Old 07-21-2016, 05:27 AM   #1
KEITHS2000
Default Penta crankshaft
So following on from the distributor thread
I liberated the block from the boat yard as I understand it , it may or may not have a forged crankshaft
How do I tell? Any markings to look out for
KEITHS2000 is offline   Reply With Quote
Old 07-21-2016, 06:33 AM   #2
DET17
Reformed SAABaholic
All cast cranks have a narrow "parting line" from when the casting is poured into the form. The forged version has a much wider parting area with more of a smeared look to it, due to the mechanical forging process.
A good used forged crank will ring like a bell when tapped with a hammer..... if a dull sound results, it's cracked.
Old 07-21-2016, 10:11 AM   #3
linuxman51
BRANDSCHUTZVORSCHRIFTEN!
linuxman51's Avatar
was the boat powered with a 2.3 or 2.5?
Megasquirt Tuning!
Old 07-21-2016, 10:11 AM   #4
Stiggy Pop
Stiggy Pop's Avatar
afaik all of the 2.5 (aq151/171/250/251 etc) cranks are forged.
'79 242
943 pickup
Old 07-21-2016, 10:48 AM   #5
GTJordan
Been here for too long
GTJordan's Avatar
My 2.5 crank is forged- it has a large casting line and it does ring like a bell.
80 242- 2.5L, T5, Porsche brakes, short billies and kaplenkhe suspension, trutrack.
Old 07-21-2016, 02:50 PM   #6
sbabbs
sbabbs's Avatar
Yeah the boat redblocks have a tag riveted on the motor right by the starter. Look at that and post what the tag says here and we'll be able to tell you what it's got.
1990 745 B230FT Getrag JohnV flywheel 240mm clutch 13c A-cam 3.54 G80 544K MILES
Old 07-21-2016, 03:16 PM   #7
KEITHS2000
Ok I will have a look tomorrow
cheers for replies guys
Volvos are all new to me
Old 07-21-2016, 10:21 PM   #8
4x4_Welder
Protip- If the crank is still firmly enclosed in the block, you can tell what it is with a drill. Pop the crank bolt out, and use a 1/8" drill bit on the end of the crank. Not deep, just enough to see the swarf. If it comes out as a curly-q, then it's forged. If it's a bunch of little chips, then it's cast.
Signature delete option-
4x4_Welder is offline   Reply With Quote
Old 07-21-2016, 10:31 PM   #9
John V, outside agitator
pull the pan.
look for this
Another:
But as usual you ask info but don't supply background info so that we can really help you.
What's your plans?
Why Penta?
How much for the block and crank?
Going to build a 400+ hp motor?
Forged is nice. Its real nice if you get it cheap.
What year block you currently have?
Do you know there's 2 versions of B230 fambly?
Sleezattle WA, USA
--> CALL (206) 431-9696<----
www.rallyrace.net/jvab
www.rallyanarchy.com
Vive le Prole-le-ralliat
— Don Marquis
Old 07-22-2016, 01:56 AM   #10
KEITHS2000
Plans are to fit a Volvo b230 in a Honda s2000 whith a chip tune and mbc
Why ? Because I already had the Volvo and the Honda was dirt cheap and already has track suspension and brakes
I also have a b90 gbox
As for the penta it was laying around the boatyard I use ready for scrap and I needed a distributor and drive to convert mine
As for plans with the penta block etc i will put it in storage for a while until Honda is finished
Then decide what to do maybe build a better motor
Old 07-22-2016, 07:31 AM   #11
240240
I crush everything!
240240's Avatar
Srsly you are adding like what 150-200# of extra weight in a place in the car where you don't want to add unnecessary weight to a nimble car.
Sell the crank and put an awesome Honda engine back into the car. Forget you even thought this thought
I know what I have, and you can buy it here
Old 07-22-2016, 08:44 AM   #12
KEITHS2000
The Honda didn't have an engine when I aquired it
Horrible buzzy things anyway
Interesting collection of pictures you have
Do you have any exact weight figures of a b230 and m90 gbox
If not don't guess I'm just after the facts
Old 07-22-2016, 09:13 AM   #13
240240
I crush everything!
240240's Avatar
Just because you can doesn't mean you should. Sell that crank to someone that knows what to do with it and buy anything else. A redblock is maxed out at 350haichpees and gonna be finicky at best. After dumping thousands of dollars of go fast parts at it.
This is a downgrade.
Wait until the tuners chime in.
Old 07-22-2016, 11:54 AM   #14
JohnMc
JohnMc's Avatar
This sounds like a reverso swap story.
Like when someone (Leno?) stuffed an SHO Taurus engine into a Fiesta. That was neat, but then what would happen if you stuffed the Fiesta motor into the Taurus?
'63 PV Rat Rod
'93 245 16VT Classic #1141
Old 07-22-2016, 12:08 PM   #15
240240
I crush everything!
240240's Avatar
Youd get really good gas mileage going 55 on flat terrain.
Old 07-22-2016, 12:30 PM   #16
Terrorize that pu$$y
Further derailment as the op is trollin or deranged, I got 33.74mpg's in my Matrix on Tuesday on a 300 mile trip, doing between 75-80mph most of the way, I hit almost no traffic on I64-I95 from Virginia Beach to Harrisburg PA. I only got 29.8 on the return trip due to traffic.
Old 07-22-2016, 12:35 PM   #17
240240
I crush everything!
240240's Avatar
It's hot.m p g is always great in the summer. When I gave the m47 240 to my now wife in the summer in Utah she was getting 27mpg on mountain terrain (which is pretty awesome) , then winter came and it dropped to below 20mpg on the same route in the snow. 2.4 doesn't like the cold
Old 07-22-2016, 12:38 PM   #18
JohnMc
JohnMc's Avatar
I've always thought a TDi swap (RWD'ed via an adapter and a Toyota truck trans) would be awesome in my PV. As much or more HP as the motor currently (with some tweaks) and ridiculous MPG.
This concept has only strengthened after buying a 2003 TDI Jetta wagon and driving it over the last couple of months. 5 spd manual, so it's still somewhat engaging to drive, 40 mpg in the city, upper 40's on road trips, it's certainly not fast but it's not achingly slow either.
Old 07-22-2016, 01:14 PM   #19
240240
I crush everything!
240240's Avatar
Put that b16 in the Jetta!!
Old 07-22-2016, 02:58 PM   #20
KEITHS2000
So I take it the red block is a **** engine that can't be tuned by adding more boost
Old 07-22-2016, 03:01 PM   #21
So I take it the red block is a crap engine that can't be tuned by adding more boost
I think they missed the boost part even though you did mention MBC in your post.
Old 07-22-2016, 03:02 PM   #22
JohnMc
JohnMc's Avatar
It's a tractor motor that we nonetheless sometimes enjoy overpolishing into explosive little bursts of fun.
How much HP are you looking for?
Toss an Ellis in it, similar amounts of work, but ridiculously over the top end results, instead of likely meh-ness.
Old 07-22-2016, 03:08 PM   #23
KEITHS2000
The point of the conversion is
Honda was dirt cheap and I mean dirt cheap if I break it I will treble my money
The volvo engine I already have
The engine is in and mounted using volvo mounts just got to wire it up and away I go
Just the props shaft and gear stick to sort
Looking into the weight it's not a lot heavier than the Honda lump
And with a bucket load more torque
As for fuel economy I couldn't give a rats arse otherwise I would have bought a Prius
As I understand it a Honda s2000 has 240hp with **** all torque
Volvo with have almost double the torque at half the rpm
The chick with a dick comment that made me laugh
But you all sound like a bunch of bitching school girls
Old 07-22-2016, 03:15 PM   #24
cwdodson88
Power to weight, cost to power... Honduh bruh.
The Build Thread
SVEA - PUSHROD TURBO!
Old 07-22-2016, 03:16 PM   #25
210
As for chick with a dick that made me laugh
See what i said earlier about not telling us enough?
NOW you say its it.. OK... Its in...done deal..
Now, whatchoo asking about the Penta crank if the Volvo lump's already in?
Tell us more. Like if you're in OZ or in Pommieland cause again it makes a difference..Different junk is easier to find in some places than the other.
Are you planning on building a reliable engine?
