Old 09-09-2018, 03:25 PM   #1
Volvord302
Default S60 R Motor Rebuild/Replacement
Hi all, I know this is normally a RWD forum, but I'd like a little front wheel drive advice. Because who can resist 300HP and a 6 speed?
I have a line on a 2004 S60 R. The guy says it may need an engine, or perhaps a cylinder head. Sounds like he doesn't really know. What I'm wondering is worst case scenario and the block is trashed, how difficult is a rebuild or a replacement engine? Does anybody have any familiarity with these cars, what goes wrong with them?
I'm not at all afraid to get my hands dirty, but I'm afraid I'm a little inexperienced when it comes to FWD Volvos, or any Volvo motor for that matter. My brick runs a 5.0 and that's what I'm used to working on, rear drive american rigs. Can you guys give me an idea of how difficult of a project this may be? also any other maintenance/ease of working on info on the transmission and the AWD system. My research hasn't turned up much.
It also seems getting your hands on a used B5254T4 is near impossible.
Volvord302 is offline   Reply With Quote
Old 09-09-2018, 04:52 PM   #2
GTJordan
Been here for too long
GTJordan's Avatar
Headgaskets are rare on those. Likely cracked cylinder wall. Which would require a new block or sleeves (Darton).
Can find engines from a Volvo recycle shop. Depending on your location.
Jordan
Old 09-09-2018, 05:42 PM   #3
Volvord302
Jordan
Nearest junkyard is about 4 hours away unfortunately. How is sleeving them?
Old 09-09-2018, 05:44 PM   #4
Volvord302
Also, would any 2.5 short block work? Then just use all the R spec manifolds, turbo, head, etc.
Old 09-12-2018, 02:13 PM   #5
GTJordan
GTJordan's Avatar
The R uses different pistons for sure, possibly rods. I'm not 100$ sure.
Most people look for 2.3 bottom ends if you're going for power.
Otherwise, I'd be scouring used Volvo places.
Jordan
Old 09-13-2018, 09:03 PM   #6
vwbusman66
sold his dream car
vwbusman66's Avatar
The R (B5254T4) has different pistons/rods/head as compared to a 2.5T (B5254T2).
Where is said S60R located? I think we looked at the same car.
I would either go with a 2.3 (B5244T5), or build the hell out of a sleeved/reinforced B5454T4 if I had to do an engine.
1971 142 M40/B20
1991 Mercedes 300TE
Originally Posted by Stiggy Pop View Post
You're not going to be an aerospace engineer because you have a library card and a can-do attitude.
Originally Posted by stick70 View Post
It's all just lifter noise til it comes out the side.
vwbusman66 is online now   Reply With Quote
Old 09-22-2018, 09:30 AM   #7
Volvord302
This car is in Montana. So update on the car. He had a compression test done on all 5 and it seems it's not the block. He said 45 lbs even on all 5 cylinders. He seems to think they took it to a quick lube place and they didn't drain the oil before filling it back up. that caused the timing to jump and bend the valves. I don't know. But, if what he believes is true, a head rebuild or a fresh head should be a bit cheaper, no?
Old 09-22-2018, 10:13 AM   #8
tryingbe
Boosting along.
tryingbe's Avatar
45psi on all 5 cylinders? Valves are not bent. Something else went wrong. Condition of rest of the car? Cost? S60R is not a cheap car to maintain, are you sure you want it?
85 GLH 367whp
00 Insight mpg > yours.
Old 09-22-2018, 10:30 AM   #9
Volvord302
Rest of the car is ok. Interior is good. About 100k miles. Exterior needs a little work. He's asking 2800, which I don't think I would pay. I was considering maintenance cost. Probably a fair bit more than a 5.0. Yep, that's why I'm asking you guys, just to get a better idea of what I'm getting into. But for even low pressure, jumped timing makes the most sense to me.
Also, how is maintaining a turbo car?
Old 09-22-2018, 10:39 AM   #10
tryingbe
Boosting along.
tryingbe's Avatar
Synthetic oil change every 5000 miles. Coolant changes every 2 years. Check to see PCV system is working. Check to see there is no exhaust blockage.
Maintaining a turbo car is EASY. Maintaining a S60 R, not so much.
Set of front struts is almost $600. https://www.fcpeuro.com/products/vol...BoCWRUQAvD_BwE
$2800? He's smoking something. A running driving S60 R can be found for $3900. https://tucson.craigslist.org/cto/d/...688048090.html
Old 09-22-2018, 10:48 AM   #11
Volvord302
Yikes. Brakes aren't any better. Thanks for the heads up. It sounds like the motor isn't bad to work with, but all the wear/maintenance items are just plain expensive. Gotta pay to play eh?
Old 09-23-2018, 01:51 PM   #12
ovlov760
ovlov760's Avatar
This.
A S60R with a blown motor is worth scrap value IMHO. A pristine '07 6-speed V70R with a blown motor... now we're a bit closer to reality but still on the high side.
You can find runner for not much more if you're patient. Just beware that angle gears aren't cheap and neither are the struts. Make sure the AWD actually works before purchasing.
2009 XC70 T6
2011 XC90 R-design
1998 V70 AWD
1966 M-B 230
2006 V70R GT
2011 C30 T5M
2006 XC70
1997 850 T5
1988 760 Turbo
ovlov760 is online now   Reply With Quote
Old 09-25-2018, 02:25 PM   #13
wyatt8740
wyatt8740's Avatar
Originally Posted by ovlov760 View Post
This.
I know a guy who recently blew out the engine in his relatively pristine '06 manual silver V70R. He traded it in to the local Volvo dealer. Any ideas what they'll do with those cars when they get 'em?
(My dad has a still-working identical V70R, btw.)
1991 244 (manual 5spd)
1993 245 (auto 4spd [for now])
And the Dalai Lama smiled and said, 'Well my son, life is like a beanstalk, isn't it?'
wyatt8740 is offline   Reply With Quote
Old 09-25-2018, 02:51 PM   #14
tryingbe
Boosting along.
tryingbe's Avatar
How much did the dealer pay him? $1?
Old 09-25-2018, 10:08 PM   #15
wyatt8740
wyatt8740's Avatar
I don't actually know. I was surprised he traded it in to them, though.
I'd be too afraid they were going to crush it or something just to reduce the remaining supply of parts and force americans to buy new slushbox cars.
Of course, maybe they'd refurbish it. I don't actually have a clue, which is why I asked.
(Guess no one else not under NDA is likely to know, though)
Old 09-26-2018, 10:09 AM   #16
dualcitizen
Yes, I sold my R (was a sad day) because I couldn't justify the cost of ownership anymore. I know people are picking up used R engines on eBay for around $1000 usd. Any S60 T5 motor will bolt right up, just swap the oil pan over from the R since it has a oil level sensor.
The R head gaskets do not go back, if it's losing coolant you have a cracked block. Get a new motor, shim it, tune it, and have fun.
Some say the cost of acquisition is about $6,000, which I think makes sense. Budget around $250/month just for normal maintenance items.
Best of luck.
PS: If you can find a 2.4 T5 motor, get that. It has thicker cylinder walls. Don't get the 2.3, it has a longer stroke and is quite a different engine.
dualcitizen is offline   Reply With Quote
