Old 11-14-2017, 07:51 AM   #1
tyrefryrevolvo
Post b23 build suggestions.
Allright guys , I have an 84' 242DL back in cali waiting for me with an m46 and it has 180k on the clock so barely broke in. From what i understand it is a b23 engine. I would like to build it from the ground up with a turbo and all the correct supporting mods to at least 400hp I would really appreciate some direction and some options and reccomendations from the the guys that have been working with these engines for years allready and know what exactly to look out for . When i get home from deployment i plan on diving right into it.
Don't nag me , your not my wife.
tyrefryrevolvo is offline   Reply With Quote
Old 11-14-2017, 09:45 AM   #2
Ilvmetal
Ilvmetal's Avatar
all you need to do is search search search...
then take out your wallet
1973 142 Turbo 8V build
1988 740 16V money pit
2004 V70R Wife's DD
2017 S60T5 Pole star ecu flash (still slow)
At any given time I have to many projects but not enough Volvos...
Ilvmetal is offline   Reply With Quote
Old 11-14-2017, 09:47 AM   #3
Ilvmetal
Ilvmetal's Avatar
and this might help;
http://forums.turbobricks.com/showthread.php?t=249553
Old 11-14-2017, 10:56 AM   #4
John V, outside agitator
When are you back?
Ho much you budgeting for?
Sleezattle WA, USA
--> CALL (206) 431-9696<----
www.rallyrace.net/jvab
www.rallyanarchy.com
Vive le Prole-le-ralliat
— Don Marquis
John V, outside agitator is online now   Reply With Quote
Old 11-14-2017, 04:06 PM   #5
eabras
What I did to get 352whp from a b21, just to show what can be done without spending a ****load of cash:
Stock 7,5:1 compression shortblock (b21et, same as us b21ft)
Stock 398 k-jet head, stock valves but stiffer springs
Stock v-camshaft timed straight up
stock k-jet intake manifold
stock 90+ manifold (flange opened up to t3 size)
stock headgasket
holset hy35cw
3" exhaust with a single muffler
siemens deka 63lb injectors mounted in k-jet holes in head
dw300 intank pump
dodge 4bar fpr
generic ebay ic
accel ultracoil, stock dizzy, some generic accel plugwires, bcr8es plugs
and a decent standalone ems.
30psi, 19.5 degrees of timing and 352whp on ron98. With a more suited cam, larger injectors and slightly smaller turbo (the holset hits 30psi by 3800-4000rpm) I bet the number would be even higher.
eabras is offline   Reply With Quote
Old 11-14-2017, 06:13 PM   #6
soclosenotnear
stock headgasket
holset hy35cw
dw300 intank pump
dodge 4bar fpr
generic ebay ic
30 psi
How many miles on something like that?
soclosenotnear is online now   Reply With Quote
Old 11-15-2017, 11:41 AM   #7
eabras
I guess that if the crank position sensor hadn't let go, it would still be running. Timing was suddenly way off, blew hg and bent the rods.
Old 11-22-2017, 07:43 AM   #8
tyrefryrevolvo
Thanks for the responses guys, And budget and time go hand in hand for me , but i would rather save the money and buy quality parts than to have to do something twice. but dont get me wrong im not afraid of the junkyard either. Im just not familiar with what parts are compatible with eachother and which years on the 240's , im talking big ticket items like cylinder heads and cams etc... but i would not put an ebay turbo on my car lol thats just me.
Old 11-22-2017, 10:08 AM   #9
photoman327
photoman327's Avatar
stock headgasket
holset hy35cw
dw300 intank pump
dodge 4bar fpr
generic ebay ic
Good number from a B21 and I was thinking of junking a couple.
Old 11-22-2017, 11:25 AM   #10
Mueller
Mueller's Avatar
How are you going to pass smog with a heavily modified car in California?
Old 11-22-2017, 11:45 AM   #11
BDKR
Section 9
BDKR's Avatar
That's what I was thinking but I decided it'd let it go.
For all you Dijkstra fanboys:
Old 11-22-2017, 11:49 AM   #12
You guys always do that, and then put those horrible B230Ft things in there.
Old 11-22-2017, 03:39 PM   #13
Iddnit weirder than fawk?
I can't understand where the hell the ideas form that there is anything wrong with the B21 or B23 but i swear I've has SOOOOOOOOOOOOOOOOOOOOOOOOOooooooooo many people say "Oh the B230 are MUCH better-er-er, eeeeeverybody says so"
Huh?
Old 11-22-2017, 04:35 PM   #14
culberro
culberro's Avatar
Huh?
Nothing wrong with a b21 or b23 motor.
The b230 is a more efficient design and they're easier to come by.
Old 11-22-2017, 05:36 PM   #15
eabras
Speaking of b230's, I'm replacing the b21 with a b230. 149mm rods and stock f-pistons
Old 11-22-2017, 06:18 PM   #16
Efficient? You mean lower drag? Stock to stock sure..But built to build its a meh.
And more truthiness yep easier to come by.
But no reason to go out of the way to find one or the other.
Build whatchoo got.
Old 11-22-2017, 06:36 PM   #17
culberro
culberro's Avatar
Build whatchoo got.
Exactly this.
