Old 02-22-2017, 10:26 AM   #1
VeroDubs
The Big Swede
VeroDubs's Avatar
Default T5 Clutch or Trans Issue?
So as of late, I have been having some weird disengagement issues going on with my T5. Let me see if I can describe them well.
These issues usually happen after hard or long drives when the trans is hot.
-With the clutch depressed, on deceleration to a stop, with the car in 1st, 2nd, or 3rd gear; It feels as though there is enough of the clutch dragging to cause the back wheels to shutter like the clutch is engaged. This all is gone once the car comes to a stop.
-On deceleration, trying to downshift to 1st, 2nd, or 3rd, I will sometimes get grinds. These are intermittent and usually when I don't rev match perfectly. Sometime it does not need rev matched at all and down shifts fine.
-Randomly on up shifts I will get a grind. There is no rhyme or reason to this. Almost like I didn't compress the clutch enough, though it is fully depressed.
Thoughts and possible other useful info-
Flywheel: STS Machine LH2.4 60-2 Flat Flywheel
Clutch Disk: Southbend Ceramic 225mm T5 Splined Disk
Pressure Plate: SAAB Viggen 228mm PP
DeeWorks/Avalanche Kit
Ford TOB
I have adjust the cable both ways and driven it, does the same whether it is loose or tight or adjusted perfectly. Right now I have it a little over tight and there is no way it's not disengaging as much as possible.
I set the endplay in the trans when I did the swap. Is it possible to be set wrong (Too Tight) and would it cause issues like this?
I had to space my pressure plate with 1 machine washer on each pressure plate bolt in order to have the pressure plate release arms at the right height.
Any other info needed, just ask. I am looking for some insight on this.
My '89 Brick -"The Big Swede"
VeroDubs is offline   Reply With Quote
Old 02-22-2017, 11:53 AM   #2
GTJordan
Been here for too long
GTJordan's Avatar
Did you lubricate the splines on the transmission at all? Disk sticking to the splines? Was the input shaft worn in a pot that could be causing it to catch?
80 242- 2.5L, T5, Porsche brakes, short billies and kaplenkhe suspension, trutrack.
Old 02-22-2017, 12:17 PM   #3
VeroDubs
The Big Swede
VeroDubs's Avatar
I know we lubed the splines the first time, but I pulled the trans 2 or 3 times after that and can't remember if I did it again or not.
The T5 was fully rebuild and the input shaft was fine.
Old 02-22-2017, 03:06 PM   #4
Dan Stokes
Here's what I noticed on the one I'm doing the swap on:
The cable looked sort of OK but I decided to swap to a new one. When I had it out it was clear that it had been too close to the exhaust for too long (we're running shorty headers). When I reassembled the system I paid special attention to the cable routing and ended up wrapping the exhaust in DEI insulation - that's the ceramic tape that us hot rod folks use for this sort of thing. If you go to BangShift you can find my build thread and it'll show what I did. Directions to the thread in the thread I posted yesterday on here.
If I had to guess your cable has gotten toasty and the inner cable guide (sort of a Teflon sort of stuff) has melted to some degree and is preventing the cable from sliding smoothly inside the guide. Worth a look.
Dan
Dan Stokes is offline   Reply With Quote
Old 03-08-2017, 09:14 AM   #5
oldschoolvolvo
oldschoolvolvo's Avatar
Curious if you got this sorted out...
-Mike
1998 V70 T5
Old 03-08-2017, 09:44 AM   #6
VeroDubs
The Big Swede
VeroDubs's Avatar
Dan
I have not. I have been driving it daily and it's strange; some days I will not experience the dragging of the clutch at all. This morning though, it is wet and rainy out and pulling into a parking lot, I put it in first with the clutch completely disengaged and the the clutch chattered something fierce till I was down to about 3 mph, then it smoothed out and went away.
I have sitting on my bench at home a new clutch cable and STS clutch cable bushing to be installed this weekend.
Old 03-08-2017, 09:50 AM   #7
Simi
Upsetti Spaghetti
Simi's Avatar
Could be that the t5 is not disengaging all the way, depending on how heavy the clutch is, check for firewall flex, or have someone depress the clutch to see if the fork has the full amount of movement
Simi is offline   Reply With Quote
Old 03-08-2017, 01:50 PM   #8
culberro
culberro's Avatar
The Saab flywheel has a 1-2mm step, and the Ford disk is about 1mm thicker than the Saab disk. How thick is the spacer under the PP?
Diaphragm springs have less force when they get bent past a certain point. You may not have enough clamp load to prevent shudder.
Also, the ceramic disk will not like being "slipped" while down shifting or taking off. They are more on-off. If you slip them a lot, they "grab" and shudder.
Old 03-08-2017, 01:58 PM   #9
John V, outside agitator
Originally Posted by culberro View Post
The Saab flywheel has a 1-2mm step, and the aftermarket USA made Ford disk is about 1mm thicker than the Saab disk. How thick is the spacer under the PP?
da fuq?
I haint never seen no stinkin 1 OR 2 mm step on any real Saab 99 or 900 flywheel..How could the 900 T16v PP be direct interchange with the Volvo 215 B21T PP if there was a step?
Dems plat as a pankaka.
Sleezattle WA, USA
--> CALL (206) 431-9696<----
www.rallyrace.net/jvab
www.rallyanarchy.com
Vive le Prole-le-ralliat
— Don Marquis
Old 03-08-2017, 02:00 PM   #10
gsellstr
gsellstr's Avatar
This far and not a single mention of the pilot bearing being bound up? Come on guys...
RIP
74 144 B20
90 745Ti
Old 03-08-2017, 02:09 PM   #11
culberro
culberro's Avatar
da fuq?
Dufaq!? I don't know mang!!! From the pictures of new and used FW for a 2000 9-3 turbo, they all have a step?!
I'm trying to get the exact number from a Saab shop, but no one wants to play nice.
Looks a lot like a step to me... https://www.eeuroparts.com/Parts/286...-Mass-9179136/
http://www.ebay.com/itm/FLYWHEEL-FLE...3D152331636746
Old 03-08-2017, 02:15 PM   #12
culberro
culberro's Avatar
That'll definitely do it.
Old 03-08-2017, 02:53 PM   #13
B20Paul
Good point.
What about the opposite? What do you use for a pilot bearing in a T5 conversion?
B20Paul is offline   Reply With Quote
Old 03-08-2017, 03:01 PM   #14
gsellstr
gsellstr's Avatar
I used the standard Mustang pilot, been running fine so far.
Old 03-08-2017, 03:31 PM   #15
VeroDubs
The Big Swede
VeroDubs's Avatar
Wouldn't I get some kind of noise or vibration from a seized pilot bearing?
Originally Posted by B20Paul View Post
Good point.
I too am running the Avalanche Kit which utilizes the Ford T5 Pilot Bearing
da fuq?
I don't slip the clutch much at all. My engagement is pretty much on and off. As for my setup, I am not running a SAAB FW, it is an STS Machining Flat Flywheel. It is combing with a SouthBend Ford Splined Disk and a SAAB Viggen PP.
My PP is spaced with 1 washer to account for the extra thickness on the clutch disk so that the release arms sit flat with the PP face.
I will check for flex tonight. And as for the fork at the bell housing, I actually clearanced the bell housing to make sure the arm was not making contact and had room for full travel.
Old 03-08-2017, 06:56 PM   #16
gsellstr
gsellstr's Avatar
Usually you might have a little noise with the clutch in at idle, but I have seem them with nearly seized bearings and minimal discernible noise.
Put the car on stands, climb under, have a buddy press down on the clutch with the trans in 4th, see if you can easily spin the driveshaft. You should be able to see the outer edge of the disc as well, if you look thru by the shift fork, see if the plate is fully disengaging.
Old 03-08-2017, 07:04 PM   #17
VeroDubs
The Big Swede
VeroDubs's Avatar
Good idea. I am probably going to wind up staying at the shop and pulling everything apart one night this week. Doesn't take that long to take the T5 out haha
Old 03-09-2017, 03:04 AM   #18
culberro
culberro's Avatar
da fuq?
According to Mr.Medcroft, the flywheel step on a Saab 9-3 turbo is .073in.
The 215/228 PP is from a Saab 9-3 Viggen, not a 900.
I'll have some time to shim the PP tomorrow with an assortment of washers.
Old 03-09-2017, 07:42 AM   #19
freevolvos
Dial indicate the bellhousing to the crankshaft centerline and see is if it is centered if it's not it can cause all kinds of strange problems
Old 03-10-2017, 04:07 PM   #20
culberro
culberro's Avatar
As I can't seem to find the Saab PP and T5 thread, here's some info on the stock saab flywheel step height and clutch disk thickness.
Flywheel 9179136 has a raised outside shoulder where the pressure plate mounts, it is raised 1.55mm
The Sachs equivalent of 5174966 (1878005624) is 7.66mm thick compressed
Just measure whatever t5 disk you have for thickness (compressed), and then add the difference from the stock disk (7.66mm) and then add the flywheel step height of 1.55mm. Viola, instant spacer thickness needed.
Old 04-21-2017, 12:25 PM   #21
VeroDubs
The Big Swede
VeroDubs's Avatar
UPDATE ON THIS ISSUE:
I got the cable out and inspected it. I did not see anything that looked off or broken, but I replaced it anyway. When I did I noted the new one is a lot tighter when reconnecting the clutch arm.
I also bought STS Machining delrin bushing to replace the rubber one on the cable.
I have been driving a while now with it and have not had the dragging issues. Everything seems to have returned to normal.
So hats off to Dan Stokes... good call
Old 04-21-2017, 12:37 PM   #22
Pro Sneaker Peddler
Be very leery. The new plastic sheathing cables like to stretch.
Old 04-23-2017, 01:28 PM   #23
VeroDubs
The Big Swede
VeroDubs's Avatar
I will keep an eye on it and try and source a new OEM cable.
Old 04-23-2017, 04:41 PM   #24
Stiggy Pop
Stiggy Pop's Avatar
they're NLA. I have two of the good metal sheathed versions if you want to buy a used one.
'79 242
943 pickup
Old 04-25-2017, 11:31 AM   #25
VeroDubs
The Big Swede
VeroDubs's Avatar
Well, that's what I get for updating the thread. Got into a little spirited around town driving last night and then pulled into a parking lot coasting in 2nd and could feel the clutch dragging bad. It seams to only happen when I get the clutch hot.
