Old 11-24-2016, 11:31 AM   #276
JW240
All idiot, no savant
JW240's Avatar
Originally Posted by lookforjoe View Post
Is this a dead (NLA) item now? Now that I have a viable EZK116 setup, eliminating the dist/cap/rotor wear items seems like a good idea...
BTI doesn't list it on their website, and reading through this I assume Karl no longer produces the boards?
BTI still has the boards, I inquired a few days ago. info a bijlsmatechnicalinnovations dot nl
Old 11-24-2016, 03:36 PM   #277
5ft24
I just got my board from Karl about a month ago. It's installed. Runs great!
5ft24 is offline   Reply With Quote
Old 11-27-2016, 11:15 AM   #278
lookforjoe
lookforjoe's Avatar
Did you message him via TB? I did send him a PM, but that was only a few days ago, given the holidays he may not be checking in. I'll wait to see if he gets back to me before going the overseas source route.
My XR July2013 - 446AWHP @ 8K rpm
Old 11-27-2016, 12:39 PM   #279
5ft24
May also want to try the email in his profile. I know he has a lot going on at work right now and is putting in some long hours.
Old 11-27-2016, 12:51 PM   #280
5ft24
Plus when I checked with the overseas vendor, they wanted like 400 USD for it... Karl wants 65... I need to go find my emails for the coil and module... most places get over 100 for each, but I got both total for less than that, brand new
Old 11-27-2016, 02:01 PM   #281
JW240
JW240's Avatar
That price is for a complete kit with coil, brackets, wiring etc.
The complete pcb is about the same price.
Old 11-27-2016, 09:43 PM   #282
lookforjoe
lookforjoe's Avatar
It works!! Thanks to ipdown for helping me figure it out. Karl's board uses NPN transistors to switch the coils' path to ground; these VAG coils I'm using have to use PNP transistors to switch a 5v power feed. So I went to radioshack, got a few transistors (2n3096 I believe), a few 1k ohm resistors, and a small round pcb to mount them on.
And after that whole mess, I had the leads coming out of the EZK box switched, so I was a little angry at first... switched the output leads and she fired right up!
Which coils specifically did you use? I'm thinking of using the standard Volvo application ME7 coils (Bosch 00117)
Did you make a schematic for the COP variation? It's still 1-4, 2-3 correct? Not individual signals..
Old 11-28-2016, 12:32 PM   #283
lookforjoe
lookforjoe's Avatar
I tried the hotmail in his profile - it's not a valid email it seems
Old 11-28-2016, 08:52 PM   #284
Dannyt0186
Hey Karl
Do you know if your board is compatible with the IGN-4 module that diyauto sells?? Not trying to plug anyone In your thread, but I was curious if it could considering I am looking to build my own megasquirt in the near future and it would be mega dope if I can re-use components.
Thanks
Dannyt0186 is offline   Reply With Quote
Old 11-28-2016, 10:02 PM   #285
5ft24
It has an input for each cylinder. The waste spark board here has an output for cylinders 1 and 3, and another for 2 and 4. You may be able to feed 2 of the inputs on the IGN-4 with each of the outputs of this board. Do you know what it requires for input voltage/current?
Old 11-28-2016, 10:04 PM   #286
5ft24
Actually, yes. If you use the Bosch motorsports coil pack, you just use 2 of the inputs and 2 of the outputs.
Old 12-01-2016, 01:14 PM   #287
lookforjoe
lookforjoe's Avatar
No way to use COP on the Fiat - no clearance.
Fabian from BTI got back to me today, so I have a board coming from them.
Got the coil pack off Amazon, and 3pole JPT connector from Mouser. J723T power stage off eBay, with pigtails (used).
Have to change the cable ends on my Kingsborne 8mm wire set, or get a new set made, whichever is more cost effective.
Old 12-11-2016, 09:38 AM   #288
lookforjoe
lookforjoe's Avatar
Originally Posted by DNAsEqUeNcE View Post
I have to edit that post that everyone keeps quoting, because OC2 and IB2 are switched
Hi there.
Trying to figure out which of these posts has the correct wiring for the Mitsu power stage...
Can you please advise?
EDIT: Just follow this schematic?
OC2 - to Coilpack Pin 1
IB2 - from WSB output 2-3
correct?
Old 12-11-2016, 01:51 PM   #289
Beachee
Beachee's Avatar
Not all the board had this problem. I bought a few of these board from Karl. Some had these 2 mislabeled. Switched.
Beachee is offline   Reply With Quote
Old 12-11-2016, 10:50 PM   #290
lookforjoe
lookforjoe's Avatar
Right - so which is correct? Your schematic I am assuming
Old 12-12-2016, 04:11 AM   #291
Beachee
Beachee's Avatar
Some had the signal to the coil pack switched. Don't assume nothing.
Old 12-12-2016, 01:04 PM   #292
lookforjoe
lookforjoe's Avatar
Right - actually since I'm using the BTI board none of this is directly relevant - I'll need them to clarify their schematic
Old 12-28-2016, 10:09 PM   #293
Dannyt0186
Is it just me or are people having problems getting a hold of Karl? Ordered my board from him and still no dice.???
Old 12-28-2016, 10:43 PM   #294
MrD
Ditto
MrD is offline   Reply With Quote
Old 12-29-2016, 10:58 PM   #295
Dannyt0186
Well that sux booty.....
Old 01-01-2017, 09:17 PM   #296
bgpzfm142
crossmember
bgpzfm142's Avatar
Originally Posted by MrD View Post
Ditto
Not good. Not good. I'd like to order 3 of these boards, which are needed for various projects.
Last update on the Buchka Engineering Facebook page was around September 14 2016, and it appeared he was still selling them then, but what about now?
Circumstances can change significantly in that amount of time.
On Saturday, I sent an email to the address he uses for his Paypal.
If there's no response by next Saturday, I guess he's bored with these boards.
_______ THE FLEET (AKA good luck trying to park around here)
71 1800E | 73 144 | 74 142 (x2) | 74 145 | 79 242GT | 87 745T | 88 780 V6 | 93 945T | 2010 S80 V8
plus a Holden Commodore VT SS 5.7
feedback thread
bgpzfm142 is offline   Reply With Quote
Old 01-03-2017, 10:47 AM   #297
lookforjoe
lookforjoe's Avatar
Trying to clarify once and for all the actual wiring of the relay with transistor and resistor for use in cases where stock wiring has been modified / removed.
There is the pic from MS, 500's sketch, and the photo of Karl's actual relay (transistor has shrink wrap so I cannot categorically state which pin is collector & which is emitter. To remove any confusion I'd like to clarify the physical connections required to the relay. I made a diagram with all three plus what appears to me to be the actual wiring required (fig. d), based on the photo of Karl's relay (fig. c)
I have assumed "stock ignition output pin" refers to the feed from EZK box to pin 5 on the stock powerstage, since coil neg and tach feed are connected.
Based on these references, 4 wire connections at the relay are required:
Relay ground (30) - 2N5551 emitter (1)
Spark signal (87) - 2N5551 base (2) via 1k ohm resistor
Signal to tach (85) - 2N5551 collector (3)
VBat to relay coil (86)
Can this be confirmed by someone who's done it?
Old 01-04-2017, 01:04 PM   #298
bgpzfm142
crossmember
bgpzfm142's Avatar
As I've gotten a couple of PMs about this:
Been in touch with Fabian at Bijlsma Technical Innovations, who replied to my email very quickly (in this silly season, too, which impressed me) with a complete price list for his wasted spark boards and kits, which aren't listed yet on the bijlsmatechnicalinnovations.nl website.
He offers a wide range of choices starting with the board and connector only, right through to a complete kit which includes brackets, coils, etc, as well as a range of EZK and LH 2.4 chips.
A customer of Fabian's has also written to me to say that he's very pleased with the quality and design of his wasted spark board.
Old 01-06-2017, 10:17 AM   #299
Kestrel
Kestrel's Avatar
Ditto
Unfortunately... I ordered a board from Karl last year, and ended up having to refute the purchase with Paypal when Karl was unresponsive for what was nearly two months.
I was OK with any sort of delay, but he just... never got back to me. Not sure he responded to the Paypal dispute either, but rather just let it time out, at which point money was auto-refunded.
It sucks because I really wanted to buy another board or two from Karl, but thankfully it looks like Fabian/Blabla will be selling an alternative.
Old 01-06-2017, 11:12 AM   #300
lookforjoe
lookforjoe's Avatar
The BTI version has been available for a couple of years. I would rather have bought from Karl, simply because he has given much support here, however the BTI version is no different in function in terms of WS. No launch, etc. Works as intended.
