Old 05-05-2017, 10:06 AM   #1
Hotdoggin
Hotdoggin's Avatar
Default Rusty fuel tank
Car: 1978 245 N/A with Penta Solex carbs.
My fuel tank is trashed, I'm running two small filters before the fuel pump, and one after the fuel pump. They work, but I think the restriction is killing my pumps. I would like to find a new tank, but they're seemingly NLA for this year. It has the gravity feed out of the bottom left corner of the tank, no pre-pump. I took it out and went to have it boiled, but he said there's so little metal left, he's worried there would be tons of pinholes. Are these tanks actually NLA? Are all of them that I find going to be just this rusty? There is the option of a fuel cell, but I'd have to retro it to work in place of the old tank, since this isn't a racecar or anything. Thanks in advance for the advice.
1978 245DL - B21 Penta carb powered!
1982 244T - Crushed
1983 245DL - SOLD
1984 244DL - Crushed
1984 245DL - Sitting in someone's yard
1991 740SE - girlfriend's car
2008 S60 2.5T - Money drainer
Hotdoggin is offline   Reply With Quote
Old 05-05-2017, 10:23 AM   #2
Kjets On a Plane
Devoid of Luxury
Kjets On a Plane's Avatar
The "side spout" no lift / vapor lock prevention tank pump is NLA.
Volvo gave you a later tank for your early car when you could last get anything.
Side spout tanks were 1974-1976, so not exactly going to be rust free by now most likely
How PSI a stock can support?
Old 05-06-2017, 10:34 AM   #3
Hotdoggin
Hotdoggin's Avatar
Sigh, so I'm SOL. Is my only option just to run a lift pump now, with a later tank?
Old 05-06-2017, 10:40 AM   #4
No recall tanks for the 74's left in the system?
Old 05-06-2017, 12:32 PM   #5
planetman
planetman's Avatar
Hello,
About a year ago we had to replace the gas tank for a 1978 264.
Since all of the parts to properly update the gas tank aren't available new anymore, we decided to modify one of the cheap pieces of crap repro gas tanks. The repro tanks don't have a fuel isolation bowl, nor the expansion tank inside.
The local ReNu shop swapped the filler neck and installed a fuel isolation bowl from a completely different gas tank into the repro tank. The expansion tank cannot be transferred. It is made of plastic and would melt when the ReNu coating is being cured in an oven.
If you don't want to add the lift pump, you don't have to install the bowl.
Eric
Torrance, CA 90502
Old 05-06-2017, 12:39 PM   #6
Or post in wanted and pay your shipping like a big boy.
Old 05-06-2017, 01:22 PM   #7
James10952001
Using a later tank with the pre-pump in it doesn't seem like all that big of a deal. It's a small price to pay in order to have rust-free reliable fueling.
James10952001 is offline   Reply With Quote
Old 05-06-2017, 03:06 PM   #8
Hotdoggin
Hotdoggin's Avatar
It's really not a big deal, I just like being able to hot swap fuel pumps if needed. One 10mm, two clamps and done. That said, I will probably go that direction, and keep an in line low pressure pump as well.
Am I going to have fuel gauge problems moving up to a sender with a pump in it? Is the resistance difference on the newer senders?
Old 05-06-2017, 04:01 PM   #9
No. The return hose changed from hard plastic to rubber, but that's it.
Here's the TSB for the conversion to intake pump.
http://hiperformanceautoservice.com/images/SB_Grp.24_No.17%20Fuel%20Tank%20'74-'78.pdf
Old 05-06-2017, 05:39 PM   #10
Kjets On a Plane
Devoid of Luxury
My diesel has no lift pump but does have a later tank, FWIW.
Just no pump, different sender, and no evap system IIRC.
