Old 11-13-2017, 01:36 AM   #1
gsellstr
gsellstr's Avatar
Default PSA: T5 swap guys, driveline vibration fix!!
Been fighting this for ages, tried the usual engine angle, diff angle, 1pc, 2pc, compound angles, new yoke, new tailshaft bushing, fluid types, the whole lot, NEVER made any progress. Had a little of the same with the Celica box but not like the T5.
Fast forward to this weekend. Yard run yesterday, pulled a yoke from a 92 Grand Marquis with a V8. Same length yoke as the Mustang yoke, same OD, but with a balancer on it, and it still runs a 1310 joint. Installed onto my current 2pc driveshaft, went to install, minor issues. Had to pull the spacers I had shimming the trans up (from playing with angles), got enough clearance to slide the yoke in, not enough clearance to put the shims back, not a big deal in my case.
Took it out for a test drive. Accel is smoother than it's been, light cruise rattle is 80% gone, decel rattle rpm range dropped from anything over 2800 to only 2800-3800rpm, and the severity of the rattle dropped by 60-70%.
Don't get me wrong, this didn't fix ALL of the rattle, but I suspect if I went with a balancer the size of the one on the 4-cylinder Mustang's balancer it would potentially have fixed all of it, but for something about 1/4 the size it really made a huge difference.
One thing to be aware of while looking in the yards though...there are several different OD's on the yoke, also different spline counts. The Ford boxes run a 1.5" OD, 28 spline, but there's a variety of yokes in the yard.
RIP
74 144 B20
90 745Ti
Old 11-13-2017, 02:32 AM   #2
Tfrasca
Tfrasca's Avatar
This is relevant to my interests. What's stopping you from finding a 4 cylinder yoke/damper?
Old 11-13-2017, 03:06 AM   #3
Pro Sneaker Peddler
Oh hello
Old 11-13-2017, 01:55 PM   #4
towerymt
the real Towery
towerymt's Avatar
Which car?
Cut it off the driveshaft we put on the 240 lemons car. I didn't think it fit a 240. Probably still have that other slip yoke around...
Old 11-13-2017, 03:33 PM   #5
gsellstr
gsellstr's Avatar
4-cylinder I DID find at the yard was a different OD yoke so no chance of it sealing.
There may be something from a later 3.8 with the big balancer though. That said, I don't think I'd have the clearance for it in the tunnel since the balancer section is much longer and would extend into the tapered section of the tunnel. As it was with this one I had to drop the trans just a little to get the clearance needed, but I had the room to do so since it was already shimmed up when I was playing with angles.
Old 11-13-2017, 03:51 PM   #6
Tfrasca
Tfrasca's Avatar
I see. I'm thinking that since I have to hack the **** out of my tunnel anyway, I could make room for the biggest damper I can find. Good to know that it makes a difference.
Old 11-13-2017, 10:47 PM   #7
gsellstr
gsellstr's Avatar
Yeah, definitely could clearance it a bit.
You could go for something like this most likely...
http://www.drivetrainamerica.com/f6z...anger-mustang/
Old 11-14-2017, 12:41 AM   #8
Tfrasca
Tfrasca's Avatar
Yeah, I haven't decided whether or not I want to convert the T5 I have to a mid-shift yet. If I leave it in mustang format, I'll have to cut up the rear of the tunnel a lot anyway. Might be worth the considerable headache to make room for a nice damper. Also- they want a lot for a slip yoke with an extra donut on it!
Old 11-14-2017, 01:05 AM   #9
Cutting the tunnel is no problem with one of these 240 tunnel covers to make it look stock.
Old 11-14-2017, 01:07 AM   #10
Tfrasca
Tfrasca's Avatar
You always know just what to say. PM incoming.
Old 11-14-2017, 01:40 AM   #11
gsellstr
gsellstr's Avatar
Funny, he always knows what to get and where to get it as well. Lucky SOB. lol
FWIW, my 140 already has the 240 tunnel stock, so swapping to the big balancer would still require some 'massaging', just a good bit less than the early 140 tunnel I suspect.
Yeah, saw the price on those balancer yokes new...damn. Might be worth calling a driveline shop, see if they're any cheaper there or if they have a crossref to a spicer unit instead of spending coin for something marked Ford. I've found that a few times buying stuff in West Sac.
Old 11-14-2017, 01:43 AM   #12
Tfrasca
Tfrasca's Avatar
I thought that was the case with your car. Lucky. You didn't have to cut up your tunnel or modify the shifter hole at all, right?
Old 11-14-2017, 01:49 AM   #13
gsellstr
gsellstr's Avatar
Nope, nothing whatsoever.
Also, got word from yet another, the SN95 crossmember works nicely, even in a hippy car.
Old 11-14-2017, 02:11 AM   #14
Tfrasca
Tfrasca's Avatar
Like, a stock Mustang crossmember?
Old 11-14-2017, 11:25 AM   #15
gsellstr
gsellstr's Avatar
Yup. SN95 crossmember, grabbed mine from the same 95 I pulled the trans from. Requires a couple riv nuts into the frame to bolt it in, then you're done. I was able to use 1 existing bolt hole, 1 more rivnut on the driver side, 2 on the pass side since the stock one mounts vertically on that side. On a 240 you can use 2 of the 4 existing bolt holes.
Should be a pic in my build thread for the 140.
Old 11-14-2017, 11:47 AM   #16
Tfrasca
Tfrasca's Avatar
Oh nice. I just went and looked at those photos. Exhaust clearance looks really tight for my 3", but it might be worth a try.
Old 11-14-2017, 12:07 PM   #17
EivlEvo
If using the SN95 T5, the stock 240 cross member works fine as well. Just add an angle bracket and drill 4 holes.
Mine is SN95 and a 93 245 fyi
EivlEvo is online now   Reply With Quote
Old 11-21-2017, 11:23 PM   #18
Chuck W
Chuck W's Avatar
I know I have a couple of Fox DS in the garage from all of the various TBirds/Cougars/Faimonts/Capris I've had over the years. Wonder if any still have the dampers on them.
'80 264GLE - (B21FT-MS'ed/M46)
'97 854 T5 (Eventually to be 5spd)
'77 242DL (B21F/M45) - SOLD '75 245DL SOLD '85 244GLT DEAD
'83 Tbird Turbo (2.3T/T5/MegaSquirt)
My feedback thread
Chuck W is offline   Reply With Quote
Old 11-21-2017, 11:34 PM   #19
gsellstr
gsellstr's Avatar
Entirely possible. Just gotta watch out, the 4-cylinder shafts are a different yoke size than the V8's, at least from what I found at the yard.
Old 11-21-2017, 11:45 PM   #20
John V, outside agitator
You ever wonder how in the world those USDM Fords needed those dampers for driving 55mph yet the one Euro Ford using the T5 which stock out of the box went 150 mph didn't?
And that Euro Ford didn't have some cut up old semi-truck tire between the yoke and the propshaft either.
How did they do it?
Sleezattle WA, USA
--> CALL (206) 431-9696<----
www.rallyrace.net/jvab
www.rallyanarchy.com
Vive le Prole-le-ralliat
— Don Marquis
Old 11-22-2017, 12:01 AM   #21
Pro Sneaker Peddler
How did they do it?
Quit teasing and show me the goods
Old 11-22-2017, 12:15 AM   #22
just a yoke and a u-joint, 2 piece prop with some cheesy rubber center support bearing..
What's to show?
Old 11-22-2017, 11:03 AM   #23
gsellstr
gsellstr's Avatar
You pose a question but pose no answers John.
With correct angles, parts in good condition, and properly built (as confirmed by those that build on a daily basis, have done so since your days on a bike), what are we all doing wrong? You seem to have the magical answer you're not sharing, as implied by your post, so I HONESTLY would like to know what we're all doing wrong.
I'd also love to know why Ford deemed it necessary to include the damper if it's not needed. I'm sure their engineers were just trying to find a way to sell more parts, make more money, but they had to get it thru channels for a lot of years. Again, serious question.
Old 11-22-2017, 11:30 AM   #24
culberro
culberro's Avatar
What's to show?
Are you talking Escort or Sierra?
Old 11-22-2017, 01:20 PM   #25
Pro Sneaker Peddler
Certainly looks like they allow much less movement than the Volvo stuff...
