Old 06-17-2018, 09:31 AM   #26
Brotkasten
Jonas
Brotkasten's Avatar
I think if I'm lowering more it will look awesome
Originally Posted by MadDog_945 View Post
nice big hubcaps would look awesome to it..
You are right. Im worried about the mounting tho...
91' 940 B230FB+T M90
Old 06-17-2018, 08:35 PM   #27
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
huh? it is oem application..
Old 06-18-2018, 02:26 AM   #28
Brotkasten
Jonas
Brotkasten's Avatar
On my Peugeot rims?
I will make it fit!
Old 06-18-2018, 07:37 AM   #29
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
it clamps on the hub.. it should fit...
Old 06-21-2018, 07:12 AM   #30
Brotkasten
Jonas
Brotkasten's Avatar
Ok, so the following problem(s) showed up yesterday:
Symptomes:
- Manometer on fuel rail shows varying fuel pressure.
- Idle is varying, but not rough.
- LOUD main fuel pump.
- Weird sound (like there is air mixed in the fuel) when under load.
- No change when under load. Excellerating like normal.
My suspects:
- Air in fuel system (in tank hose, bad seal)
- Bad fuel filter (I'll have to change it anyway)
- Bad FPR (had that once with the EXACT same symptomes)
What I checked:
- Took out the pre-pump and checked for a leak in the small tube. There was no hole what so ever and the rubber felt like new. The filter sock was clean.
- Visually inspected all the fuel lines. One injector was leaking on the fuel rail seal!
Actions:
At first I'll be changing out the injector O-Rings. Im not going to keep that fire hazard! Maybe that will fix the fuel pressure problem... (MadDog doesnt think so... )
Old 06-21-2018, 07:40 AM   #31
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
yeah.. you havent told me also that your fpr had that problem already in the past..
Old 06-21-2018, 08:14 AM   #32
Brotkasten
Jonas
Brotkasten's Avatar
No, it was the original one that was broken! I told you everything
Old 06-21-2018, 08:24 AM   #33
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
you bitch.. dont lie to me !
Old 06-25-2018, 08:26 AM   #34
Brotkasten
Jonas
Brotkasten's Avatar
I did a silly and not usefull mod to my car this weekend:
Did this just to mess with the VW Polo tuners in my area...
I put a solenoid valve into the vacuum tube leading to the CBV.
Now I can trigger the "Stututu" flutter sound whenever I want with a flick of a switch Without having to deal with the negative effects of having no CBV.
Atm I can only activate it when on boost because otherwise the vacuum is trapped inside the cbv and it just stays open. Maybe I'll add a one-way-valve in the future...
Together with my K&N Cone filter and metal piping it makes a pretty sweet sound.
https://www.instagram.com/p/BkLTv50nKC-/
Old 06-25-2018, 11:22 AM   #35
Brotkasten
Jonas
Brotkasten's Avatar
That explains some things.
Idle vacuum went from -26.5inHg to -20inHg. That sounds better
Old 06-25-2018, 03:30 PM   #36
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
you should have installed this.. would have been cheaper ;)
Old 06-25-2018, 05:12 PM   #37
Brotkasten
Jonas
Brotkasten's Avatar
Already payed enough for the turbo
and no: the solenoid cost me 7€
Old 06-30-2018, 09:08 AM   #38
Brotkasten
Jonas
Brotkasten's Avatar
I made up this emblem.
Quite like it
Old 07-09-2018, 02:15 PM   #39
Brotkasten
Jonas
Brotkasten's Avatar
I've been driving around without a shifter boot/cover for a while now and the accumulating dirt annoyed me.
All the boots I could find were disgusting and stinky tho
So on this rainy day I made my own.
I think the color matches my seats quite well.
Old 07-09-2018, 04:30 PM   #40
thessejway
Wannabe TBer
thessejway's Avatar
That looks great
Awesome job
thessejway is offline   Reply With Quote
Old 07-09-2018, 04:38 PM   #41
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
advanced womanly skills ;)
Old 07-09-2018, 05:22 PM   #42
Brotkasten
Jonas
Brotkasten's Avatar
Grandma helped a bit...
Old 07-15-2018, 09:45 AM   #43
Brotkasten
Jonas
Brotkasten's Avatar
I added a padded cover to my armrest. MUCH more comfortable than the stock one.
Old 07-18-2018, 04:51 AM   #44
Brotkasten
Jonas
Brotkasten's Avatar
While most people at work are on vacation I had some freetime to design this...
I already printed it 1:1 (only half of it - it's symmetrical) and it's a good fit.
Im going to get a 1650x550mm sheet of plywood for my first try. Thinking about fiberglass.
Old 07-18-2018, 10:46 AM   #45
thessejway
Wannabe TBer
thessejway's Avatar
You have a 3D model of a 940? Where did you find it? I've been looking for one
Love the splitter, I may have to do this also
Old 07-18-2018, 01:48 PM   #46
Brotkasten
Jonas
Brotkasten's Avatar
It's a 3D scan you can find online with a bit of searching. I scaled it and confirmed it was scaled correctly by measuring varius dimensions. It's rough but workable.
I can upload the stuff tomorrow and send it via PM.
Old 07-18-2018, 03:46 PM   #47
thessejway
Wannabe TBer
thessejway's Avatar
That would be awesome. Thanks!
Old 07-19-2018, 01:52 AM   #48
Brotkasten
Jonas
Brotkasten's Avatar
https://drive.google.com/open?id=1nm...Dh4Fw3gRebrHBq
I recreated my brick
Old 07-19-2018, 10:12 AM   #49
thessejway
Wannabe TBer
thessejway's Avatar
haha very nice
Thanks for the model
Old 07-21-2018, 10:48 PM   #50
Brotkasten
Jonas
Brotkasten's Avatar
Got the first "prototype" cut, painted and intalled today.
The template I made in CAD worked perfect.
Now I just have to order the support rods.
