I would like to run new wire from the crank position sensor to the ECU. My 91 240 3.1 has been giving me some problems, and would like to know if I could run regular automotive wire for the three connections vs. the shielded wire that is on there now. I'm not sure what problems it would cause, such as significant EMF noise from the engine causing it to run poorly- which maybe could be eliminated by braiding it in a ponytail.
I suspect the wiring because The CPS was bought about a year ago. I put some wire wrap around the cable to keep it from getting chewed up.
If this is a terrible idea, does anyone know of a store that sells this kind of wire?
Thanks as always!
Thanks as always!
