Bit of a stupid issue but here goes. 1997 945T.
I need the downpipe welded way before I replace the stock 13C with a straight flange 16T. I don't have access to a welder anywhere near where I'll be working, so it should fit straight away when I put it in.
My question, will the outlet of the straight 16T be in the exact same spot as the conical 13C? If so, I can just cut the conical flange off the other downpipe I have and weld the straight flange on it, right?
Thanks.
Thanks.
