t8fanning
8v are still cool, right?
- Oct 10, 2010
- Vancouver, WA
I've been doing a ton of reading trying to figure this out, but haven't found anything yet. If you know an applicable thread, please point me to it.
My problem is that on cold start my engine runs very rich (~10), and sometimes chugs like it is only running on 3 cylinders or something. After a minute or so, the chugging stops and it idles fine, but still rich (maybe 10-11). The car runs rich until the coolant is fully heated, and then it runs what I think is normal on light throttle (~14-15) and richens up on WOT (~11). So it seems my only problem is when the car is warming up.
Last weekend I took apart the control pressure regulator. Everything seemed clean and fine, but I cleaned it anyway. I thought it might be an issue with the lambda system, so I just measured my O2 voltage this morning after everything had warmed up and it was 0.87 V. That seems high from what I've read, but isn't it just indicating a rich condition?
I'm new to K-jet, so bear with me as I probably don't know anything. I haven't yet taken any fuel pressures, so I am trying to piece together a fuel pressure testing setup.
