Old 04-16-2017, 10:58 AM   #1
Leeboy
Default 17x9.5 square set fitment issues
I bought a set of C4 35th anniversary wheels for a steal. I went with a set of 25mm adapters and they still dont fit without hitting the suspension. Is it recommended to add a spacer onto the adapter?
Fitment is 17x9.5 +56
Leeboy is offline   Reply With Quote
Old 04-16-2017, 11:27 AM   #2
okoye
okoye's Avatar
run as close to 0 offset as possible.
Old 04-16-2017, 11:32 AM   #3
daijoubanai
waste of skin and blood
daijoubanai's Avatar
Never stack spacers/adapters. Sell your adapters and buy larger ones. With 9.5 inch wide wheels, you're going to need like 50mm adapters to get the offset low like the poster above said.
Also you should list what car its for. I looked in your profile and it seems to be a 240 I assume.
daijoubanai is offline   Reply With Quote
Old 04-16-2017, 11:37 AM   #4
okoye
okoye's Avatar
I'll admit i've stacked adapters. But it's not something I'd recommend.
Old 04-16-2017, 12:43 PM   #5
wagonfan00
#tiltyplategang
Stacking adapters and spacers is sketchy but the cheap way out...I'm forced into it on my C4 better wheels and am not too proud of it but it works
Current: 1988 745Ti 248k (BC Coilovers, Kalphenke Adj. panhard bar, MBC @ 13psi, custom intake, Hydras) 2002 V70 NA M56 170k (M66 style singlemass flywheel and S60R clutch kit, a lotta poly, BC coilovers, Kaplhenke solid subframe mounts, R brakes and pegs)
Past: 2008 Mini Cooper S Clubman R55 (Stock) 1997 855 T5 300k
wagonfan00 is offline   Reply With Quote
Old 04-16-2017, 01:32 PM   #6
cosbySweater
cosbySweater's Avatar
Buy a c4, it's a better car and the wheels fit
Old 04-16-2017, 05:16 PM   #7
golddayton101
Anyone have any reommendations for where to buy adapters that large? The wheels are going on an 87 240.
golddayton101 is offline   Reply With Quote
Old 04-16-2017, 05:29 PM   #8
Mueller
Mueller's Avatar
1st learn how offset works and how to use a tape measure.
http://www.motorsport-tech.com
Old 04-16-2017, 05:45 PM   #9
Old 04-16-2017, 08:50 PM   #10
superboosted
You wish you had some..
superboosted's Avatar
With my 9.5's I had to dimple the strut housing a bit.
Photobucket can suck it.
Originally Posted by centason View Post
You may get detonation and the kool-aid man loves 940s
superboosted is offline   Reply With Quote
Old 04-16-2017, 09:36 PM   #11
TurboDenny
Why am I here?
I expect a similar post from you in every thread I open. It's why im on TB..
'90 245 Daily
Instagram: @itstotesdenny
