WindowsBreakerG4
ALDORF THE DESTROYER OF WHITE SHIRTS
- Sep 29, 2008
- Western PA
OK so I am at my wit's end with this, alternator doesn't excite. Started like this every now and then (for about a week or 2) it would start up with a bunch of dash lights on (classic bad alternator) drive it like 50' car was good. It would only do it on cold starts (this is still true at least for start up). Once it did it I was good.
Next we have a new symptom that started the other day, it will un excite while driving, drop it out of od into 3rd, revs hit 4k no issue. Did that about 4 times in 60 miles the other day. Symptoms of not exciting when cold.
Today we have a new symptom I haven't seen before alternator stopped charging, rev to 4k; won't excite. Rev it to 5k; no go. Rev to 6k, still no go. Pull over turn car off back on, alternator is charging, no lights. WTF.
What i've tried so far:
The alt was rebuild about 15 months ago when I blew out the rectifier, battery is 8 months old tops.
Other thoughts are maybe it's a bad ignition switch? But this seems unlikely as I haven't noticed anything else not working.
Ideas? I'm kinda stumped. I am debating pulling new wire from the cluster to the alt but that sounds like a huge pain. Also, anyone have the harness book for a 91 volvo 940? I seem to be missing it. I am about to take a long trip in this car and would like to get it sorted.
- reving it (usually works see above),
- I checked to see if there is voltage at the exciter wire at the alt, there is half of a volt, jump it to the battery, all lights go out, remove jumper, they all come back on. Once the car warmed up, all lights went out on their own. Charging was taking place at 14.37 v as indicated at the alt AND the battery.
- Wiggling the wiring harness in the engine bay, seems to make no difference
- Wiggling the wiring on the back of the cluster. I never had this issue before I had the cluster out, but nothing seems loose? I've tried pulling it out again and then
