Old 08-05-2018, 04:46 PM   #51
Brotkasten
Jonas
Brotkasten's Avatar
I bought an old 940 SE for 100€ and gave it away the same day.
I installed the bigger radiator - the oil cooler now has to move again.
I only bought it because of the M46 in there. I'm going to swap it in place of my M47. It was just too cheap to say no... (Still hoping for that M90)
Old 08-05-2018, 04:55 PM   #52
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
you should have waited a bit.. you can buy all you need for a m90 swap from me, if you want
Old 08-20-2018, 12:34 PM   #53
Brotkasten
Jonas
Brotkasten's Avatar
I painted the rims silver this weekend. Used a wire brush set and got to work until I was left with a metal surface. It took about 2 hours for one wheel.
Old 08-20-2018, 04:46 PM   #54
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
you should have painted the centers gold ;)
i think it will look much better when you lower the front 15-20mm more and add some negative camber! long ricy wheelnuts also will look nice on it
really nice how it stands there
Old 09-10-2018, 01:36 AM   #55
Brotkasten
Jonas
Brotkasten's Avatar
This weekend I cleaned out the engine bay a bit by cleaning and spraypainting some crusty lookings parts...
Apart from the intake manifold and timing gear it looks nice and clean now I think
Also installed this for safety... and looks:
I also got this nice retro looking MOMO wheel (I really should take a picture at daylight )
Hopefully I can get the new transmision in soon.
Old 09-10-2018, 02:46 AM   #56
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
Yeah.. because now it looks gooey and moldy ;)
Still needs more camber and spacers ! Nice Car!
Old 09-10-2018, 03:04 AM   #57
Brotkasten
Jonas
Brotkasten's Avatar
ITS REALLY NOT
And the camber mod is on the agenda.
Old 09-12-2018, 04:52 AM   #58
Brotkasten
Jonas
Brotkasten's Avatar
I had to try this...
I will have this block off plate made (will release the .DXF if requested):
Old 09-12-2018, 09:42 PM   #59
Mbeas96
Mbeas96's Avatar
Should be okay because of the AMM on the cold side, yeah? Very clean engine bay, props to that!
Old 09-13-2018, 02:11 AM   #60
Brotkasten
Jonas
Brotkasten's Avatar
I cant tell any difference from the too locations. Might need a bit of cleaning after a few miles... I've got a few spares flying around.
I used the oem intake hose and attached the idle hose to the pcv intake. It's a tight fit but it works.
Thank you! Lets see how much oil the BOV is gonna spit all over it!
Old 09-21-2018, 06:10 AM   #61
Brotkasten
Jonas
Brotkasten's Avatar
My Turbo is shot and started to smoke often especially on summer days. I checked the play and verified my guess.
While waiting for my new chra assemlby I created this CAD model (pictures show progess):
Not meant to be accurate or realistic... It's just what I like to do for fun
Old 10-18-2018, 05:15 AM   #62
Brotkasten
Jonas
Brotkasten's Avatar
I replaced the turbo chra last week:
And did some other minor things:
- Because of the battery location I'm now running a Honda Civic air box (Ek4 I believe). The connections are 3". Ill have to get some hose for cold air.
- Installed a new under engine tray
- Replaced the cam shaft seal
- Fabricated my own strut brace
- Replaced the main fuel pump and filter (I had some weird ticking sound - it's gone now)
Old 10-18-2018, 09:42 AM   #63
JCol91
Macaracachimba
JCol91's Avatar
Looking good! I’m following you on IG and the process is well covered, subscribed for inspo. Also hoping to download that scan CAD model to start playing around with. You still running with the 25mm spacers on back?
'95 855 Turbo - In hibernation
'93 244 N/A - 18" Eikers, IPD Sways, Eibach Red Lowering Springs, Bilstein Tourings, M47
IG: @stock_bricks
Flickr: @JCol91
JCol91 is online now   Reply With Quote
Old 10-18-2018, 09:49 AM   #64
Brotkasten
Jonas
Brotkasten's Avatar
Thank you!
Hit me up on instagram!
Yes. The wheels have 47mm offset. So spacers are a must have!
Cheers!
Old 10-18-2018, 10:14 AM   #65
oldschoolvolvo
oldschoolvolvo's Avatar
Wow nice CAD work.
-Mike
1998 V70 T5
1979 242 DL 16v
|Feedback|
Old 10-18-2018, 12:24 PM   #66
Brotkasten
Jonas
Brotkasten's Avatar
Originally Posted by oldschoolvolvo View Post
Wow nice CAD work.
Thank you!
I already went bit further...
Old 10-21-2018, 04:29 AM   #67
J2_
J2_'s Avatar
Those CAD skills
J2_ is offline   Reply With Quote
Old 10-22-2018, 04:17 AM   #68
Brotkasten
Jonas
Brotkasten's Avatar
Originally Posted by J2_ View Post
Those CAD skills
Doing CAD 8h a day...
Old 10-25-2018, 01:56 AM   #69
Brotkasten
Jonas
Brotkasten's Avatar
I got myself a new BOV.
I also wrote this guide small guide on +T with some information i gathered.
Next week is going to be good: I can finally install the gearbox and clutch!
Old 11-07-2018, 03:16 AM   #70
Brotkasten
Jonas
Brotkasten's Avatar
This weekend I installed my M46 along with a new clutch.
I had a small problem which you can read about here.
You can really see someone jacked the wagon up wrong in the past. The lower sill flange is mangled up at all four jacking points. (needs some attention ASAP)
The old M47 was quite leaky
I also painted my valve cover in wheels matching silver:
Old 11-28-2018, 03:58 AM   #71
Brotkasten
Jonas
Brotkasten's Avatar
I scored some nice leather seats this weekend. I paid half of whats usual in Germany.
Now I will have to do the headliner.
Old 11-28-2018, 12:24 PM   #72
soclosenotnear
Any ill effects from not having a timing cover? I've been thinking about not reinstalling mine when I put it back together, but am more worried about the belt walking off more than anything. I realize this shouldn't happen, but seems like it could.
check my feedback here
Old 11-29-2018, 03:12 AM   #73
Brotkasten
Jonas
Brotkasten's Avatar
I removed it about 15.000km ago. I have not noticed anything worrying yet.
Old 11-29-2018, 03:14 AM   #74
Brotkasten
Jonas
Brotkasten's Avatar
My new rims:
17x7.5, 45mm offset, 25mm spacers
225/45/R17 tires
Old 12-05-2018, 07:55 AM   #75
Brotkasten
Jonas
Brotkasten's Avatar
Drawing of my Volvo in Initial D Style!
