Old 09-14-2012, 03:50 PM   #426
740volvo
740volvo is offline   Reply With Quote
Old 09-14-2012, 09:00 PM   #427
Koston740
Rollin on reps
Koston740's Avatar
Originally Posted by gsellstr View Post
You're kinda SOL until you get enough fuel to feed the injectors, regardless of pressure. Lines won't be an issue for the time being, but the volume certainly will.
$100 for the Mustang pump drop-in upgrade.
is the stock mustang pump a walbro.
90 745 w/ b230ft- Holset He351cw, TLAO chips, eBay ic, Delphi 65's, bmw oil squirters, spec stage 2+ clutch, t5 WC E85
Feedback thread:
http://forums.turbobricks.com/showthread.php?t=236339
Koston740 is offline   Reply With Quote
Old 09-14-2012, 10:32 PM   #428
cosbySweater
cosbySweater's Avatar
just simply swapping pumps is not gonna fix anything, i tried and failed, swap pumps and upgrade the wiring to w bigger gauge to see real improvement
1995 Porsche 993
Old 09-14-2012, 11:10 PM   #429
740volvo
Old 09-14-2012, 11:22 PM   #430
cosbySweater
i run a single whinebro 255 with 10 gauge wiring and it has kept the fuel pressure right where it should be all the way to 30 psi.
Old 09-14-2012, 11:42 PM   #431
gsellstr
Vintage anti-ricer
gsellstr's Avatar
Eh?? Bumped up the wiring inside the tank, running the stock wiring for the rest of the car. Voltage at the sender connector is within .2v of battery voltage at high load, fuel pressure hasn't been an issue to 20psi on mine. Stock pump was 3-4a nominal, walbro is 8-10 max at full pressure which these cars will never see (hopefully).
As for Koston's question, depending on where you get the pump, may be a walbro. The Airtex E2366 (I believe, the specific number is around multiple threads, I just don't remember off-hand), is a Walbro, only downfall is it doesn't have a check valve in it like the stock pump. It's not an issue on LH2.4 or any system that primes, but 2.2 doesn't prime prior to cranking.
RIP
Nick Fengler "fengler" 8/6/18
74 144 B20
90 745Ti
Old 09-15-2012, 03:58 PM   #432
cosbySweater
stock wiring powering a relay switching to 10 gauge off the battery
Old 01-17-2013, 06:20 PM   #433
lookforjoe
lookforjoe's Avatar
Interesting read.
Trying to decipher out of the original posts just what I need to calibrate my fuel maps to for use of E85. What seems to be stated time again is a 42% increase in injector (size? flow?)
Running ME4.4, laptop programmable fuel, ign & WOT maps.
I can calibrate my main fuel map for any injector size, currently 650cc (@ 3 bar, approx 710cc @ the 3.8bar I'm running now), I can adjust regulated pressure.
Running 20psi (PTE6262) boost I'm hitting over 85% duty cycle on my setup, so I'll need larger injectors to run the same boost level?
Tuning should shoot for AFR .85? I'm tuning for AFR 12.5 with gasoline. I can calibrate a data gauge in Innovate for Ethanol - AEM gives a chart to scale from, but it just says Ethanol, doesn't specify E100, E85, etc... also I should switch the WB02 for Lambda display for more accurate tuning ?
When calibrating for idle/cruise, I'm shooting for 9.0:1 correct?
Any current tips or suggestions from those with experience?
My XR July2013 - 446AWHP @ 8K rpm
Old 03-30-2013, 06:08 PM   #434
pelicanflyt
pelicanflyt's Avatar
Have any of you longer-term E85 users experienced any adverse side effects? Has anyone changed to different oil or do more frequent changes with E85? Seems to be a recognized need (more OCs) when using it, from what I've read around the web.
1998 V70 T5m 18t, ARD Blue, turboback, SNAAB intake, currently 151k miles. Now running 50% E85.
2004 V70R 6m SOLD 9/29/08.
aka washdup
pelicanflyt is offline   Reply With Quote
Old 03-31-2013, 10:56 AM   #435
thelostartof
unbalanced chemical
thelostartof's Avatar
I am still doing 5k oil changes with 0-30 castrol oil with no major issues seen here. I have been running e85 since '09.
thelostartof is offline   Reply With Quote
Old 03-31-2013, 05:21 PM   #436
740tankDriver
Post-Hypnotic Sigma
740tankDriver's Avatar
i have been running nothing other than e85 alcohol for about three years. only thing observed as a negative is what was already observed is the carbon gum buildup on the valves and injector tips. running fuel system cleaner is a neccessity, from what i have observed. i run a bottle of redline fuel system cleaner every oil change. no problem.
the gum buildup is the only issue.
Happy Passover!
Great Victory!
740tankDriver is offline   Reply With Quote
Old 03-31-2013, 09:05 PM   #437
thelostartof
unbalanced chemical
Or you could just run some chevron 91/93oct fuel every 3-4 tanks add 1-2 gal of normal pump and that helps also.
Old 04-01-2013, 08:41 PM   #438
gsellstr
Vintage anti-ricer
gsellstr's Avatar
Same here, just the deposits on the valves, nothing on the injectors even. Been on E85 since may '12.
Old 04-13-2013, 05:40 PM   #439
740tankDriver
Post-Hypnotic Sigma
based on my morning cold-start condition, where the engine is difficult to fire, i was considering a dry nitrous induction setup for aiding cold-start engine start. nozzle install past the throttle body...perhaps at the cold-start valve location or egr port location. any dangers of unwanted ignition and /or explosive results?
Old 05-05-2013, 10:49 PM   #440
pelicanflyt
Did a before and after dyno and saw 25WHP gain (8WTQ) with just 30% E85 / 70% 91 octane petrol. Car runs fantastic with that blend. Any greater E85 proportion, though, and get a CEL for lean. Also, the intercooler weep hole seems more active (more discharge).
Old 05-06-2013, 12:33 AM   #441
gsellstr
Vintage anti-ricer
gsellstr's Avatar
Haven't had the deposits or CEL on mine, even running straight E85. I will say, TLAO's chip had a VERY nice 8-8.5 AFR from 3k-6500 in boost on the dyno while running the stuff, which is right where it should be in boost.
Orie tried a blend in both of his cars with nothing but pure win results, smoother, way more grunt, etc.
Hit the yards with the neighbor yesterday, he filled his Ranger up afterwards at Arco, 2 miles later it was running like crap, pinging, etc. even at cruise with the a/c on. Suggested he try tossing in a couple gallons when he gets a chance, see if it helps that tank run worth a darn, waiting to hear the results.
Old 03-13-2019, 11:12 AM   #442
twann74
Hi!
This post has not been used for a long time, but has anyone converted their NA 740 to run on e85? I have a b230e and want to do so by swapping injectors. Stock injectors are 203cc @2.5 bar (at least I think).
I'd like to find injectors that can be straight swapped. If I want to increase the size by 42 to 60%, the bigger injectors should be 288cc-324cc @2.5 bar. However I can't find anything smaller than greentops which are 337cc @3 bar.
I'm afraid it's too much and the car will run too rich. Does anyone have another bosch reference that would be straight swapped or simple to install?
I am already running e85 on my subaru impreza but I installed a flexfuel kit on it, and I want to do it the turbobrick way on the 740. Running e85 is an huge saving in France (0.5€/l compared to 1.5€/l for petrol).
Thanks!
twann74 is offline   Reply With Quote
Old 03-16-2019, 03:13 PM   #443
linuxman51
BRANDSCHUTZVORSCHRIFTEN!
linuxman51's Avatar
337cc at 3 bar is going to be a little bit smaller at 2.5 bar.
Megasquirt Tuning!
Old 03-17-2019, 04:58 PM   #444
OttoB
337cc @ 3,0 is 307cc@2,5 bar. So pretty close, but you need resistor pack with greentops.
Old 03-18-2019, 09:49 AM   #445
linuxman51
linuxman51's Avatar
not if you use 850 turbo injectors..
Old 03-20-2019, 05:31 PM   #446
MikeSr.
What, me worry?
MikeSr.'s Avatar
That’s what I have in the LS V8!
I coulda had a V8!
