Old 08-05-2018, 03:49 PM   #76
Lankku
Lankku's Avatar
Drove a couple of laps on track and only oil pressure sensor stopped working. Ring connector broke between ring and crimp. Might be because of the positioning of the connector and shaking of the wire due time. Spun the insides while loosening the nut and didn't work after that. Replaced it with a new one later.
Again it was hot and didn't install bigger oil cooler yet and had to remove grille to control the temps better. Coolant temp started to climb immediately after oil temp got higher. Max oil temp was around 115°C so not that much really but enough to cause an effect.
DS2500 front pads worked great, much better than RedStuff. They wear faster but it's a price I'm ready to pay for the performance. Other big difference was the heat. Front discs were 380°C after cooling lap and with Red or Yellow I haven't measured over 350°C. Not even on faster tracks that are harder for brakes. Rears were 191°C with Yellow. With EBC's I have measured always around 100°C difference between front and rear. Swapped Reds back to front and boy it's a different world with those, so much less grip.
Hankooks(215/45 V12 Evo2 front, 225/45 S1 Evo2 rear) were also great compared to Nankang semislicks. You can feel the front tire starts to give in on a tight corners but I was still able to increase the steering angle without too much understeer. Nankangs just felt like they would slide and lap times were several seconds slower. Of course brakes were now better because of DS2500 but the car felt lighter to handle and felt faster on tight corners. Federal semis had better grip when I had those in front and I'm going to dump the Nankangs and buy a set of Federals.
Here is incar of the fastest lap. Still waiting turbo to spool when getting out of corners
https://youtu.be/79O9VSf0kxg
Two drive by shots(third gear) from a flagpoint, first around 0:15 and second 1:55:
https://youtu.be/06aiWr_k76g
Dunno why the rear tires would squeal so much in the first drive by Some exhaust note can be heard in the second one.
On Saturday it was time to make a check up to the engine. Was going to replace leaking stem seals(some exhaust side seals leak badly) and check the state of the head gasket and rod bearings.
Head gasket was basically intact and I believe it's only because of the block guard. Normally it would have moved a bit or be destroyed at this point with the abuse it has had. All upper rod bearings have small scorching area on the outer side of the top. Might be because of E85 residue or such? All surfaces feel and seem fine otherwise and the scorching can be bearly felt.
Since beginning of June the bottom end has had a small rod bearing-like rattle just above idle. I've waited it to become louder before any action. While bearings were ok, I found out that the Wössners have suffered the same fate as Wiseco earlier. All skirts have cracks in the oil squirter recess'. No wonder the rattle sounded familiar because it was the same but louder with Wiseco. Use has been hard but still not too nice. And yes, the piston clearance was exactly the given spec 0.07mm/0.0028".
Guess I'll build another bottom end with std bore and pistons and have a block guard installed to it.
The worst, rest aren't that bad and some just visible:
245 -90 "B6284T"
Old 08-21-2018, 04:46 PM   #77
Lankku
Lankku's Avatar
Won't build a "stock" engine with H-rods. Instead have thought of changing to 143 or 147mm rods and DP pistons. If skirts on those would finally last. It's a project that has to wait for a while because I have other cars to throw money at
In the meantime salvaged a -78 265 gl from under two birches where it had sat around 6 years.
Previously on the road around 10.5-11 years ago. Originally B27A which had been swapped to a D24 & M46 and converted to a 2+3 van(cheaper paymets as a diesel vehicle) with a "hard" rear seat. Leather interior in ok condition, working front electric windows and power steering. Paint was bad already ~13 years ago when I saw it the first time so why clean good patina
It took just three evenings and one weekend(from Friday before the last to last Wednesday) to make it roadworthy again. Did some maintenance, welded a couple of spots, cleaned the windows and interior. Vacuumed leaves and trash from the cowl, heater core and front of the skirts. Also swapped in a healthier D24T engine, etc. Have done small maintenance after that and driven over 1000km/620miles after MOT last Wednesday. Swapped in a 23mm front sway bar from 95-> 960 and a 19mm rear, etc. small upgrades.
Rest of the pics here.
Bodywork and other repairs here.
Old 10-26-2018, 10:20 PM   #78
Ghettobird
Ghettobird's Avatar
Lankku, Did the Motronic M1.8 self learn for the T6 injectors? Or did you need to change the injector values with a chip or ostrich? Ive got a set of 550s Im thinking of putting in before I go full blown teardown and T6 block on my M1.8 B6403 swapped 240
Ive got both an ostrich and a chip reader/burner so could do either.
Amazing build as always, really digging the green moss and blue on the new wags
Ghettobird is offline   Reply With Quote
Old 10-27-2018, 05:57 PM   #79
Lankku
Lankku's Avatar
Yes it did with E85 and 0.5-1bar higher fuel pressure. If you are going to use gas then changes are needed. Don't now anyone who has experience on tuning 1.8 so it's been as it is.
For some reason it seems like B6254 ECU is better for coldstarts than B6304S ECU. I've had two or three -95 B6254 cars/ECUs and now a -93 965 with B6304S. 3l requires more attempts to start a cold engine when 2,5l started with one try.
265 has had a new owner a couple of weeks now. Didn't want to drive it in the winter(without repairing the rust spots) and haven't got enought space to store it under the roof at the time. After selling that I bought a -93 965 from the same guy I bought 265 from Had also been sitting a couple of years but almost no rust on the body.
Old 10-31-2018, 03:37 PM   #80
okoye
okoye's Avatar
Do a turbo build on the 960
Old 10-31-2018, 04:06 PM   #81
240wagonguy
You mentioned using maxspeeding rods for the build. Were you able to purchase 6 rods from them or did you have to buy two sets of 5 to get enough?
Old 10-31-2018, 06:29 PM   #82
Sjeng
Sjeng's Avatar
You can buy individual rods on aliexpress.
Old 11-01-2018, 02:40 PM   #83
Lankku
Lankku's Avatar
That's one branch of the plans along with driveability. I did mostly buy it because I needed a winter car
Last week swapped in a M90, BC-Racing front coilovers with 450lbs springs(the same ones that I had in the V90) along with facelift spindles and 850/x70I brake calipers. IPD 25/25 sway bars, 302mm caliper brackets and some poly bushings might be here tomorrow. Grooved 302mm Ate Powerdiscs and pads just arrived.
Some pics just after buying here and changing to Gemini wheels.
They and some other sellers will sell a set of 6 if you ask.
Old 11-01-2018, 04:12 PM   #84
okoye
okoye's Avatar
Where did you pull the oil feed on the b6304? And did you do an up pipe for the holset setup. And does the 93+intercooler work for the turbo setup?
Old 11-01-2018, 06:06 PM   #85
Lankku
Lankku's Avatar
On RWD blocks I've split oil feed from pressure sender and made exhaust manifolds myself. For 965 was thinking of using T6 manifolds as a base. With NA manifolds and up pipes it'll just look nasty.
The big 940 radiator has the same dimensions as a 960 radiator, so a stock intercooler fits into 960 as well. Never used one, always have had a 600x300x76 cheapo.
Old 11-02-2018, 06:18 AM   #86
Broke4speed
Broke4speed's Avatar
Later single-turbo T6 manifold? What years? :D
Old 11-04-2018, 04:19 PM   #87
Lankku
Lankku's Avatar
Using that type of manifold and flange makes a twin scroll exhaust housing useless. You (might) get a narrower rpm range. Aand Garrett is too expensive for my taste compared to the results over other makes.
In other news: installed previously mentioned parts in to 965. Now it just needs some power and I can call it a nice daily
I was suspicious of the 25mm rear sway bar being too much, but it doesn't seem to have much oversteer. Rear has old sloppy Nivomat shocks and their original springs(1 coil shorter) so it makes a lot. I wouldn't use any stiffer stuff on the rear for now. With this setup the balance and handling is quite nice on a small road with various bumps. I would like to have a stiffer front bar for ramps and other hard turns but this will do.
Old 11-05-2018, 05:23 AM   #88
Lankku
Lankku's Avatar
And I'm not saying there's anything wrong. Older manifolds are surprisingly decent and why not the newer too.
What I'm interested in is that is your turbo single or twin scroll? Haven't seen the newer T6 manifold but in your picture looks like might have a dual outlet? Now you could have a good possibility to try if there is any difference by dividing the flange afterwards.
Old 04-21-2019, 08:50 AM   #89
Lankku
Lankku's Avatar
Time to wake this thread up a bit.
965 got some Schwitzer off the shelf along with a better B6304. T6 exhaust manifolds with up pipes to the turbo and 850/x70R pressure plate with solid flywheel. Has served as a daily during the winter. It also received a quick facelift(unfinished) and both rear spoiler and a set of Aurigas from a 945 Classic which I had for a while.
The main car of this thread has been moving again since last Friday. It has another block with block guard and stock T6 pistons. New valve stem seals and a total of 1mm milled from the head because I want to have a higher compression than stock turbo 8.5. Have to visit a dyno at some point for adjustments.
Some new pics of the engine bay:
In other news:
Been looking for another 245 to build for some time and didn't find suitable candidates. Got one rolling -90 in exchange for previously mentioned 945. Then a week later friend offered a complete -92 B200F M47 which he got cheap. Before I picked that up, I bought back a red -90 B200F M45 which I sold around 4,5 years ago. If that's not enough a customer of ours offered a -88 B200E M47 because we had spoken about it last year. Didn't buy it yet but the price is quite tempting
So, I was going to use the rolling chassis as a base but chose the -92. I'll just transfer -92 engine and -90 M45 to the rolling one and make a M47 swap to the -90. Red -90 is so good base for a restoration that I'm not going to build it more than swapping the transmission and doing some mods that won't be seen. Just have to paint both sides because of a bad paint job, change drivers seat(or just upholstery), speaker grills and mostly tidying up. I had a 850 drivers seat in but it was changed to a 240 seat with wrong upholstery.
I've started with the -92, repaired a couple of rust spots, checked the brakes and stuff and it's almost road legal again after sitting some time. Cat is damaged or empty and have to change that to clear the emissions test. After that I can start the build, easier to test drive when it's road legal(at least on paper). It's also tenth white 240 I have owned, -88 would be 11th if I buy it
Some pics here
For now -92 will receive engine version 1 which is 965's old block, 2.5l head with 1.5mm milled off, 204hp cams, newer style timing belt, M90 tranny with dual mass flywheel and stock manifolds. Engine is almost assembled and transmission is waiting for assembly.
Evo 2 will include T6/2.9l crankshaft, 147mm rods, cams with more lift, compression suitable for NA, home made manifolds, lighter solid flywheel, etc.
Red -90 is a stranger in that sense, that it doesn't have power steering or central locking and has a M45 but it has metallic paint.
Old pics here.
Old 05-25-2019, 06:45 PM   #90
Lankku
Lankku's Avatar
Already over a month since last update, well here is another one.
"B6284T" suffered a generator failure on the road and called a friend to bring a second battery so that I could drive home. Swapped another generator from a junk S80. Might have to repair the old one if it's not completely toast. In retrospect it was getting weaker already last summer because fuel was trying to go lean on 1/4 mile on high rpm and load.
Installed powersteering pump with 960 pressure line, 240 reservoir and low pressure lines and now I need to add one more cooler... Had to swap the auxbracket to an unmolested one and cut it as little as possible. Pretty tight fit.
No other new parts for that car, just driving daily. Second primary fuel pump went dead, it was already around six years old so not that surprising.
-92 got it's "new" engine and tranny and some other stuff.
Made front part of driveshaft from junk lying around. Have a couple 740 front parts with the weird male spline, used front half of that and a back half of 240 M46 D24 shaft. No balancing afterwards, no vibrations either
Made a 3" exhaust with biggest freeflow oval mufflers I could fit. Added the tail pipe later.
Engine made a loud knocking noise from the start and didn't stop. Listened that one or two lifters on the intake side were making it(cyl 5/6). Opened up the top and there were two lifters that moved completely without any resistance. Shoul've checked them better
Swapped in new valve stem seals because engine was smoking and I didn't do it before installing the head. Not a big job to do it at this point. Piston rings and worn block are the main reason for smoking. Nice that it didn't smoke at all before in 965(did consume oil) and engine was sitting only a couple of months. Poured some ATF on top of the pistons for a couple of days and all went through. Drove it hot, changed new oil and poured a can of STP Oil Treatment(which I like to use in "B6284T" too). Smoking reduced to a tolerable level and feels like it has reduced more since. Let's see what happens.
Sparco Sprint for the driver, Innovate MTX-L, new discs from Mtec, Ferodo DS2500 front pads and rear pads are EBC YellowStuff which had been on the shelf a long time. Polybushings for front control arm rears and Panhard. Cut the springs a bit to have a reasonable driving height, will update to coilovers once have enough money. Changed new seals to lower pistons on both front calipers. I have done some bedding in and brakes are starting to feel grippy.
Repaired tank sender unit. Welded new pipes, checked leaks with brakeclean, soldered wires to the old stumps and covered them with chemical metal, made a support for the wires and screwed it in using the screw as a ground point. Painted and corrosion protection on top of that. Now pump and fuel gauge are working.
Made a front undercover from thin sheet metal. Couldn't find stock one, it affects alot on the road and I'm going to drive some tomorrow.
Did an overall cleanup. Washed the worst dirt and vacuumed the interior. Paint is matted but not that matted as the picture shows.
Old 06-02-2019, 08:18 AM   #91
Lankku
Lankku's Avatar
Time for another -92 update.
Took it for a short roadtrip and on the way back dropped one cylinder and then shut off. Some troubleshooting on the side of the road in light rain and found that one coil had broken and burned ignition fuse. No spares so disconnected injector wire, made a jump on the engine bay fusebox and moved the power wire inside the car behind a fuse. At home made a quick look and it was not the coils fault, signal wire was grounded.
Next day took the intake off and heater hose had pressed the wiring against corner of the head. There is only tape from the factory and the corner had gone through. Taped it and put a piece of fuel hose over the loom to prevent further damages.
Swapped in a FL 960 23mm front sway bar and made the endlinks. Tried without the stock rear sway bar for a day and it was terrible to drive. Needs much more stiffer suspension to drive without. Adjusted the cams some and now it pulls decently on higher rpm too. Needs dyno time for better adjustments.
Installed old fiberglass hood and some new locks. It's around 1/3 of the weight of the original(6,4 vs 20kg). I've had the hood ~10 years and the paint has taken some damage. Going to paint it again at some point.
Made a 2.5" end pipe for the exhaust. Now it looks decent.
Removed rusty trailer hitch, "useless" interior parts, central locking parts and some wiring. It's getting lighter little by little and more is to come. Dash will remain for now as well as front door cards. I will buy a better set of front seats later, Sparco Sprint for the driver is barely adequate and co-driver has stock one Rear lifted so much that I had to cut the springs again.
Dug up "B6284T"'s old Griffin. It's higher than stock so had to take a couple of rows out from the bottom to make it fit without body mods. Got the tanks welded and installed it.
Yesterday morning swapped Polaris with semislicks and took it to a VRCF trackday. Ahvenisto again and it seems to be a fitting track for this. Just needs more power, better suspension, locker, etc. But it was good fun without problems. There is oil consumption because of the worn cylinders but less than expected. Brakes, tires and cooling worked great.
Some incar laps: https://youtu.be/EB2It5ZRJug
Clutch pedal went to the floor just after leaving the track. Felt like slave cylinder pushed the piston too much out and it did. Jacked the left side up on the side of the road, managed to fiddle a tire iron so that i could push the clutch fork back enough to set the piston seal back to its place with other hand. Added some brake fluid and drove home just fine, just had to pump the pedal because of the air. I was thinking of installing a stopper under the pedal because now it moves much more than with floor mats but didn't have the time.
Old 06-02-2019, 08:52 PM   #92
oldschoolvolvo
oldschoolvolvo's Avatar
Great work. Inspiring and taking notes...
-Mike
1998 V70 T5
1979 242 DL 16v
|Feedback|
Old 06-07-2019, 07:53 AM   #93
oldschoolvolvo
Originally Posted by Lankku View Post
What are you using for a radiator fan in this 240?
*Edit: Looks like you are using a 940 e-fan in your other whiteblock 240.
Old 06-07-2019, 03:13 PM   #94
Lankku
Lankku's Avatar
940/960 fan FTW I've used those in everything I have been able to fit one.
That picture is from when "B6284T" had a stock radiator. I had to change the fan after installing Griffin rad because it would have been a tight fit. Griffin is thicker than stock and that engine has a front mounted trigger wheel. Now it's also faster to adjust cams while dynoing. Some BMW fan was just the right size to install in front of the intercooler.
-92 doesn't have/need a fan yet. I don't have to sit in traffic for a long time and a stock radiator would be just fine even on track.
On Tuesday I changed rear gear oil(might've still been factory fresh ) and on Wednesday I made upper and lower braces. Wish i would have had time to make them before going to the track. Didn't even remember how big difference they make even with an old stock suspension. It's getting better to drive little by little.
And here is a pic of a slightly updated engine bay:
Should really repair the firewall before going to the track next time.
Thanks.
Old 06-07-2019, 03:26 PM   #95
oldschoolvolvo
Also, what ECU are you using on the -92 240?
Old 06-07-2019, 07:01 PM   #96
Lankku
Lankku's Avatar
ATecu V3, a simple MS2 variant sold and designed by a local Megasquirt/Maxxecu retailer. Has built-in fuel pump relay etc.
Old 06-07-2019, 10:14 PM   #97
DET17
Reformed SAABaholic
My understanding is MS2 cannot do sequential fuel. We are talking about a whiteblock vehicle, yes?
Old 06-08-2019, 04:44 PM   #98
Lankku
Lankku's Avatar
Well only -92 in this topic is the one in previous pictures
MS2 can't do sequential fuel and there is no need for that or sequential spark with a basic setup like mine. ATecu board supports only 4-cyl sequential in any case. All other engines have to use batch fuel/fire and it's fine. "B6284T" has MS3X V3 and I haven't updated that to sequential because of lazyness. I have to do it with bigger injectors but it's not in the near future, 1200cc is enough for ~800hp with E85.
Old 07-14-2019, 02:13 PM   #99
Lankku
Lankku's Avatar
Made an exhaust manifold for the -92.
6-2-1 with 1.75" primaries and 2" secondaries. Not nice but might be better than stock? Exhaust noise is smoother and more quiet, which is nice because new cams will make more noise in near future. Can't really say how much there was improvement otherwise, it's been a while since I drove it harder. But feels better.
Merge collector is a generic piece and it might not be as good as a proper one but let's see. Also hooks for the springs for secondaries are still missing.
Swapped another brake booster in to the "B6284T". Old one was leaking and barely held vacuum. Took one from a friends parts car and painted it epoxy black just like the old one. Otherwise car has been just sitting and collecting dust because of the booster and I have been lazy. Gave it a wash and started driving around again.
Old 07-14-2019, 10:45 PM   #100
LC4CARL
Aero challenged
LC4CARL's Avatar
I wish I had 1/2 your skills.
@PDXvolvo on IG
