The 75 242 DL
TIPSP
Got Boost?
Moorpark, CA
Images should be updated soon...
More images are here:
I bought a supposedly running car from a forum member to replace my totaled 82 244turbo.
1975 242 DL with a B20, k-jet, auto, and only 49,800 original miles supposedly.
Here is the car when I got it.
Nothing worked on the car. Mold in the carpets. Rear calipers frozen, Distributor drive gear broke, Fiber gear was missing teeth. Engine was gross. Carbon build up and slugged oil. Gas tank rusted. Injector and feed lines ruined.
Rust on the headliner. Cleaned up some of it.
The interior was leaking water, hence the rust and mold. Fixed that problem.
Some quick paint in the bay.
Fresh carpet.
Added Better looking mirrors
Brand new GT (R-sport) gauge cluster to go in very soon.
Transferred the parts from another car, and my old totaled 244turbo.
Finishing rust removal and the under coating.
New seals:
Yoshifab x member. Modified.
Custom Drive shaft
Finished cleaning the rear end
Lower mounts for the engine.
Was going to mill them, but somethings happened and the machinist was busy.
New exhaust
Learning to tig on this car.
RSI adapters didn't fit right
New Master
New Fuel Lines everywhere
Stereo Modeling
Fuel filler neck adapter I made
Stereo Continued..
Stereo Cont...
Cleaned up some of the wiring
New Rims:
Added a resonator to keep it more street friendly.
Teaser:
Alignment. Left over 80-20 works great.
First Trip to the station.
It took way to long to get it running, but it is running now.
Some wiring is left, and the supercharger and rear brakes. Then it will be done.
2.5 years of waiting to drive it. It is fun to drive.
Here is when it was first started after 2.3 years.
<iframe width="560" height="315" src="https://www.youtube.com/embed/0YBHoNutqvo" frameborder="0" allowfullscreen></iframe>
Without resonator. and first rebuilt fuel distributor I did. We Rebuilt Kjet distributor once, and cleaned out the injectors (thanks Ian). Also opened and cleaned the CPR. I bought a new rebuilt distributor because I had to open the other one back up again. Didn't have a new plate for it. Ran like crap the second time I took it apart.
I will have to get more videos later.
Thanks,
And thanks to all the people that helped me get it done. Me and my dad did most of the work.
somethings like machining and the drive shaft where out sourced. I learned(ing) to tig weld on this car.
Ian (hiperfauto) played a major rolled with awesome parts and advice.
Ben helped with custom awesome parts, and some other people not on this forum help source parts.
oh, and this is my daily drive so it will not see too much boost.
The pulley is designed to run the charger at 14,000 rpms (which is like 10 psi), but I can control that with the bypass valve on the charger.
probably 5-7psi. should be like 160 crank hp.
That looks amazing. I had no idea you put so much work into this car. I'm glad you finally got it all sorted out.
And what's this about a supercharger? You never said anything about it.
Oh. My. Lord.
Truly impressive, I'm gonna post some of these pics in the inspiration thread, you've more than earned it.
What made you want to stick with the b20?
