Old 02-03-2017, 11:24 AM   #1
xDread92x
xDread92x's Avatar
Default Volvo 240 Driver Window Weatherstrip
Hey all,
So there is the strip that surrounds the window that the window goes inside. It covers the rear of the window opening, the top, and front as you go toward the side view mirror. It's not the window scraper I am unsure what the name is.
The rear part of the stripping has gone somehow and has caused afew issues. For one water finds it way in of course and two when driving above 50-55 loud constant annoying air gets in and just makes the inside of the car loud.
So how can I get ahold of a replacement stripping and how's installation?
Thanks
xDread92x is offline   Reply With Quote
Old 02-03-2017, 11:46 AM   #2
Window guide or window track.
You'll need to drop the window down into the door to change it.
Edit for window tipping picture.
Old 02-03-2017, 05:46 PM   #3
xDread92x
xDread92x's Avatar
I have a 92 240 in the yard. Just a junk car. I am thinking about trying to pull the window surround off of it.
Any thoughts?
Old 02-03-2017, 05:58 PM   #4
I thought I just told you exactly what to do?
Old 02-03-2017, 06:51 PM   #5
xDread92x
xDread92x's Avatar
Sorry I didn't clarify that my car is an 85 and I was asking in terms of compatibility from the 92.
But this method of the window I haven't seen before. Do I actually have to do the window that way? Couldn't I just roll the window down?
Thanks
Old 02-03-2017, 07:46 PM   #6
Same thing 74 - 93 Front / Rear & 242 window specific, but not side specific.
Yes because it will not tip the other way.
No I highly doubt it will go in.
Thanks
Old 02-03-2017, 08:37 PM   #7
nel621
The rubber drops down into the side of the door about another 3/4 inches IIRC. Although you may be able to remove the rubber with the glass in place ( maybe) I doubt you will be able to reinstall it correctly without tipping the glass.
Old 02-03-2017, 08:41 PM   #8
xDread92x
xDread92x's Avatar
Is there any way I could just replace the back strip missing?
The vertical peice perpendicular to the door handle.
Also is there any way to get an automatic window down with no battery in the car?
Thanks
Old 02-03-2017, 08:46 PM   #9
Hotdoggin
Hotdoggin's Avatar
No, and put a battery in the car. That's the way to do it unless you want to pull the door card, cut the wires and power it directly from a smaller battery.
1978 245DL - B21 Penta carb powered!
1982 244T - Crushed
1983 245DL - SOLD
1984 244DL - Crushed
1984 245DL - Sitting in someone's yard
1991 740SE - girlfriend's car
2008 S60 2.5T - Money drainer
Hotdoggin is offline   Reply With Quote
Old 02-03-2017, 08:46 PM   #10
xDread92x
xDread92x's Avatar
It does not have an ignition switch in the car.
Old 02-03-2017, 09:25 PM   #11
TestPoint
TestPoint's Avatar
Crush it.
Ford V8 Conversion Manual -
Old 02-03-2017, 09:56 PM   #12
xDread92x
xDread92x's Avatar
No way Jose.
Old 02-03-2017, 10:04 PM   #13
Unplug the lead to the power window motor and jump it there with 12V from any source.
You'll want the window about 1/2 way down then reach up in there lift the front of the clip and push the clips back off.
Old 02-03-2017, 10:41 PM   #14
xDread92x
xDread92x's Avatar
So I would unplug the motor on the driver window and then put 12v on the motor prong and then a ground on the other prong on the connector?
Old 02-03-2017, 10:44 PM   #15
No you would be jumping its leads directly.
Old 02-04-2017, 12:08 AM   #16
xDread92x
xDread92x's Avatar
The leads on the connector from the motor right? I'm just going by a picture of the motor and it shows its wiring coming off with the connector on the end.
Old 02-04-2017, 12:13 AM   #17
Yep one way's up, and one way's down, you just gotta jump them and see what happens.
Old 02-04-2017, 12:43 AM   #18
xDread92x
xDread92x's Avatar
Yea I believe backwards is down. I don't have a 12v supply so I may just run wires from a battery and do it that way. One coming off positive and one negative.
Old 02-04-2017, 12:53 AM   #19
Sounds good.
I carry one of my Milwaukee 12V batteries in the JY to test things and do this sort of stuff.
Old 02-04-2017, 01:00 AM   #20
Jack
junkman
Jack's Avatar
Sounds good.
18v makes the window come down faster
