord_Athlon
Sf1k Kryptonite
Lord_Athlon's Avatar
My vband to cossie housing was tigged by jesse, and its held up fine. +1 on the warping warning though
Originally Posted by rvolvor
Old 10-19-2013, 02:08 PM   #11
daemon2
daemon2's Avatar
stainless conducts heat at half the rate of mild steel but has a higher rate of thermal expansion. cools faster, cools slower, whatever.
Old 10-20-2013, 05:17 AM   #12
2fast242gt
If your dead set on tigging it use a nickel or stainless rod, nickel perferably. And toss it in some sand for a slow cool after
Old 10-20-2013, 10:53 AM   #13
nathaninwa
The Beloved Oarnge Juice
nathaninwa's Avatar
Ive done them before. Like Brian said, preheat the housing, I use 309L, or 309Lmo filler material and toss in a 5 gallon bucket with cat litter, sand, and the last time I used wood pellets for heating your house.
962j 815/692@27psi
THIS IS FORSALE V
Old 04-13-2017, 08:26 PM   #14
soclosenotnear
Hey all,
I found this thread while searching and figured I could bump it instead of starting a new one since I'm looking for the same thing. I'm trying to have a 2.5" v band welded to my flat flange td04hl housing. A buddy of mine who I thought would be able to do it is not comfortable, thinking the v band will warp. I realize I could drive across town and hope someone could do it, but I'm not in a hurry. I'm actually hoping someone on here who has done this before could help me out if I ship them some parts??
Thanks,
Joe
Old 04-13-2017, 08:39 PM   #15
thelostartof
unbalanced chemical
My self I have personally mig welded 3 of them and had zero issues, make sure the metal is clean and preheat it. Then again I have sent 3 f them out to be tig'd by a friend. The one I am going to run on my car is going to be a tig one.
Old 04-13-2017, 08:51 PM   #16
soclosenotnear
I am no welder personally and have no idea where locally that could do it. Wanna send mine to your friend along with yours??
Old 04-13-2017, 09:21 PM   #17
gsellstr
gsellstr's Avatar
That one on the Holset housing you did for me Mike turned out great. Ran for a couple years on my car, sold to another member, ran for a few years on his car as well. That was mig'd.
RIP
74 144 B20
90 745Ti
Old 04-13-2017, 10:44 PM   #18
EivlEvo
Just go to a welder or an exhaust shop. It's probably cheaper than shipping it all anyway.
Old 04-14-2017, 08:07 AM   #19
soclosenotnear
Cheaper is not always better. Someone that has done this before would be nice.
Old 04-14-2017, 10:37 AM   #20
EivlEvo
Yes. A welder has done this before. Go to a welder versus sending it to someone who can weld.
Going to a welder isn't the cheap option, it's the cheaper option. You'll get better results.
If you want to hit a home run, you go find Barry Bonds*, not little Jimmy from down the street who's had 3 at bats and homered all 3 of them.
Go to a welder.
Old 04-24-2017, 07:44 PM   #21
Boris740
Broad Member
Boris740's Avatar
Got knock? Got Megasquirt? Check out Knocksense knock indicator and KnocksenseMS indicating Megasquirt interface.http://www.viatrack.ca/
Boris740 is offline   Reply With Quote
Old 04-24-2017, 07:54 PM   #22
Powder>Paint
im dying... Best. Word. Usage. Evar.
Powder>Paint is offline   Reply With Quote
Old 04-24-2017, 08:46 PM   #23
ICantDrift
ICantDrift's Avatar
TIG everything
Sam
ICantDrift is offline   Reply With Quote
