Old 03-29-2017, 02:51 PM   #1
Dannyt0186
Default newbie advice, 940 wagon build
hey t-brickers
i was looking around for a new daily/beater and came across what i now own (1991 turbo 940 wago). old girl is pushing 260k+ and she pistons slaps like the best of them but runs good...not great, but recently noticed a lil coolant mixing with my oil in the reservoir so i hunted for a cheap FT, but instead scored a complete 91 b230f with 90,000 miles. i plan on doing a mild "swedish special" cheap-o build and have already received my china-bay rods and rod bolts.
here are my plans
Intended uses: mild drifting, highway pulls and aggressive grocery getting
what i have:
-stage 0 complete maint and new water pump.
-m46 90% complete swap parts(yes yes i know T5 everything... can't afford it for now)
-chinabay rods
-tlao chips (need chip friendly ezk)
-FAST efi wideband(not fitted)
-3" downpipe(on the car)
-big core FMIC(not on)
-19t converted turbo with ARD billet wheel(on the car)
-Forge unos MBC (at 14psi currently)
-ebay manifold with flipped flange.(no fitted)
-holset hy35(dunno what to do with it)
-volvo 15G(don't know what to do with it)
-boost/water temp gauge
-front springs cut one coil
-metallic front race pads
-MS in the future
I've never messed with volvos !PERIOD, but have built a few other cars and know my way around boost, but am gonna come into this with full newb mentality so i can learn some things. i want to build a quick spooling trolling sleeper that will be fairly simple and inexpensive. I'm not too sure if 15+psi will be kosher on an NA b230 or not and from what I've read and understand, the typical "thicker headgasket= lower comp" trick doesn't work well with these engines.
any and all advice will be greatly appreciated....
what bearings are recommended??
what HG do i use??
thanks all
Dannyt0186 is offline   Reply With Quote
Old 03-29-2017, 10:14 PM   #2
Dannyt0186
No one..?
Old 03-29-2017, 11:11 PM   #3
okoye
okoye's Avatar
Where in CT are you? Check if it's the Trans cooler in the radiator that is leaking. And the head gasket job is easy I've done it a few times on a few motors.
Old 03-30-2017, 01:45 AM   #4
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
you only asked 2 questions which have been answered.. so.. what exactly do you want to know ? :D
Old 03-30-2017, 11:19 AM   #5
Dannyt0186
Okoye. I'm in Stamford, also noticed a little coolant pooling around the bottom edges of the head under the intake manifold. Maddog.......looking for advice/guidance from knowledgeable folks that have built these motors like the swedes have using budget friendly items. I know my build isn't going to be a balls to the walls build, but I would like to tickle 350whp. How extensive should I go with the bottom end and more importantly, is there anyway I can reduce the comp 1 pt or at least bring it to b230ft equivalent.
Thanks again guys and I'm confusing some of you folks, please excuse me
Old 03-30-2017, 12:28 PM   #6
okoye
okoye's Avatar
Check that the coolant temp sensors (2) are screwed in properly. Those can leak!
Old 03-31-2017, 01:27 PM   #7
Dannyt0186
i replaced it with stage0 because the temp gauge was dead. ill inspect again when i get home from work just to make sure all is well.
thanks for the advice.
Old 04-19-2017, 06:05 PM   #8
Dannyt0186
Just checked and it doesn't seem like it is the sensor, but oddly enough I ran it today for a bit and it's no longer happening....???
Old 04-19-2017, 06:48 PM   #9
eabras
Bolt on hy35, throw away m/t/whatever cam, take out the pistons and remove as much of them as you dare (lower compression), bolt it together and turn up the boost.
Or just leave the compression as is and run e85.
eabras is offline   Reply With Quote
