maxitoman007
- Feb 15, 2017
- Calgary, Alberta, Canada
So a couple days ago, after getting a big dump of snow here in Calgary AB, I decided it would be a good time to go out and practice "winter driving" and really try to learn what it feels like when the power is going to the back wheels. Long story short, I believe my turbo oil feed line was cracked but still attached before I even started the car (most of the oil leaked out just after starting the car) but I didn't know this at the time. I started the car drove to get some gas then went to a parking lot and "practiced" pretty hard. Eventually the engine just stopped. Tried cranking again but it cranked very slowly, then it suddenly cranked fine but wouldn't start. Looked under the hood and the turbo oil feed line was completely snapped off (uses a metal 90 degree elbow which I am now revising as to prevent it from breaking not a second time but a third time). I asked my buddy to crank the car and instantly I knew something was wrong, the crank and all accessory belts were turning but the cam and aux shaft were not. Eventually got the car towed back to my place and found that the aux shaft could still turn quite freely and that the timing belt had been stripped of teeth around the crank (hence why nothing else was spinning), I then assumed the cam had seized. Also discovered a huge puddle of oil underneath where the car was parked before i took it out, right under where the turbo oil feed would have been. probably from when the car was just starting up, confirming my theory unless somewhere else was leaking significantly.
So here's my interpretation. Started the car with cracked oil feed and before long, oil was gone. kept driving car then drove it hard and eventually the cam seized, stopping the engine. Tried to crank the engine but the cam wouldn't turn hence the slow crank. attempting to crank with seized cam ended up shearing the teeth off the belt on the crank. Hence why it cranked fine after.
I feel very stupid.
Here's what I've found so far on the subject:
I found one user who said that usually when a cam seizes in one of these cars, the first approach is simply to remove the burs from the cam bearings, reinstall cam, use "high detergent oil" (i believe he suggested diesel oil) for the first bit, and pray. He said most engines ran fine after this. I've also heard of somebody suggesting that to remove burs, one could install the cam with a small amount of fine valve lapping compound and turn the cam by hand both ways for a bit.
Here are questions I still have:
-If the cam seized first can I assume my (rebuilt literally 120 km ago (not thousand km just km)) lower end is still okay even after being run with little to no oil?
-Is the valve lapping compound technique a good idea?
-Is there a certain gap spec between the bearings and the cam that I could check?
-If the car runs okay after the DIY refurbishing, will the minor change in bearing size affect timing to any significant extent (I have an adjustable cam gear I can use to compensate for this).
- would it be a good idea or bad idea to upgrade my cam after this? Good because camshaft journals will be as big as possible to fix tolerance issues? Bad because of it being more aggressive?
Side notes:
- I would like to go 16 valve turbo in the future but cant nearly afford the parts yet so I'm hoping this fix will last long enough for me to be able to do the swap in the future.
Thanks, Max
I feel very stupid.
Side notes:
Thanks, Max
