Old 11-09-2014, 02:05 AM   #226
malloy1
malloy1's Avatar
Originally Posted by Fivehundred View Post
Can you elaborate on this for the electronically challenged like me?
Does it work like this?
Originally Posted by Karl Buchka View Post
That's exactly how I did it. It's the same circuit that's listed on msextra.com.
Paul
malloy1 is offline   Reply With Quote
Old 11-15-2014, 08:48 PM   #227
Mylesofsmyles
Solved the problem about my NO TACH...it was due to a faulty J702T igniter...
I dug up my old spare, and swapped it in....tach works perfectly!
So, to confirm, the J702T will directly drive a Volvo tach....with no use of a relay coil or pull-up wire...but your J702T igniter has to work.
Old 11-16-2014, 11:12 AM   #228
Beachee
Beachee's Avatar
Hello
Can you please post some pictures of the J702T setup in the car?
Would be nice to see it... :-)
Beachee is offline   Reply With Quote
Old 11-16-2014, 10:24 PM   #229
Mylesofsmyles
I can do that!
Old 12-17-2014, 09:27 PM   #230
brod
Does anyone have or know where a I could buy the female connector for the j702t ignitor
brod is offline   Reply With Quote
Old 12-17-2014, 10:45 PM   #231
Mylesofsmyles
Old 12-18-2014, 02:37 PM   #232
turbotankshane
So I got a board in the mail today from another tb'er, and I've got a harness built for my VAG coils, and ipdown's program to setup the dwell for these coils. Going in either tonight or tomorrow, but I gots a Q.
I'm going to keep my stock coil set up, and use a switch chip with stock setup, so if I need to I can just switch back to the dizzy if the need arises. Can I just use the switched 12v for the stock power stage for my coils, and split it between the two? Or if not, what's the best switched 12v to tap into?
Eh, looking at a diagram makes it seem like the stock power stage shares switched 12v with several others anyways, so I'll run it there.
Old 12-19-2014, 11:51 PM   #233
turbotankshane
I got the board soldered up yesterday, and installed with coils today.
No start. Now the coil and dizzy were still in place, and the car will run if I just hook up the spark plug wires.
From the stock coil, I have a bright blue spark, and with those wires hooked up I have a thick, bright blue spark at the plug. With wasted spark coils hooked up, I have a weak, yellow spark.
I built the harness using AWG 16 wire for switched 12v and grounds, and 18 gauge for logic level spark outputs.
I tried with ground to engine block, and grounded to battery; tried with power from switched 12v at several different locations, and then just power straight from battery while cranking. No change.
I pulled the ecu back out and double checked solder. The board has 5v power and good ground; I believe the VR signal is good because if I swap the outputs I start getting fire 180 degrees out, engine speed picks up, etc. My balancer is off a little right now so I can't check with a timing light.
Measuring at the logic level outputs, I'm getting a signal but maybe it's not strong enough? Or maybe I just need to redo my harness.. I'm completely unsure and a little frustrated, I was ready for my car to fire off on those coils!
Help?
Old 12-21-2014, 03:36 AM   #234
turbotankshane
Still no fire. So I rebuilt the harness with 10 gauge wire for the 12v and ground circuits, with the 10 gauge tied to the positive terminal and run through a relay that is controlled by switched 12v from the diagnostic port.
Then I tested resistance on the coils individually, and compared that to resistance from the connections to logic level outputs, and I have continuity through those circuits. So I tied signal ground to the EZK's internal ground, no change.
I tested the board with a DVOM, and I've got 5v to the board, and a good ground, which leads me to suspect the spark output. I believe it should be a 5v output, but I'm only getting around .3v to the board. I read here http://www.atmel.com/Images/doc7607.pdf that minimum output high voltage for the Atmega controller is 4.0v, so it should be sending 5v to the coils, but it's not.
So I think I might either a bad board or a bad solder to the spark output on the EZK; I'll check it in the morning.
So I looked and the IC on the board is attiny24a, and its dc characteristics are listed here
http://www.atmel.com/Images/8183_105.pdf
The attiny24a needs to see .6v to pull the circuit high if supply voltage is 2.4-5.5v; from the spark output, tested on either side of the resistor and at the wasted spark board, I'm only getting about .5v. The wasted spark board is outputting .3v consistently on both spark outputs. I don't think I'm going to get any fire out of that. Something strange is going on...
Old 12-22-2014, 08:54 PM   #235
turbotankshane
It works!! Thanks to ipdown for helping me figure it out. Karl's board uses NPN transistors to switch the coils' path to ground; these VAG coils I'm using have to use PNP transistors to switch a 5v power feed. So I went to radioshack, got a few transistors (2n3096 I believe), a few 1k ohm resistors, and a small round pcb to mount them on.
I fed the spark output signals from the wasted spark board through the resistors and into the new PNP transistors, 5v through the emitter and then ran the output to the coils from the collector. Now Karl's board switches the path to ground for the PNP transistors, and those feed 5v to my VAG coils.
And after that whole mess, I had the leads coming out of the EZK box switched, so I was a little angry at first... switched the output leads and she fired right up!
Old 02-08-2015, 04:06 PM   #236
RuneD
Is it possible to order this "buchka boards" for volvo b230(fk) ?
I live in Norway..
PayPal is fine...
RuneD is offline   Reply With Quote
Old 03-03-2015, 01:58 PM   #237
The Beaner
The Beaner's Avatar
Wondering if anyone has used MSD's Ford DIS 4 Tower Coil Pack Part No. 8241 http://www.summitracing.com/parts/msd-8241/applications
1984 242 Turbo, M46, Red LH2.4
1983 242 Turbo
1992 745TI Green M46
PAST:
1992 745TI Red M46
1992 745TI Red Auto
1981 242 N/A, M46, Carlsbad Yellow
1992 244 Grey Auto
1993 945TI Flat Black M46
1993 945TI Black Auto
1989 745TI White M46
1991 244 Gold Auto
1993 245 Black M47
1992 245 Blue M47
1983 245 Green M46
The Beaner is offline   Reply With Quote
Old 03-03-2015, 05:19 PM   #238
turbotankshane
https://www.youtube.com/watch?v=cJvJeE9d1v8
Assuming its someone on here
Old 03-03-2015, 05:59 PM   #239
The Beaner
The Beaner's Avatar
Thank you!
Old 03-16-2015, 09:57 PM   #240
firefighter519
So I'm assuming these boards are no longer available?
firefighter519 is offline   Reply With Quote
Old 03-16-2015, 10:24 PM   #241
turbotankshane
Try bjilsma technical innovations if you can't get hold of Karl. They sell a board as well
Old 03-16-2015, 11:04 PM   #242
Mylesofsmyles
There's one on eBay right now!
http://www.ebay.com/itm/Volvo-240-74...cf398b&vxp=mtr
Old 03-17-2015, 10:42 PM   #243
Lord_Athlon
Sf1k Kryptonite
Lord_Athlon's Avatar
For only 2.3x the original price
Originally Posted by rvolvor
Old 03-20-2015, 01:19 PM   #244
pieterveenstra
Just order a wasted spark PCB from BTI..
Good quality and the same price. And most important: items are in stock
The kit even includes a screw in plug
pieterveenstra is offline   Reply With Quote
Old 03-26-2015, 11:31 AM   #245
crassh242
Been looking for these boards as well,
but as earlier posts say the Bijlsma's kit is quite a step up in price.
crassh242 is offline   Reply With Quote
Old 03-26-2015, 11:45 AM   #246
puliukk0
-Plug&Wiring loom, €45,00 including 21% Dutch Tax
-Wasted Spark PCB with connectors, €55,00 including 21% Dutch Tax
I ordered these, i tell when i got these. (already in transit)
I think thats nice price, with connector etc...
puliukk0 is offline   Reply With Quote
Old 04-02-2015, 01:44 PM   #247
puliukk0
I got these installed, nice quality!
Heres, some pictures:
I have to mod/bend little that coil connector to get 90 degree bend... (stupid hood )
Or just weld better coil bracket...
Its easier to buy better bracket from BTI... But i thinked i can do it...
Old 04-10-2015, 01:16 AM   #248
Ghettobird
Ghettobird's Avatar
Karl​, Buddy READ MY MESSAGES
Ive been waiting over 6 MONTHS for my parts and you no longer respond to my messages?
Ive had to message people all over the forum to find out what the hell is happening.
Id like my parts Karl, Ive paid a LOT of money for this stuff and id like it SOON
Ghettobird is offline   Reply With Quote
Old 04-14-2015, 11:39 PM   #249
mikep
The MP
mikep's Avatar
Ghettobird, buddy, stop posting the same **** in all of these threads, or I will ban you.
Use the feedback thread, or ask for help.
Originally Posted by centason View Post
Nice pencil sharpener.
Old 04-22-2015, 08:21 AM   #250
Mode$6
The moral of this story is a lot of spoiled litte rich *******s, who have mommy and daddy cut checks for there whims don't care about people who work hard to pay there bills. Word is they moved to LA to bigger and better things for spoiled brats.
Mode$6 is offline   Reply With Quote
