Old 02-28-2011, 01:41 PM   #201
swedish-rocket
Originally Posted by Jeh View Post
No its not actually nesc, but nice to have. It will clear.
Thanks for the quick response!
swedish-rocket is offline   Reply With Quote
Old 02-28-2011, 09:49 PM   #202
Mueller
Mueller's Avatar
Originally Posted by BradC View Post
With what is going on in the LH2.4 tuning thread, do you _really_ need the Turbo LH and EZK or can you simply upgrade the software in the N/A versions with something read from the Turbo computers? Would be a cheaper upgrade for those of us that live in places where volvo wreckers are harder to come by.
Both options require you to have something mailed or shipped to you correct?
How you do you figure it would be cheaper to do the software upgrade? The emulator alone is $175
You should be able to find at the wreckers, ebay or classifieds a proper Turbo ECU and EZK for $100
You might save a few dollars with the shipping on the smaller emulator...
If you feel comfortable to do the software upgrade that is the reason to do it...to try and save a few dollars is just plain silly since the factory parts are known to work.
Old 03-09-2011, 09:35 PM   #203
swedish-rocket
How would the car perform if I was to install 577cc hi resistance injectors in place of the turbo volvo injectors if they fit? I may have a extra set off my srt4 if I decide to upgrade them.
Old 03-09-2011, 10:03 PM   #204
500dollar744ti
still rides with MrDoug
500dollar744ti's Avatar
probably about the same assuming you have lh2.4.
if you raise the boost results may be wonderful.
-Matt
1989 Volvo 744T- 16v turbo, '94 FD-block, RSI pistons/rods, GT35R, Tial 38mm, RFL, MSnS-E, DSM spark, 100lb Delphis, 4.6 springs, Bondo header, Heebspeed intake, Q45 90mm TB, Bosch 044 FP, 12x24x3 ebayIC, w/c t5, Clutchnet 4puck/PP, 4.10 G80, IPD sways, 960 brakes.
1998 Volvo S70 T5m- Stock, 229k
1998 Jeep Cherokee XJ- Stock, 154k
1983 Ford F150- '89 5.0 H.O, C6/4x4, F+R LSD 4.10, 7" lift, 35s.
1990 Cobia San Marino 225 ECS- MCM 350 Mag, GM Bowtie Intake, HR-Titan 19p.
500dollar744ti is offline   Reply With Quote
Old 03-28-2011, 08:29 AM   #205
Death{AW}
OK guy I have 89 740 Intercooled turbo wagon. My engine is on it last days. I found nice low milage 230f from 91 NA 740. What I will need to do other than drill the hole in pan or block when I swap engines?
Death{AW} is offline   Reply With Quote
Old 03-28-2011, 08:39 AM   #206
Death{AW}
Should I swap heads or leave them alone? Compression on NA is over 175 on all cylinders.
Old 03-28-2011, 12:21 PM   #207
sevedenv90
i think your going to have to swap out the head gasket to lower the compression...
sevedenv90 is offline   Reply With Quote
Old 03-28-2011, 01:45 PM   #208
Death{AW}
I have stock tdo5-12b turbo and I run stock boost. Do you guys think I will have to get different gasket? I guess I will just run it way it is. If it will blow I will replace gasket and head from my old engine
Old 03-29-2011, 12:03 AM   #209
leslie_s
thats....it.
i drive a 2008 Jeep Wrangler
Originally Posted by cancer man View Post
On May 21st 2011, the official majority language will be Hispanic in the great U.S.A. Adios Gringo.
leslie_s is offline   Reply With Quote
Old 04-22-2011, 02:43 PM   #210
swedish-rocket
Does anyone have pictures or know of a how to on the coolant lines to and from the turbo?
Old 10-26-2011, 05:06 AM   #211
turboCars
for some reason, its cool
turboCars is offline   Reply With Quote
Old 11-15-2011, 03:30 AM   #212
242GT-R
242GT-R's Avatar
is there a link or size for the oil sender thred size or for the T-?
79 242-GT+Hx35 and NX on LH2.2
04 S60R 314 Awhp
81 244 DD 2.1+2.3=Blueblock
242GT-R is offline   Reply With Quote
Old 11-16-2011, 04:18 AM   #213
242GT-R
242GT-R's Avatar
Please
Old 11-27-2011, 10:18 PM   #214
242GT-R
242GT-R's Avatar
LOL well for ppl wondering its a 1/4 and Im pretty close to being done, in the photo i was mocking up with a 15G but i now have a K24 instead, if anyone needs help im sure I can be more use now that im doing and almost done.
Old 11-28-2011, 01:42 AM   #215
TeamBuzzard
Well this thread has been helpful for the most part. Have a doner turbo car lined up. Minor problem I've run into. I have a 1992 245 M47 car. It has the LH 3.1... Tons of talk about the 2.2 and 2.4. Have followed all of the links in this thread and have seen no mention of the 3.1. I am a bit color blind so not sure of the injector top color. Same as the rest of the N/A cars? How compatable are the 2.4 and 3.1 harnesses? The air meter appears way different. really don't want to rewire car because of the before mentioned color thing. Extending wires is not that hard though. At least a nudge would be appreciated. Thanks in advance.
TeamBuzzard is offline   Reply With Quote
Old 11-28-2011, 08:56 PM   #216
mrmint359
mrmint359's Avatar
i have this engine in my 740 gl 1988
i want to put this 940 turbo into it
is all the wiring all there already??
i have everything from both cars just a little more fact gathering i want to be ready before starting!
mrmint359 is offline   Reply With Quote
Old 12-05-2011, 01:17 AM   #217
volvoboy90
sanna kärlek är svensk
volvoboy90's Avatar
Ok, here is something I haven't seen on here. I have a friend of a friend who says he can turbo my 89 240 for 750 - 1000 dollars... Naturally I haven't asked what all that includes yet, but he also said he can get it done in an afternoon. Does this sound generally reasonable from what all of you have seen and done? He said 750 to get it done cheaply, 1000 to get it done right... I assume the 1000 includes the ecu's, and such.. but not sure yet... anyways, I thought I would ask.
Originally Posted by TrickMick View Post
HEY...we're all in this "Volvo stuff" together here @ Camp TBrix...
keeping the "oldies but goodies rockin' down the road"...
*PICK YER POISON*...either put a raw egg under your gas pedal
and tip-toe around town - *OR* learn to live with the GREAT FUN of
sucking unsuspecting "other brand drivers" into the educational benefits
of NEVER underestimating a "grandpa car" again....hee, hee....
RIP TrickMick You'll be missed
volvoboy90 is offline   Reply With Quote
Old 12-07-2011, 04:33 PM   #218
Mueller
Mueller's Avatar
heck, it can be done for $250 or so..... if you buy a $250 donor car which is possible.
so , yes, it can be done, I'm guessing that is parts and labor?
Why not do it yourself and save some money?
Old 12-09-2011, 11:47 PM   #219
volvoboy90
volvoboy90's Avatar
The reason I wouldn't do it myself is because I do not have proper tools... or a garage... Winter can be cruel when working on the side of the road without proper tools, an such. He said he has the parts sitting around and can get it done in an afternoon.
Old 12-10-2011, 12:30 PM   #220
Mueller
Mueller's Avatar
I'd find out the differance between both options if actuallly have the money and are serious.
The $750 option better come with the correct turbo ECU, they only sell for $50 so that couldn't be reason for the price change.
Old 12-10-2011, 12:51 PM   #221
volvoboy90
volvoboy90's Avatar
Well I have to wait until tax return season rolls around, but it is close enough for me to try to get an idea if I will need any extra parts, or not...
Old 01-02-2012, 11:57 PM   #222
qbenplaya00
qbenplaya00's Avatar
def making swap... starting to collect all parts now. budget build!
Fern
Feedback
122(66), 142(71), 144(68), 145(74), 242(80)
died; '83 245, '89 240
sold; '91 240, '05 s60 2.5t awd
qbenplaya00 is offline   Reply With Quote
Old 01-21-2012, 08:30 PM   #223
Simi
Upsetti Spaghetti
Simi's Avatar
Going to get the engine swapped by a volvo specialty shop in the summer, can't wait for my B230FT.
Hopefully I can pay them to throw a M90 transmission in with it, I heard the M47/46 Can't hold more than 200hp
Simi is offline   Reply With Quote
Old 02-16-2012, 03:58 PM   #224
Mueller
Mueller's Avatar
good luck, not available in the US unless you have one sent here from Europe, expect to pay $1000 for parts and shipping (or more)
Old 02-17-2012, 02:26 PM   #225
hutchyy91
hutchyy91's Avatar
just a quick question. Does a aw70 work fine with a b230ft? I'm thinking that it would but I'm not positive.
hutchyy91 is offline   Reply With Quote
