Old 04-19-2017, 04:38 AM   #1
chevy_dude97
Default Wheel Spacers for 1989 745
Good day all,
I was fortunate to pull a set of perfect s40 rims yesterday for free.
Markings on them are as follows; Tire size(205/55R/16) Wheel size(6.5Jx16x52.5)
I know I have seen wheel spacers to fit the fwd rims on the rwd vehicles.
I have a 1989 740 GLE estate without any suspension modification. What size spacers would I need to allow the new tires/rims fit without much fab work? would the IPD 25mm spacers work?
1989 740GLE 8V 250K miles in Survivor mode
1951 Buick Super
1980 MG MBG GT Sebring
2001 Seat Alhambra 1.9TDI
chevy_dude97 is offline   Reply With Quote
Old 04-19-2017, 04:53 AM   #2
Surfingbird
Depends on the ET of the rims, you want to aim for an ET near original or lower. My 240 run ET 5 Front and ET 0 Rear
Surfingbird is offline   Reply With Quote
Old 04-19-2017, 05:10 AM   #3
jakemness
jakemness's Avatar
Yeah, the 25mm spacers work well. I know some people like to run 32mm on the back wheels though. It's all personal preference. There should be some pictures on the googlewebz of the different spacers and the appearance they give.
jakemness is offline   Reply With Quote
Old 04-19-2017, 05:41 AM   #4
chevy_dude97
Thanks guys!
Old 04-19-2017, 06:53 AM   #5
wagonfan00
#tiltyplategang
IPD has 25mm spacers that should get the ET right for you. Although do be careful....the s40 has a different hub bore than our redblocks
Current: 1988 745Ti 248k (BC Coilovers, Kalphenke Adj. panhard bar, MBC @ 13psi, custom intake, Hydras) 2002 V70 NA M56 170k (M66 style singlemass flywheel and S60R clutch kit, a lotta poly, BC coilovers, Kaplhenke solid subframe mounts, R brakes and pegs)
Past: 2008 Mini Cooper S Clubman R55 (Stock) 1997 855 T5 300k
wagonfan00 is offline   Reply With Quote
Old 04-19-2017, 07:13 AM   #6
chevy_dude97
Do you mean make sure its centered before bolting down? Is there perhaps a ring insert that fits on the market?
And yes, IPD is the site I was looking to purchase them from since they are having a sale currently.
Old 04-19-2017, 07:47 AM   #7
Triebwerk
Hier werden sie geholfen
http://www.schippan-shop.de/EXEC/6/2...BCF05892EBE440
regards Mathias
[Austria]
Triebwerk is offline   Reply With Quote
Old 04-19-2017, 10:12 AM   #8
https://www.kaplhenke.com/collection...-studs-spacers
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
Old 04-19-2017, 12:19 PM   #9
wagonfan00
#tiltyplategang
No the hub bore is different for the s40. It's smaller than the P2, P3, P80, and redblock cars. No idea why. also the 1st gen s40 has a 4 bolt pattern while the P1 s40 has the 5x108 but weird hub bore
Old 04-19-2017, 12:20 PM   #10
wagonfan00
#tiltyplategang
Originally Posted by blkaplan View Post
To completely thread jack.....I bought a set of used spacers for my 745 thats missing a stud.....any way i can get just one?
Old 04-19-2017, 12:28 PM   #11
lummert
lummert's Avatar
Do those S40 wheels have 5 holes for the studs? Early S40 were 4 lug. 4 x 114.3.
Old 04-19-2017, 01:53 PM   #12
yes, if they were one of mine.
Old 04-20-2017, 08:19 AM   #13
chevy_dude97
Wow thanks for all the replies, I think I will use some calipers to measure the hubs. Like I said I pulled it off of a car going into the scrap yard and believe it or not, even the winter tires where alloys. So just to be safe I think I should measure considering.
To answer the 4 or 5 lug question, yes sir! 5 lugs.
To be 100% I am not sure of the exact year/model but when I head back up to check out the rest of the yard I will mark it down.
Old 04-20-2017, 11:31 AM   #14
lummert
lummert's Avatar
He has ET listed as 52.5. My math says 52.5-25 spacer=27.5, 52.5-32 spacer=20.5. Stock alloy 15x6 wheel has 25mm ET and 4.5" back spacing.
Old 06-19-2017, 03:49 AM   #15
chevy_dude97
The 25mm spacers worked perfect, for some reason I had to almost "press fit" 2 of the rims on the hubs. Other than that the wheels went on as smooth as one could expect. Thanks for all the help guys!
Old 06-19-2017, 07:41 PM   #16
LC4CARL
Aero challenged
LC4CARL's Avatar
Pix, pix, pix!
Built-not-bought: PDXdl Resto-Mod.
#carlfeague on IG.
