Old 01-09-2015, 03:07 AM   #201
cosbySweater
cosbySweater's Avatar
You dont need to run a 2.4 cluster. To much wiring. Just run a 86-88 lh 2.2 cruise control cluster
1995 Porsche 993
2013 VW Passat TDI
Old 01-09-2015, 01:21 PM   #202
Duder
Comes with a free Frogurt
Duder's Avatar
Please expound on this. Does the 2.2 cruise cluster use a mechanical speedometer? Does it output a vehicle speed signal that LH2.4 can use?
I was under the impression that the 2.4 cluster didn't require major surgery to install, but correct me if I'm wrong.
Old 01-09-2015, 01:46 PM   #203
The Full Banana
not yet good enough
The Full Banana's Avatar
It doesn't require major surgery
-Tom 1980 242 T5
Old 01-09-2015, 01:50 PM   #204
cosbySweater
ou need to move some wire around and add some I believe, all you need to do with the lh 2.2 ic is run the wire for the impulse sender from the ecu to the spade connector on the back of the cluster near the speedometer. its a lot more simple in my opinion, then you don't have to worry about having a check engine light in the cluster as well
Old 01-09-2015, 02:05 PM   #205
Duder
Duder's Avatar
So the LH2.2 cruise speedo outputs a signal analogous to the tone-ring diff VSS signal that the LH2.4 ECU is looking for?
I do need to add a check engine light however; this car is going to be BAR-ref'd and smog legal after the swap.
Old 01-09-2015, 02:27 PM   #206
cosbySweater
well that's no fun!
Old 01-09-2015, 02:40 PM   #207
Duder
Duder's Avatar
Ok, I should clarify. It will be smog legal at first. Once the swap is certified I'm going to start taking liberties with it.
Old 01-09-2015, 03:24 PM   #208
Chewy
Chewy's Avatar
I feel your pain (Commie-fornia).
Progress is lookin good.
I'm ~a week ahead of ya. Just dumped my b230ft into my kjet 242...
I cant wait for the referee session.... /sarcasm.
Originally Posted by alreadyupsidedown View Post
Just think of K-jet as an extremely complicated mechanical Rube-Goldberg carburetor.
Originally Posted by volvo240skunk37 View Post
Good God son, you're just a pile of fail.
A-A-Ron
Going away: 69 142 "Inga" Build Thread
Had: 80 242 "Elsa" Build Thread
Chewy is offline   Reply With Quote
Old 01-09-2015, 03:33 PM   #209
Duder
Duder's Avatar
We should remain in communication. Good to know there's someone local who is doing the same thing at the same time. I'll be very curious to hear how much (or little) scrutiny you get by the BAR ref. I've heard of them being extreme dicks about every little detail like accessories, radiatior, fuel tank, etc. But something tells me an old beige Volvo won't raise eyebrows quite like an LS-swapped FD RX7 does, for example.
Old 01-09-2015, 04:41 PM   #210
Chewy
Chewy's Avatar
Will do. I've heard either A) it's pretty simple, and they just make sure the emissions features are right, OR, B) you want to gouge your eyeballs out with their thoroughness.
Also depends on which BAR referee you go to.
Old 01-09-2015, 06:07 PM   #211
cosbySweater
get a d24, swap it in, or change your title at your local aaa office. not that hard
Old 01-09-2015, 06:14 PM   #212
Duder
Duder's Avatar
Yep, actually already have a D24 still installed in a 245. I want this car to be legit though. There are a lot of things I can do with a B230FT that won't ever be noticed by a smog guy.
Old 01-09-2015, 10:27 PM   #213
cosbySweater
But smogggggggggggggggg
Old 01-10-2015, 12:31 AM   #214
Duder
Duder's Avatar
But I've heard that older diesel title swapped cars are subject to random testing. And I asked my AAA office if they do paperwork on diesel swaps and they said no. "Change of motive power" is what DMV calls it. Is your 244 a "diesel?"
Old 01-10-2015, 12:35 AM   #215
cosbySweater
My 244 and 242 are
Old 01-10-2015, 12:39 AM   #216
Yesssss. Getting a highly modified car to fly under the radar in California seems like such a fun challenge.
Old 01-10-2015, 12:45 AM   #217
cosbySweater
It really isnt. Ive never had a problem. Been driving modified volvos since 08 and never had a issue
Old 01-12-2015, 01:08 AM   #218
Duder
Duder's Avatar
I'll consider the diesel title a bit more before doing anything rash.
Below are some pics of my Recaro adapter brackets which attach my brown corduroy seats to stock 240 sliders. Today I finished welding the driver's side brackets and painted them. Started on the passenger side and got mostly done with one of them.
I had to cut windows in the sides for bolt access, and my cutoff wheel went outside the lines a bit in order to get deep enough. Welded the corners closed to remove stress risers.
My TIG skills are improving; the one I fully welded today looks far better than either of these.
Old 01-13-2015, 12:52 AM   #219
Duder
Duder's Avatar
Another seat bracket post. Super exciting.
Proof of better TIG welds on the 2nd set:
First set is now 100% done. Brown is the new beige.
Finally parked both 240s next to each other for a photo op. What a dashing duo.
Old 02-03-2015, 03:18 AM   #220
Duder
Duder's Avatar
Some updates of note.
I have the B230FT mostly stripped down to the long block now. Cleaning up components, starting with the intake manifold. Quaker formula solution in a heated high pressure parts washer works very nicely.
Before:
After:
Went on a junkyard run and scored a Denso 100A alternator, G80 + aluminum cover, wasted spark coil pack from a Ford Escort, and some ignition modules to drive the thing.
The Bosch 100A alternator weighs 17 lb as shown, Denso 12 lb. I'm happy to save 5 lb ahead of the front axle wherever I can.
Also recently obtained various high impedance injectors, 3" AMM for LH2.4, and some DeCarbon front strut inserts for experimentation purposes.
Every little bit is progress, and I've been chipping away at it every day.
Old 02-03-2015, 09:13 AM   #221
love the brown. looking good!
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
Old 02-03-2015, 10:09 AM   #222
Stiggy Pop
Stiggy Pop's Avatar
5lbs, I think I will try to grab a denso for my car then.
Love seeing the progress
'79 242
943 pickup
Old 02-03-2015, 03:22 PM   #223
Duder
Duder's Avatar
I appreciate the feedback. Sometimes progress is slow but for projects like this I've found that posting up a quick summary motivates me to keep chugging even if each step is rather small by itself.
Old 02-03-2015, 04:04 PM   #224
122power
dude
122power's Avatar
Ive asked the dmv about that and they said you have to go to the chp. Dont know if its different for you down there. I asked three seperate times and got the same response.
Save the Volvo's.
Ring,ring,ring
"Hello"
"Do you work on Volvo ...
*Click - bzzzzzz*
Old 02-03-2015, 05:29 PM   #225
Sharingan 19
Sharingan 19's Avatar
Consistent updates are more crucial than big updates. Keep chugging along!
Sharingan 19 is offline   Reply With Quote
