Old 11-26-2016, 03:44 PM   #1
brickcupra
Default 240 / 7mgte swap
Hi guys, I here doing this again after my wife disconnected the computer and erased all the info I had typed. I am new to the bricks. I am a a Toyota fan, but I always wanted a Volvo wagon since I saw one back in the 80's. Finally I got one in a great deal with the exterior( red) color I wanted and the black upholstery I wanted. I got it back in September and I've been working on it on spare time after work. I have already pulled the engine and trans out of it. I had to put the cressy to sleep due to the fact it rusted beyond my budget and parts are practically impossible to get. One day after work I glanced at a 240 and the LED lit, Why not a 7mgte -240 combo? the engine only has 9k, yes 9,000 only since I rebuilt it.
Also I am changing the lug pattern for 5-114 to fit some 17 inch Maxima wheels.
I was blessed to find a supra in the local junk yard. The cressy hump is a front one and does not fit. The supra is mid hump and easier to make it work in the 240 chassis.
brickcupra is offline   Reply With Quote
Old 11-27-2016, 12:32 AM   #2
Steve Zissou
Steve Zissou's Avatar
Do it. Post lots of pics. I'm a closeted Toyota fan and straight sixes are my favorite swaps in the 240. Plenty of rear sump 1JZ's floating around for cheap also.
I don't think I've ever personally seen an M engine swap, but plenty of threads on JZ series.
Steve Zissou is offline   Reply With Quote
Old 11-27-2016, 01:15 AM   #3
BillyMaysHere
BillyMaysHere's Avatar
get to reading:
Old info and discussion about the swap
http://forums.turbobricks.com/archiv.../t-108633.html
diff detween 2j and 7m
http://www.driftworks.com/forum/tech...s-2jz-gte.html
2j swapped 240 volvo (with detailed pics and info)
http://www.turbobricks.org/forums/sh...ighlight=supra
sweet 2jz swap in a 740, but great build and all around info
You having the hubs redrilled? or getting adaptors?
Old 11-27-2016, 02:33 AM   #4
brickcupra
Default 7mgte 240
[QUOTE=BillyMaysHere;5510473]get to reading:
Hi bill.im redrilling them myself.I used the rotor of a 2002 infinity and the center hole fits iperfect to make the pattern .Im using Chevy trailblazer studs complements of the local junk yard. I got one done already.
Old 11-27-2016, 11:05 PM   #5
brickcupra
Question 240 7mgte,
How do I post my pictures here?
any tips would be greatly appreciated
DZ
Old 11-27-2016, 11:18 PM   #6
BillyMaysHere
Copy the image adress
Then paste it after clicking this box
Old 11-27-2016, 11:50 PM   #7
Wilford Brimley
LOCAL ONLY
Wilford Brimley's Avatar
Bryce Farted
'91 744t...it's fast as phuck
Old 11-29-2016, 12:23 AM   #8
brickcupra
thanks will do tomorrow, today i began cutting the oil pan for clearance
Hasta la vista!!!
DZ
Old 12-01-2016, 12:12 AM   #11
BillyMaysHere
you did half the steps, gotta click the little mountain box and paste each of the addresses in one by one
Old 12-01-2016, 02:21 AM   #12
Steve Zissou
Originally Posted by brickcupra View Post
hi, ok hopefully these pictures can be seen now. Thanks Bill!!!
Old 12-01-2016, 02:24 AM   #13
Steve Zissou
oil pan being cut and oil pick extended
Old 12-02-2016, 08:30 AM   #14
brickcupra
Hi , thanks for the help. I also work as a welder and I come home exhausted!!!
Still on the works as you guys can see
enjoy the weekend !!!
DZ
Old 12-08-2016, 08:12 PM   #15
brickcupra
Hi guys ,Finally I got the pan welded, scraped and painted including sealing the pin holes with solder for a waterproof tight seal.
Here are some pictures. ( it is taking longer than usual due to being tired after work and hardly acces to the shop with no remote. I have to depend on the painter to be at the shop because he is rebuilding a studebaker. https://s20.postimg.org/ppvhv2wv1/20161204_120503.jpg
https://s20.postimg.org/4u97ju0nx/20161204_120512.jpg
https://s20.postimg.org/ip7i2av31/20161206_220513.jpg
https://s20.postimg.org/e4lbndbdp/20161207_162548.jpg
ok hope you guys enjoy the pictures
Dz
Old 12-13-2016, 07:57 PM   #16
brickcupra
Hi guys , I got the engine and trans in already, although is a mock, because I have to pull it out again to put in the clutch.
Now I encountered a problem.The brake booster interferes with the intake manifold. I need to cut down the lower support to clear the hood, still I need to figure something out with the booster, Any ideas you guys can come up with?
thanks
Dz
Here are some pictures of the engine in the bay.
https://s20.postimg.org/ypt9073dp/20161212_180056.jpg
https://s20.postimg.org/xc67imti5/20161212_180125.jpg
https://s20.postimg.org/br14v0wrh/20161212_180106.jpg
enjoy, the cold weather is killing the time to do some things
Stay warm
Dz
Old 12-13-2016, 09:35 PM   #17
Terrorize that pu$$y
You can buy the skinny booster reman from advance auto.
Old 12-14-2016, 12:48 PM   #18
mbolton1990
mbolton1990's Avatar
Heck ya!
Nice progress,good luck with the build.
I love the sound of a 7mgte,can only imagine one in a 240 best of both worlds really.
'93 245 Classic #902/1600
'85 190D 5-Speed
mbolton1990 is offline   Reply With Quote
Old 12-14-2016, 07:57 PM   #19
brickcupra
Thanks guys for the tip and support !!!!
Happy holidays !!!!
Old 12-14-2016, 08:14 PM   #20
BillyMaysHere
thanks
Dz
Stay warm
Dz
Old 12-14-2016, 08:15 PM   #21
BillyMaysHere
http://turbobricks.com/forums/showthread.php?t=201749
Old 12-14-2016, 08:22 PM   #22
BillyMaysHere
Looks like the volvo part # is 53-5890 NOT 53-5990
Old 12-16-2016, 12:27 AM   #23
brickcupra
Wow !!!! thanks guys for the help.
I went today and removed the engine again to redo the oil pan. It does not clear the hood. I will have to recut and re weld again and add an extra bump towards the rear for more oil due to the fact that the 7mgte needs plenty of oil with the turbo and squirters and also I will possibly be cutting some of the center support as well as trimming the rack and pinion.I got some more metal scrap from work today for free to use it in the center support and the motor mounts. I gotta find out how much is the booster and if the one on the 740 fits. Another predicament is the heater core upper outlet. It is in the way o the egr valve. I might have to solder a 90 degree elbow and extend it either sideways or upwards. Gee it is a lot of work and my wife is not too happy. Again thanks a million guys or your support.
DZ
Old 12-22-2016, 03:18 PM   #24
brickcupra
hi just giving an update, Ive been sick as a dog. I went around the local junkyard and got some ideas in replacing the fat tank( break booster) assembly with some thing thinner.
Just wishing you all a safe christmas
DZ
Old 12-22-2016, 04:54 PM   #25
poulrais
poulrais's Avatar
DZ
I have a couple of 16V thin boosters if you ever need one.
1990, Volvo 740 16v +T
