Old 08-17-2016, 02:18 PM   #201
740atl
educator monkey
740atl's Avatar
Originally Posted by dragbrick780 View Post
Catch alot of crap on here but here my slip from my recent track night. Im right lane . Now how do i get my 300 + badge .
Nice!
Can you get that 60' down a bit?
Old 08-17-2016, 02:24 PM   #202
gsellstr
gsellstr's Avatar
Definitely some tuning to be had. With the 341 or 351 on mine I was in the 2.3-2.4 60' range but 105 up top. Garrett dropped down to 2.0 but only 101 up top. I could only get 3-4psi at launch on the stall with the holset, but the dang Garrett I gotta pedal to keep from lighting the tires at the line.
RIP
74 144 B20
90 745Ti
Old 08-17-2016, 02:49 PM   #203
740atl
educator monkey
740atl's Avatar
I had the same issue regardless of turbo with the stock aw71... 60's in the 2.2-2.3 range. Brake boosting and launch control eventually got me to like 7psi and the 60' down to 2.0sec with the stock converter but it takes a second or two to build the boost.
Old 08-17-2016, 04:54 PM   #204
dragbrick780
dragbrick780's Avatar
my build is high cr with no cuts in the pistons and thinner mls gasket
dragbrick780
dragbrick780 is offline   Reply With Quote
Old 08-17-2016, 04:54 PM   #205
dragbrick780
no valve collision nether.
Old 08-17-2016, 06:02 PM   #206
dragbrick780
but we all know one tooth off and goes bye bye .
Old 10-12-2016, 06:19 PM   #207
cwdodson88
Dang, looks like last weekend was the last weekend PIR will be running Friday Nights. Rain in the forecast for the next 2 weekends, and well, most likely rain the next.
The Build Thread
SVEA - PUSHROD TURBO!
Old 10-13-2016, 12:03 AM   #208
gsellstr
gsellstr's Avatar
Looks like I'm not getting out to the track again this year either. Still gotta do the head swap and MS swap.
Old 10-13-2016, 02:19 AM   #209
qwkswede
faster than you think
Our season is finishing up this week too. There is a test n tune all day Saturday. Then its all done for the winter. I did make it out for few passes last week. But I ran my 16V car to 13.85@105. Chevy's don't count, so I won't post it.
I don't think I'll be making it out for racing in the Volvo this year. :(
Some warm weather cities have racing year round. So keep posting up numbers if you can get em.
-Ken
1967 Volvo 122S
1992 Volvo 244 driver
Old 10-31-2016, 08:41 PM   #210
linuxman51
BRANDSCHUTZVORSCHRIFTEN!
linuxman51's Avatar
Originally Posted by Rich Halsey View Post
All this being done in the new shop?
maybe. bought a dyno, so that's hosed up some play money too.
Megasquirt Tuning!
Old 10-31-2016, 11:49 PM   #211
wennstroma
I'm going to try and go and improve my time this Sunday. I've leaned it out on the top end to get rid of the bad misfires. Also runs better after fixing some voltage drops in the ems supply.
I've got a switch to use for launch control. Just need to rig up a bracket this week and wire it up. Should help my horrible short times, or blow up the clutch.
wennstroma is offline   Reply With Quote
Old 11-06-2016, 07:02 PM   #212
wennstroma
Improved my time a little bit. Car 4032 in the left lane.
Ran it at 15 psi. Since it was below 14.0, I got warned to have a helmet and fire jacket next time.
I got the launch control clutch switch mounted and wired, It builds ~6 psi in 1-2 seconds with the limit set at 2500 rpm. On the datalogs, because the engagement point is pretty high, the rpm goes up to about 4000 before the clutch grabs if I sidestep the clutch pedal. More than half the launches I did today just lit up the tires to where I had to lift clear off the gas to get traction back. I haven't been doing burnouts because I have radial 225/40-18 tires, and I didn't think it would help much with those.
Old 11-07-2016, 12:14 AM   #213
gsellstr
gsellstr's Avatar
She's hurt, oil pressure is down. Not sure if it's simply the transfer tube seal or bearings again. Tube seal, engine stays in the car, bearings, engine comes out, time to source another block and build it up from the ground again.
Old 11-07-2016, 03:04 AM   #214
qwkswede
That launch control trick sounds fun. Maybe you need to play with the traction control too?? Or just launch it easy. It's tricky on radials. Nice pass!
Old 11-13-2016, 12:31 PM   #215
J_Jones
J_Jones's Avatar
East Coast - Hybrid
1991 240 with a 2jzge/R154 swap. Stock engine besides headstuds and modified intake. Holset HX35w at 13psi, ebay header, 03 cobra 39lb injectors, LS coils. Rebuilt R154 with all the fancy upgrades and the damn thing still doesn't like being rushed and when it does go into gear there is nothing smooth about it... Explorer 8.8 with 3.73 gears and carbon fiber clutches. And the Achilles heel of the day: Cooper RS3-A all seasons out back that spun in first, second, and sometimes third no matter how much I tried to baby it. Fun day though.
13.28 @ 108 was the best I could manage out of it.
Old 11-14-2016, 01:26 AM   #216
qwkswede
Damn! Cool car. I'll get your numbers posted....
Old 11-22-2016, 01:06 AM   #217
240Psycho
still trying
240Psycho's Avatar
My submission for east coast 2016.
My 1991 Volvo 240.
2.5L
H beam Rods,
Wiseco Pistons,
MS3x
IPD Turbo Cam,
SS Turbo Header with 60/63 garrett
A Failing M47
A bad tune, driven by a bad driver.
..::VFBG::..
Kyle with a
'91 244 2.5L 16V turbo
00 S70 T5
81 242 T
79 242 GT
240Psycho is offline   Reply With Quote
Old 11-22-2016, 01:08 AM   #218
gsellstr
gsellstr's Avatar
Wow, that's REALLY bad! I don't think my wagon ever went that slow in the 60', even with the Holset. Definitely time to find about another 150hp out of that build...
Old 11-22-2016, 01:14 AM   #219
240Psycho
still trying
240Psycho's Avatar
I literally put it together the night before. lol I got finished at 3am, woke up 6 hours later and drove 2 hours to a car show/drag race and made 4 passes. no tune, low boost and a rev limit of 5800 cause I forgot to adjust it in TS. Only way to go is up.
Oh, I forgot I need a Witness, I met about a dozen other Volvo guys out there, just need to have one chime in.
Old 11-22-2016, 01:38 AM   #220
linuxman51
linuxman51's Avatar
I may have to take this 242 down to the track and get a pass for it's owner
Old 11-22-2016, 09:41 AM   #221
gsellstr
gsellstr's Avatar
Ahh, so it's more of a Roadkill kinda story. lol
At least you ran...better than 95% of the crew around here.
Old 11-22-2016, 09:42 AM   #222
RoadRacer4Life
Owner: DeathWagon
RoadRacer4Life's Avatar
I'll make it to the track before the end of the year I promise.
90 245GL Build thread 2JZ coming soon...
91 245GL Dumpin Doughnuts Battle Wagon Chumpcar
93 245GL Street Beater
Old 11-22-2016, 02:03 PM   #223
qwkswede
Thats good enough. And overall a good turnout this year! I wish there was a track still open around here. My DD 240 runs great now that the weather has cooled off. I'll get your data added to the list for the EAST!
Thanks for playing.
Old 11-23-2016, 12:04 AM   #224
240Psycho
still trying
240Psycho's Avatar
Thanks for playing.
Thanks!
Old 12-20-2016, 11:07 AM   #225
linuxman51
linuxman51's Avatar
well we're done here in 'bama til after new years, got rained out sunday
