Old 04-17-2017, 09:14 AM   #1
Marvelous3
Who engineered this?
Marvelous3's Avatar
Default Tial BOV spring?
Riddle me this...
The Tial BOV I have on the red car came stock with a plain spring which says it is 11* for 18-20" vacuum. The red car pulls like 9-10" of vacuum at idle so this spring was way too stiff and causing compressor surge. I ordered a 7* spring for 8-13" vacuum yet was still getting compressor surge. I cut the 7* spring shorter and shorter trying to get it to work right but I was still getting surge. I eventually cut it so short that it was working but the BOV would remain open all of the time. I then added some shims to so that the BOV would stay closed while driving but the compressor surge is back. wtf.
If I boost it and let off vacuum will spike to 20" so there should be plenty of vacuum to pull the valve open. I do only have a smaller vac line running to the bov so maybe when I let off the vacuum is collapsing the hose? It's the only thing I can think of at this point.
Old 04-17-2017, 09:24 AM   #2
poulrais
poulrais's Avatar
Is your hose made of regular rubber or silicone? The silicone ones tend to collapse more under negative pressure.
1990, Volvo 740 16v +T
Old 04-17-2017, 09:30 AM   #3
Marvelous3
Marvelous3's Avatar
No, it's not silicone. We called it "red hose" but it's BMW rubber vacuum hose with a braided nylon casing.
https://www.ecstuning.com/b-genuine-...r/11657803732/
EDIT://
Looking again, tial recommends 1/4" line on the valve but the BMW hose is only 3.5mm. Might be something there?
Old 04-17-2017, 10:13 AM   #4
poulrais
poulrais's Avatar
EDIT://
Yep... You're almost 3mm short of 1/4"
Old 04-17-2017, 10:16 AM   #5
mopar318
mopar318's Avatar
I like 1/4" fuel hose for stuff like that.
Pimps out interiors.
1980 242 16 valve turbo
2007 V70R
mopar318 is offline   Reply With Quote
Old 04-17-2017, 03:44 PM   #6
Marvelous3
Marvelous3's Avatar
Aeroquip only makes socketless 4an hose in blue?
https://www.summitracing.com/parts/a...0410/overview/
Old 04-17-2017, 03:44 PM   #7
doucheNozzle
doucheNozzle's Avatar
Why do you only have 10" of vacuum at idle?
'99 V70 NAA - So Slow
'04 V70 T5A - Feels Fast
Old 04-17-2017, 03:58 PM   #8
Marvelous3
Marvelous3's Avatar
idk? In park it's 14-15" but in drive it's only 10".
Old 04-17-2017, 04:12 PM   #9
mopar318
mopar318's Avatar
Cams?
Old 04-17-2017, 04:18 PM   #10
Marvelous3
Marvelous3's Avatar
It does have penta cams ^_^
Old 04-17-2017, 05:21 PM   #11
poulrais
poulrais's Avatar
I'm pulling 18-19" at idle with ym 16V head and regular cams once the motor is hot... I just checked and my Tial BOV vacuum hose is 1/4" but it is rather long cause it's running from behind the right side headlamp over the intercooler and connects under Nathan's made intake so like a least 4 feet.
Old 04-17-2017, 06:59 PM   #12
gross polluter
They see me trollin'
gross polluter's Avatar
Where exactly are you sourcing the vacuum for the BOV?
Old 04-17-2017, 07:08 PM   #13
Marvelous3
Marvelous3's Avatar
My intake manifold only really has 2 ports for vacuum. One I have dedicated to the map sensor only. The other I have two plastic T's in that connect to the fpr, bov, boost gauge and stuff. I'll look at it when I get home. I can't remember what all is t'd into what.
Old 04-17-2017, 09:08 PM   #14
cosbySweater
cosbySweater's Avatar
I have a tial knock off, I have one big vac line going to a t on the driver's side of the head and from there it references the for,wastegate,boost gauge, and the bov with no issues. Are you sure the diaphragm is in good shape and nothing is causing the piston to hang up?
Old 04-17-2017, 10:37 PM   #15
Marvelous3
Marvelous3's Avatar
I have the map sensor on it's own line to the intake manifold.
The BOV is T'd into the FPR, and boost gauge.
I have the boost controler beteen the line that goes from the wastegate and the turbo.
All of these lines are 3.5mm but the BOV line is supposed to be 1/4".
Old 04-18-2017, 12:25 AM   #16
2fast242gt
Do you have a cobalt?
Mine has it's own vaccume source, and is 1/4" like. Works flawlessly. Even blows off at 2psi.
1983 242dl
*6.0 lq4 swaped* Build thread
Old 04-18-2017, 09:02 PM   #17
Marvelous3
Marvelous3's Avatar
Would it be a bad idea to t into the brake booster line instead? It's certainly big enough. I'm trying to avoid drilling a new port into the intake manifold.
Old 04-19-2017, 07:37 AM   #18
poulrais
poulrais's Avatar
Shouldn't the reference be pre-throttle plate?
Old 04-19-2017, 07:46 AM   #19
mopar318
mopar318's Avatar
I would out the correct size hose in a see if it fixes the problem. Tial has a large piston and needs a lot of volume to to fill that chamber.
Old 04-19-2017, 09:14 AM   #20
gross polluter
I really hope you're kidding.
Old 04-19-2017, 09:52 AM   #21
poulrais
poulrais's Avatar
My mistake. It's the wastegate's reference that has to be before the throttle plate.
My BOV is hooked after the throttle plate and my wastegate at the turbo outlet.
