Old 04-09-2017, 07:32 PM   #1
TurboDenny
Why am I here?
Default Removing MAF wires from plug.
Currently in the middle of a +t on my '89 244, and I've come to the point of relocating the MAF. Does anyone know how to remove the wires from the plug itself. I'd rather not cut anything if I don't have to.
'90 245 Daily
Instagram: @itstotesdenny
TurboDenny is online now   Reply With Quote
Old 04-09-2017, 07:35 PM   #2
CAPT_BLOTTO
#Crush It
CAPT_BLOTTO's Avatar
They make special terminal tools for depinning and repinning connectors. You might have to find the right one that works for that connector.
Hello My Glorious!
Old 04-09-2017, 08:26 PM   #3
oldschoolvolvo
oldschoolvolvo's Avatar
^^ that is the best option, however...
you can also file down a paper clip or some other small pick-like instrument (so it is flat, not round) and carefully deflect the tab that holds the metal contact in the plastic housing.
-Mike
1998 V70 T5
oldschoolvolvo is online now   Reply With Quote
Old 04-10-2017, 11:16 AM   #4
dbarton
Bored Member
dbarton's Avatar
The later pins found in LH 2.4 plugs will be more difficult than earlier ones. Earlier ones have only one barb that needs to be pushed in and a simple sharp pick can easily work. Later pins like yours will have two barbs and you must depress both at the same time. It can be hard, but can be done with two sharp picks. The proper tool is shown below for the later type, but not cheap. Generally about $40.
Dave B.
'84 242ti, owned since 2003. Always garaged since brand new. Old-school round headlights because they look great. B21FT, EMS: SDS EFI and IGN, TD04HL-15G, T5Z trans, Cooling Mist water/ethanol injection.
April 2018: Volvo seeks Divorce from the Volvo Enthusiast Community: www.prancingmoose.com/#novolvo
Old 04-10-2017, 11:40 AM   #5
mopar318
mopar318's Avatar
I think you are making this too difficult. Either way you are going to have to splice extra wire in. Just use high quality crimp splices or solder and a good shrink tube. Offset your splices so they don't form a big clump.
Pimps out interiors.
1980 242 16 valve turbo
2007 V70R
mopar318 is offline   Reply With Quote
Old 04-10-2017, 01:50 PM   #6
Tfrasca
Tfrasca's Avatar
Originally Posted by mopar318 View Post
I think you are making this too difficult. Either way your going to have to splice extra wire in. Just use high quality crimp splices or solder and a good shrink tube. Offset your splices so they don't form a big clump.
You won't have to splice anything if you can pull the wires out all the way back to the firewall grommet. But I agree that splicing isn't a big deal.
Old 04-10-2017, 01:59 PM   #7
mopar318
mopar318's Avatar
And then how do you take car of the computer side of the harness? Seems like a lot of work for no reason.
Old 04-10-2017, 02:19 PM   #8
Tfrasca
Tfrasca's Avatar
You'd leave the ECU side all connected, and just pull the wires through the sheath, just up to the firewall grommet point. Then just run the wires on the passenger side of the engine bay to where your AMM will now be.
Really though, either way seems like about the same mount of work for a very similar result.
Old 04-10-2017, 02:35 PM   #9
mopar318
mopar318's Avatar
Yeah but you still need a splice if you do that.
Old 04-14-2017, 03:09 PM   #10
OttoB
No need, stock AMM wires are long enough for +T. I splice only sensor ground wire and connect it at intake manifold. Maybe not needed?
Small screwdriver works when removing pin.
Old 04-14-2017, 04:27 PM   #11
FezMonki
It's either splice or remove the pins, I don't think it's possible to move them otherwise. I opened two harnesses to avoid splicing, spent two hours playing with a ball of wires, but at the volvo factory they criss crossed some wires, they can't be separated properly. At least not in the two I inspected.
Looking for S90 fat armrest.
FezMonki is offline   Reply With Quote
Old 04-14-2017, 08:40 PM   #12
TurboDenny
Why am I here?
After realizing the ground wire has multiple splits throughout the harness I just decided to cut the plug off and pull them through. Splice into the ground wire at the firewall and solder the rest. Boom.
Old 04-14-2017, 08:45 PM   #13
FezMonki
This is the most painless option by far. Wish I had, instead of ending up in a labyrinth, and having to re-sleeve everything in the engine bay.
Old 04-14-2017, 09:52 PM   #14
TurboDenny
Why am I here?
definitely the easiest route.
Since I didn't quite make my goal of attending a car show this weekend, I will likely be making a new harness and adding a mil-spec connector at the firewall. Oh well.
Old 04-14-2017, 10:05 PM   #15
Tfrasca
Tfrasca's Avatar
Also what I did on my 140, only I just ran the ground from the AMM straight to the chassis ground by the passenger headlight.
Old 04-14-2017, 10:32 PM   #16
SLO240
Awesome Sauce
I have had fairly good luck with Bobby pins. Scrape off the plastic bulbs at the ends and bend both ends inwards so they look like tweezers. Gently push into the end of the plug and gentle pull on the wire, it usually comes right out.
1985 244 B230F Sister Killed It (RIP)
1982 242 B21FT Kid Hit It (RIP)
1993 245 B230F <--You can do it!
Buyer/seller feedback. http://forums.turbobricks.com/showth...67#post4602067
SLO240 is offline   Reply With Quote
