Old 04-20-2018, 10:35 PM   #1
855 T-5R
855 T-5R's Avatar
Default TD-613 Bulb Replacement
I found two bulbs at the front of the radio but there doesn't seem to be an easy way to remove them. I found a post on MVS here but the user there had to solder. Is there an easier way and, if so, (a) how and (b) what bulbs are used?
1991 245 M471995 855 T-5R (sold)1996 854 GLT (sold)1998 V70 GLT (sold)
Feedback Thread
855 T-5R is offline   Reply With Quote
Old 04-21-2018, 12:00 AM   #2
stiligFox
Part-time Tinkerer
stiligFox's Avatar
Do you have pics of the bulbs?
stiligFox is offline   Reply With Quote
Old 04-21-2018, 08:35 PM   #3
855 T-5R
855 T-5R's Avatar
Here ya go (see below). The bulbs can be found on either side of the display. They don't appear to be able to be pulled straight out and I don't want to risk yanking on them only to break the connection with the board. The bulbs go into a plastic housing that has turns down at a 90 deg angle toward the board. The bulbs had little blue plastic covers (presumably to blend with the yellow bulbs to make a green value?) but I don't plan on putting them back.
Old 04-22-2018, 12:38 PM   #4
ovlov760
ovlov760's Avatar
Hard to tell from the photos but it does look kinda like further disassembly and soldering might be required.
In my personal experience, Volvo's dash bulbs tend to be neo-wedge t3, t4, t4-t4.7 or t5 size. If RadioShack were still around, I'd suggest taking the bulb there to find a match.
2009 XC70 T6
2011 XC90 R-design
1998 V70 AWD
1966 M-B 230
2006 V70R GT
2011 C30 T5M
2006 XC70
1997 850 T5
1988 760 Turbo
ovlov760 is online now   Reply With Quote
Old 04-24-2018, 09:35 AM   #5
stiligFox
Part-time Tinkerer
stiligFox's Avatar
Yup - def looks like soldered - you have the long stems on the bulb that folds back into holder.
Also - if you still have those blue caps, I’ll take them - hard to come by those haha.
