Old 02-15-2016, 11:06 AM   #51
linuxman51
BRANDSCHUTZVORSCHRIFTEN!
linuxman51's Avatar
it's all relative. more is better ;)
Megasquirt Tuning!
Old 02-28-2016, 09:13 PM   #52
linuxman51
linuxman51's Avatar
10.5@131. slip in a bit. no spray.
in car video https://youtu.be/N8NCd9gK2zw
sam video:
https://youtu.be/M8bLnb0Lk48
Old 02-29-2016, 02:08 AM   #53
qwkswede
faster than you think
Dang Kenny! That thing is leaving really good without nitrous. Looks like you have it making boost on the line now. Good stuff. What are you doing with the trans on the start line? Dropped it to first right at the launch... do you have a t-brake in that TH350?
----------------edit--------------
I added your new times. Take your place on the top step of the podium again.
-Ken
1967 Volvo 122S
1992 Volvo 244 driver
Old 02-29-2016, 02:19 AM   #54
Pro Sneaker Peddler
We need Nate Kahler to step in and make us west coasters look less like a buncha chumps already.
Old 02-29-2016, 08:18 AM   #55
linuxman51
linuxman51's Avatar
no brake, just a slight of hand trick with the th400 and it's manual valve body. I actually got it to footbrake up to 30psi and 6000 rpms when I forgot to re-enable the launch limiter. I also forgot to drop it down into 1st initially on one pass, that was a bit awkward too.
Old 02-29-2016, 10:50 AM   #56
qwkswede
OH, that was he magic 2-1-2 shift. LOL. I forgot you went to a th400 now. Those transmissions are weird in a 4 cylinder. I always felt like I could have used a bit lower first gear ratio. Or 4.10s in the rear maybe. And a looser converter. I could never get mine to spool without a little nitrous. But no doubt they are tough as hell. Probably not even sweating making 10 second passes. :-)
Old 02-29-2016, 11:05 AM   #57
linuxman51
linuxman51's Avatar
I'm going 3-1. It cruised through the traps at around 6900rpms on the 131 and 132mph passes, so with the 100 shot I'll be right back up against limiter even though the tires are taller than the last set of stickies. There's a trick with 4L80's that does the same thing, only electronically, so I thought I'd gamble and see if the 400 liked it. Seems to. It's probably going to cut down on service life, but so be it I suppose. It's actually very smooth, not violent at all (And only possible because of the manual valve body ;) ). I could probably pull it into shape with traction control and spray, but launching with the naws is going to be.... interesting..
Old 02-29-2016, 12:59 PM   #58
qwkswede
Wow, I never realized you could do that....
So you are staging and foot braking in 3rd, because you can with a manual valve body. That lets you make more boost without putting so much torque to the tires and pushing through the lights, or spinning the rears... The lights go green and you slam it into first? Interesting trick. Seems like timing will be tricky if you ever need to cut a good light. But it certainly launches nice that way.
My valve body wasn't full manual, so I was always in 1st gear no matter where I had the shift lever.
Old 02-29-2016, 01:31 PM   #59
linuxman51
linuxman51's Avatar
yeah it's not the most consistent thing, so I wouldn't do that well bracket racing, but it's not that bad if you don't start thinking about a bunch of stuff at the same time. I was trying to turn off the fans, watch the boost gauge, and sorta cut a light on the run I forgot to pull it down on. I achieved none of the three either hahaha.
Old 03-01-2016, 08:11 AM   #60
Rich Halsey
Rich Halsey's Avatar
[QUOTE=linuxman51;5348973]10.5@131. slip in a bit. no spray.
Awesome runs!!! Team east to the front
Rich Halsey is offline   Reply With Quote
Old 03-02-2016, 05:24 PM   #61
linuxman51
linuxman51's Avatar
thanks bud! you needa get yours back together and out there, gotta beat that LS-T time of 11.66 ;)
Old 03-02-2016, 07:28 PM   #62
haltechsupra
haltechsupra's Avatar
Bad a$$ Kenny.. You are an inspiration to take my heap down the track, maybe bring things closer together...
https://www.facebook.com/kris.d.weld...5285796936005/
If you had the audacity , to doubt my veracity, and even to insinuate, that I scrupulously prevaricate ,such an insignificant question. Then you must hallucinate before you comprehend.
haltechsupra is offline   Reply With Quote
Old 03-03-2016, 09:19 AM   #63
Rich Halsey
Im working on it. Engine and trans are in, Im fabbing a new hotside and making a few changes to the old set up. Hope to have it on the dyno in the next month or so. Might pm you soon with a few a/c hookup questions.
Old 03-08-2016, 05:55 PM   #64
PNW940Pwnage
You guys are so fooking fast, it's like...what's the point of submitting high 13's anymore. LOL. Geez!
PNW940Pwnage is offline   Reply With Quote
Old 03-08-2016, 06:41 PM   #65
UhAudoe
Sittin' sideways
UhAudoe's Avatar
Right! It's almost like theyre running some high tech big displacement engine, that if you sneeze into it, will make big power
Sometimes good enough is better.
Slow p.o.s. et13.51 @ 105mph - 13c, lh2.4
UhAudoe is offline   Reply With Quote
Old 03-08-2016, 07:11 PM   #66
wennstroma
Of what, the "other" category?
Originally Posted by First post View Post
Summary
The "east vs. west" shootout was created by Pat D. (tuff240) to help motivate the group by creating a friendly yet competitive event we could all participate from our home towns.......
wennstroma is offline   Reply With Quote
Old 03-08-2016, 07:46 PM   #67
UhAudoe
Sittin' sideways
UhAudoe's Avatar
Yessss, yes, mmmmm. Commence pissy lil Turbobricks mode.
Old 03-08-2016, 07:57 PM   #68
wennstroma
Are you okay?
Old 03-09-2016, 10:20 AM   #69
linuxman51
linuxman51's Avatar
enough participation balances things out, that's why. If 4 people submit times, then yes, the side that's got an outlier will probably run away with it, but if say, 20 or 30 (or more) people participate then a bevy of 15 second passes will drown out a couple fast cars.
Hm. a 2.5 liter volvo motor isn't what I'd call big displacement. a pushrod 5L v8 ain't exactly high tech, however if you choose to go ford over chevy you should be satisfied with underachieving.
Check it again baws, runnin' it in two categories.
wat
Are you okay?
clearly he's not.
Old 03-09-2016, 10:39 PM   #70
UhAudoe
Sittin' sideways
UhAudoe's Avatar
clearly he's not.
I was speaking about the turbo LS's.
Not dogging them.
The Volvo powered car is cool.
And I'm okay more days than not.
Old 03-10-2016, 03:51 PM   #71
linuxman51
linuxman51's Avatar
Not dogging them.
no dogging was assumed, I also expanded on that side of the game as well.
Old 03-10-2016, 11:15 PM   #72
240Pete
I'm totally going to get involved in this, just have to get the 83 GLT +I back into service. It's been too many years since I've made a pass down a legit drag strip. Hold me to it. It will be sometime this year, 16's or bust! LOL
240Pete is offline   Reply With Quote
Old 03-26-2016, 01:53 AM   #73
linuxman51
linuxman51's Avatar
well, let the east down tonight.
only managed a 10.29@133.4
can't spray it, don't have enough injector :( still managed to cut a 1.5 60' tho.
Old 03-26-2016, 05:11 PM   #74
linuxman51
linuxman51's Avatar
new PB, but no change in points
Old 03-26-2016, 06:04 PM   #75
soclosenotnear
That's nuts. Gonna hit 9's soon, eh?
soclosenotnear is online now   Reply With Quote
