Old 03-21-2017, 10:41 PM   #51
Jack
Banned
Jack's Avatar
Originally Posted by matt b View Post
Nice work! Satisfying to see it in your pictures and props for doing this on gravel and not even a concrete slab!
Originally Posted by Old Iron View Post
Coming along nice! Good to see some of the nice saves you have made!
Thanks guys. I enjoy working on the 122 the most. I been meaning to pave the driveway, maybe this year
forgot to post picture of front brake line
no antenna
new antenna
found this dirty girl in the trunk
old window channel seals
they are glued in and have a little stainless boarder on edges
cleaned off most of the glue
while inside the door I removed 80% of the original deadener and added Dynamat
new from Volvo window channel gaskets are like modern cars- all rubber, pressfit and no stainless
this one was a pain to get past the window. I took the window off the regulator and squeezed the seal past it.
sorry for the crappy photo
Old 03-22-2017, 11:15 AM   #52
matt b
I just did the quarter windows on my 65 yesterday using new seals from Volvo. Why didn't do this earlier ? Good call on the Dynamat, I did the same thing and then did the roof before doing the headliner. Definitely makes a difference with sounds and heat.
Old 03-22-2017, 07:24 PM   #53
Old Iron
I Roll
Old Iron's Avatar
Stop buying old Volvo's and pave the driveway!
Turbobricked
Old 03-22-2017, 07:37 PM   #54
That's the street in beautiful downtown Oroville.
Old 03-23-2017, 05:35 PM   #55
matt b
No, his driveway is gravel. But yeah, that street could use a little love too.
Old 04-02-2017, 12:20 AM   #56
Jack
Banned
Jack's Avatar
It made a huge difference in my 245, especially with heat from sun!
I was tired of the window rattling around. I dont have the rivet tool and the one gasket on that rail is removable
Today
replaced the headlight rings and installed a h3 (?) lights. I dont even know where or when I got them. Some made in India stuff that seems to be good.
I then installed this - sadly I only have one - sold my last pair to brown friend of mine - can anyone guess who?
Also installed trunk seal and cleaned out the trunk. Removed all the old sound deadening
and found out my gas tank needs replacement. I have another one but for now Im just going to seal up the small holes.
before
after
trunk seal
thats fuel there
Old 04-02-2017, 12:34 AM   #57
Shifted
On the Hill
Shifted's Avatar
Get that thing outta there before it kills you.
He built my Bose 901s all by himself...
Doing something because you enjoy it is a must in life.
Originally Posted by ME II View Post
Without mistakes there is no learning.
"Two roads diverged in a wood, and I... I took the one less traveled by, and that has made all the difference." Robert Frost
Lifeboat for the plankwalkers/otherwise disenfranchised.
Shifted is offline   Reply With Quote
Old 04-02-2017, 12:45 AM   #58
Jack
Banned
Jack's Avatar
I bought some tank sealer goop... should work for now. I will replace it when the fuel sender gasket comes in
Old 04-02-2017, 12:56 AM   #59
Shifted
On the Hill
Shifted's Avatar
Run some sheetmetal screws into the holes (lightly) and then goop over that.
Old 04-02-2017, 12:57 AM   #60
Jack
Banned
Jack's Avatar
thats a great idea, thanks
Old 04-02-2017, 02:54 AM   #61
Shifted
On the Hill
Shifted's Avatar
I know what you've got. BTDT... harder to do on the bottom/midwest salt ftw... those were the days.
Old 04-02-2017, 08:59 PM   #62
matt b
Dude.... that tanks needs to be in a landfill yesterday! That's scary! Those headlight covers are the same as AC Cobras, they're all over Ebay for $15-$25/pair
Old 04-02-2017, 11:40 PM   #63
toms_elleck
toms_elleck's Avatar
Those headlights are awesome.
That tank is nasty. Find someone with a backyard full of old volvos, and buy a tank from them.
-Thomas
toms_elleck is offline   Reply With Quote
Old 04-03-2017, 12:17 AM   #64
Shifted
On the Hill
Shifted's Avatar
He knows what he has.
Old 04-03-2017, 12:21 AM   #65
Or little squares of inner tube rubber and sheet metal screws.
Old 04-03-2017, 10:24 AM   #66
cwdodson88
Or the neoprene gasketed sheet metal screws for metal roofs
The Build Thread
SVEA - PUSHROD TURBO!
Old 04-03-2017, 01:10 PM   #67
matt b
I'm supposed to go check out some hulls tomorrow, some of the cars were Amazons. If there's a gas tank in decent shape, do you want me to grab it ? Cover shipping and it's yours (assuming there's one to yank)
Old 04-03-2017, 03:19 PM   #68
Jack
Banned
Jack's Avatar
Thanks for the offer, that is super nice of you. I have a good tank already, it's a little dented at the bottom but I should be able to push it out when I take off the fuel sender. I do however need a front seatbelt. My donor car was a year off and it's different. It wouldnt be a big deal but the bolt holes are different and so are the threads in body.
old on the right- one out of 65 on left
one that I need is on right
Old 04-04-2017, 12:19 PM   #69
matt b
I'll look, I probably have a few spares.
Old 04-07-2017, 12:32 PM   #70
Jack
Banned
Jack's Avatar
Matt is sending me a replacement belt. Thank you sir.
My other headlight grill came in... I would install it but it's raining cats and dogs right now
What should I use as a sealant between the tank and body of car?
Old 04-07-2017, 12:39 PM   #71
Tfrasca
Tfrasca's Avatar
I just used some clear silicone, and it seems to have sealed well, and won't be a pain to remove because it's not adhesive. Seems like it'll work?
Old 04-07-2017, 01:30 PM   #72
IPD sells this stuff, but I just use cord weatherstrip from the hardware store. 3 rows seems to work best.
Old 04-07-2017, 01:50 PM   #73
matt b
Yeah, I used the putty we use to seal the trim clips inside the doors and trunk. Thin layer works great.
Old 09-16-2017, 01:12 AM   #74
Jack
Banned
Jack's Avatar
Been a while since I did anything to this car
Today I cleaned up this page and fixed the links from photosuckit. Sure takes a long time to do this
Got around to replacing the fuel tank with one that I got from the 65 junk car. Dented at the bottom and some rust inside. I will clean out the rust from the inside with molasses - the old school trick
all the screw heads were rusted so I just sanded them down. I made sure to smoke and take off the sender to try to spark the fumes - but with no luck
thank is out
This is the replacement that I'm going to use
cleaned the top
fuel sender has seen better days
dented at the bottom but it was pretty much free
Old 09-16-2017, 02:02 PM   #75
matt b
Throw some rocks from the driveway and shake it around!
Bill Hursch sells a good tank sealer, I've used on a lot of different cars and I have never had an issue. Glad to see you working on this thing again.
