Old 08-08-2018, 02:49 AM   #1
mj4276
mj4276's Avatar
Question To T Cam or Not to T Cam... ?
Hi, I recently picked up a T cam at the junkyard, but upon closer inspections it seems to have some flaws.
Some of the lobes have a bit of pitting near the point(apex?):
There are these odd concentric ovals at the points of some of the lobes:
And the whole thing is sort of a straw yellow color (couldn't be overheated could it?). Although the bearing surfaces are less scored than on the stock M cam:
What do you think? Is it safe to put in the T cam? Should I stick with my old M for now? Any advice is appreciated
Last edited by mj4276; 08-08-2018 at 02:11 PM.. Reason: Just clarifying my question
mj4276 is offline   Reply With Quote
Old 08-08-2018, 03:42 AM   #2
MXSlotkin
You did what to a Volvo?
MXSlotkin's Avatar
M cams are to stock N/a cars what T cams are to stock turbo cars.... Stock garbage. Dont waste your time.
1983 242 DL
*Rebuilt B23F+T RSI stage 2 cam, Megasquirt
*15G
*T5 swap
*IPD sway bars
http://forums.turbobricks.com/showthread.php?t=239154
1993 945T
*IPD Cam and Sways
*15g @ 17psi
*LH tuning 101 underway
*Wasted spark conversion
*Big Ebay Intercooler
*3" exhaust from turbo to exit
SOLD 1994 944
RIP 1991 945 Turbo :(
MXSlotkin is offline   Reply With Quote
Old 08-08-2018, 10:57 AM   #3
ogamer777
ogamer777's Avatar
Get an A or B cam if going turbo
84 242 DL M46 212k
82 244 GLT (15G) M46 237k+
81 264 GLE M46 105k
Feedback thread: http://forums.turbobricks.com/showthread.php?t=322924
Looking for some hard to find Volvo accessories for my 82 GLT. Especially rubber trunk mats.
Stuff I have already:
http://forums.turbobricks.com/showthread.php?t=331526
ogamer777 is offline   Reply With Quote
Old 08-08-2018, 11:16 AM   #4
JohnMc
JohnMc's Avatar
Maaaaaaybe a T cam, if you have an automatic and, aren't trying for a bigger HP peak. It's a real tractor cam, early, low spool, nothing much on the top end (that the AW70 doesn't like anyhow).
'63 PV Rat Rod
'93 245 16VT Classic #1141
Old 08-08-2018, 02:09 PM   #5
mj4276
mj4276's Avatar
Sorry to clarify, I'd like to put the T cam in if I can, but I'm worried that it might be too worn out and damage my motor. Should I be concerned about the straw color, slight pitting, and weird ovals on the lobe tips?
(on a side note, my car is an NA b230F with an m46)
Old 08-08-2018, 02:12 PM   #6
You'll need to fix the pictures for an answer to that question.
Old 08-08-2018, 02:20 PM   #7
oldschoolvolvo
oldschoolvolvo's Avatar
I vote for this since you have an M46. Will work well with or without turbo.
*Edit: here is an A cam...
https://rover.ebay.com/rover/0/0/0?m...2F173451247818
-Mike
1998 V70 T5
|Feedback|
Old 08-08-2018, 02:24 PM   #8
Jack
Banned
Jack's Avatar
I would go with the W cam if you can find one
Old 08-08-2018, 02:29 PM   #9
JohnMc
JohnMc's Avatar
Σ cams have a better transition from mid-range to top-end torque.
Old 08-08-2018, 02:35 PM   #10
Jack
Banned
Jack's Avatar
But at $650 for used, is I still worth it?
Old 08-08-2018, 04:13 PM   #11
ovlov760
ovlov760's Avatar
The t cam ought to be one of the easiest cams to aquire for next to no $$$. If you're worried about the condition of yours, I would just find another one to run. You'll also need shims.
2009 XC70 T6
2011 XC90 R-design
1998 V70 AWD
1966 M-B 230
2006 V70R GT
2011 C30 T5M
2006 XC70
1997 850 T5
1988 760 Turbo
Old 08-08-2018, 05:03 PM   #12
740740
3==740
740740's Avatar
L cam.
740740 is offline   Reply With Quote
Old 08-08-2018, 05:19 PM   #13
Can play the blues
Since you have an M46 you would be well served to get a cam that gives you more mid range and top end so you can enjoy your driving much more.
If you want to go conservative. At the very least get a Volvo A or B cam as suggested above. An enem V15 is the first level of an aftermarket street performance cam but is still a very mild cam by performance standards. It's like the n/a version of the IPD turbo cam. The cam is ground to work with an n/a engine instead of turbo.
No don't use that T cam if you have any doubts. It's a lot of effort to put in a cam and you don't want to take a chance.
Old 08-08-2018, 05:35 PM   #14
Sjeng
Sjeng's Avatar
Why would you need shims if the base circle is the same as the original cam? (they are)
Old 08-08-2018, 05:49 PM   #15
Can play the blues
Because the valve lash may need to be adjusted. Even if the cam is on the same base circle.
Old 08-08-2018, 06:07 PM   #16
mj4276
mj4276's Avatar
I've got a handful of extra shims, and I already have the cam out of the car for some other work, but if T and M aren't that different anyways, I think I'll play it safe and stick with the M for now.
On the same note, where would one look for an A or B cam? I don't suppose there's any chance of finding one in a SoCal junkyard... Ebay?
Old 08-08-2018, 06:08 PM   #17
Jack
Banned
Jack's Avatar
I have a B cam 60 shipped
Old 08-08-2018, 06:49 PM   #18
mark244turbo
mark244turbo's Avatar
I'd stick with the M-cam for now.
The T-cam just isn't worth the upgrade, even if it was in great condition.
Both cams are very boring (low lift, little duration) and only good for towing a trailer.
Try to find an H, K, D or V-cam if you have a manual gearbox.
Or at least an A, B, VX or VX3 (recommended upgrade for automatics).
I can really recommend the K-cam. That's what i run in my 240 (B230F, manual gearbox) and it pulls great from 1000 all the way up to around 5500 rpm. Instead of running out of breath at 3000 rpm it starts pulling stronger and stronger the higher you rev.
Here's a list of OEM and aftermarket cams and the engines they came in: https://turbobricks.com/resources.php?content=camspec
1994 960 B204FT, full options, leather interior.
1991 745 B204GT (Swede Sixteen VT) M90 conversion.
1986 745 B230FT, 302mm V70 brakes, camber mod. (sold)
1983 244 turbo B21FT/AW71 - leather /airconditioning
1987 244 GLT - Polaris, Strutbar, viking motorsport lower chassis brace, k-cam, gaz strut/shocks, pu-bushings
mark244turbo is offline   Reply With Quote
Old 08-09-2018, 02:57 PM   #19
Can play the blues
The good thing about using an A or B cam is that they were used in turbo engines by Volvo overseas and work well. Buy the B cam from Jack and you are ready for a turbo.
Old 08-10-2018, 02:44 AM   #20
mj4276
mj4276's Avatar
Thanks for all the advice everybody. I just put the car back together with the M cam and she purrs (maybe underwhelmingly) like new. I appreciate the offer Jack, but I had to get the car back on the road to daily. The next time I dig into the engine like this though I'll definitely do some cam shopping.
