The late cars use an aux pusher fan and different pressure switch arrangement. They also use an orifice tube arrangement with the dryer pictured (like a GM/harrison) instead of the expansion valve setup used on 78-1990 cars (in various flavors) with the in-dash thermister style dial switch.
They achieve the same thing, but the pressure switched, orifice tube system cycles the A/C clutch according to the switch on the dryer mounted near the firewall panel. The operator just turns the single toggle "on" or "off" on the dash. Look at a pic of the engine bay of a 91-93 car if you can. 1993 is the first and only year of R134.
The old system, we have a relay triggered by the thermister dial thingy and expansion valve mounted on the passenger core support sheetmetal. You turn the dial and it cycles the a/c clutch according to how cold you want it. The manual advises that you leave it on continuously for the first bit and then turn it down to prevent icing or undue wear.
If you want a 240 series and want good reliable A/C, rip everything out of a 91-93 car if you can. Easiest is just to change out the old york compressor (on 84 and older), convert the filler to something nicer to use and enjoy the nice quiet integrated plastic reservoir 91-93 style PS pump. However, EVERYTHING is much better laid out in the late cars as far as A/C goes, and that means changing everything over...blower box, passenger firewall panel, lines, brackets, compressor, electric fan and fittings and the larger condenser used on those cars. A GM/harrison universal variable orifice tube (fits in the volvo) and some duracool make the things really work well. I personally keep the dial switch in older cars, but I am not an electrical wiz and I am a bit of an electrical minimalist.
Beware 93s...they are R134, but the biggest biatch is that some genius at volvo decided to change the thread on all the fittings. Same purpose and everything...I swear, the newer cars get, the more ways the bean counters find to screw the customer. A/C and 240 was more or less an afterthought, so I'd try to make it fit and work as best you can with careful addition of late model stuff as you deem necessary and go from there. I was fortunate enough to have a cooling technician help me out with it all and make sense of it. I can't say I am looking forward to laying it out real clean and nice and not busy in my black california 245TI. The little differences in all the A/C parts and the A/C not being so cool in the first place in most 240s except the latest ones makes it a real challenge.
