Old 01-08-2018, 01:31 PM   #376
propav8r
F*ck Edgar
propav8r's Avatar
That harness looks beautiful.
turn the ignition timing up til it's faster than eamon's miata, then replace the shortblock #wootenthings
K-Jet to Megasquirt Article
The Departed: 1981 245, 1983 245 Turbo, 1983 244 Turbo, 1983 242 Turbo, 1984 244, 1985 245 Turbo,
1989 244, 1989 765, 1990 245 Turbo, 1991 244, 1992 245, 1997 855
Old 01-08-2018, 01:33 PM   #377
Stiggy Pop
Stiggy Pop's Avatar
There isn't. I don't use it to mount the intake manifold. Just the idle air valve, and now my CAS connector.
ah ok.
Sounds like the clutch/slave is all set up and playing nicely after the trans swap?
'79 242
943 pickup
Old 01-08-2018, 01:33 PM   #378
t8fanning
8v are still cool, right?
t8fanning's Avatar
Thanks. It's could be better. Not every connector has a boot, which kinda bugs me and isn't what professionals do. But oh well, it works for an amateur like me.
1982 242 Turbo.
Old 01-08-2018, 01:36 PM   #379
t8fanning
t8fanning's Avatar
Originally Posted by Stiggy Pop View Post
ah ok.
Seems to be working ok. Pedal is still pretty stiff, but maybe I just don't remember how hard it was since the last time I drove it was before thanksgiving.
Also, I forgot how grabby that clutch is. It's very different from my sister's manual Ford Focus I was driving for a bit.
Old 01-08-2018, 01:57 PM   #380
Stiggy Pop
Stiggy Pop's Avatar
How many miles on it? Mine definitely did settle in a bit after 500 or so miles but I think you're past that point by now.
Definitely won't be like a focus though. I get in my SAAB right out of the 242 sometimes and try to put the pedal through the floor, then spend the first few shifts remembering how normal cars feel.
Old 01-08-2018, 02:01 PM   #381
t8fanning
t8fanning's Avatar
I don't think I'm past 500 miles yet. But there's no way to tell, my Volvo odometer doesn't work. But I did just get the odometer in Megasquirt working. So I'll have an accurate mileage for my car starting in 2018.
Lol. The engagement is what's most different for me. The focus didn't engage the clutch until the pedal was almost returned to the rest position. My 242 engages pretty much right as you start to let the pedal back up. And it lets my neck know it's engaged.
Old 01-10-2018, 02:04 PM   #382
t8fanning
t8fanning's Avatar
I adjusted my torque rods to match my pinion angle to my new tailshaft angle, and got rid of some annoying vibration. However, my driveshaft now hits the body on bumps and when any real weight transfer happens. I'm thinking about converting to a 2 piece driveshaft. Has anyone had problems with two slip yokes?
Old 01-15-2018, 08:12 PM   #383
t8fanning
t8fanning's Avatar
Finally replaced the stock GM ignition coil wiring harness I was using with something I made. No functional reason to make one, but I wanted it to look better.
