Old 05-19-2018, 07:13 AM   #201
DET17
Reformed SAABaholic
Originally Posted by soclosenotnear View Post
I'm talking about the bsr heat shield. I just need to open up the hole for the amm to 3" and maybe relocate it slightly.
From memory, I laid out the 3" AMM hole opening on the original, moved just slightly F-R to get my K&N filter to clear my air box. Drilled new attachment holes 90* to the original hose in my air box (to resist the hose pull against it). Free handed with my dremel and cleaned the hole up with a tiny dremel drum sander. I think I put pics in my build thread?
So are running the 012 AMM without the air box right now?
Old 05-19-2018, 07:46 AM   #202
soclosenotnear
Originally Posted by InTheWhite View Post
I solved the angle of the filter with a angel reducer from do88 for the stock amm to a 3" ITG filter.
Did you use the angle reducer just to fit your filter? Or, did you use it to create some sort of swirl before the air passes through the amm? I've read something along those lines is why the factory used an elbow.
Correct. I didn't want to go hacking up the heat shield before everything worked well together.
Old 05-19-2018, 04:57 PM   #203
+Kardboard+
Chinese guy/Swedish rides
+Kardboard+'s Avatar
Love the project thread, wish I'd seen it before!
I can't find a listing for that heat shield you have. Same BSR one as OP?
'88 245DL Uncle Sven|'95 945T Darth Haul|'82 242GLT B23E Lumpy the Angry Viking (sold)|'77 244DL, red/sold.|'90 744T C3P-LOL, gold/sold
mtd240: I suspect "the wives" have a super-secret forum to discuss whether or not they will let us buy Volvo parts.
DavidSamuels: Not a website, a panel discussion/reality show. Real Housewives of Gothenburg.
-Feedback-
+Kardboard+ is offline   Reply With Quote
Old 05-19-2018, 06:51 PM   #204
InTheWhite
InTheWhite's Avatar
I used it for both those reasons. You should never put the airfilter directly on the amm.
Old 05-19-2018, 07:02 PM   #205
+Kardboard+
What's the reason why?
Old 07-04-2018, 11:58 AM   #206
soclosenotnear
I've been driving my car a lot, I'm happy to report. I was able to open up the cutout in my air filter enclosure to accept my 3" 012 amm. Everything now fits together nicely.
I'm waiting on my m47 to give up the ghost, like everyone on this board toots. But it's holding its own at 20 psi from my 16t. I don't jam gears or drop the clutch. I do, however, get on the interstate in third gear wide open most days, and it's been handling it like a champ. It feels nice and strong.
Next on the agenda is still to button up my interior after relocating the battery to the trunk. I also still want to work out a bracket for the coil for the wasted spark system, as well as finish my exhaust in 3" through the tail pipe.
Old 07-04-2018, 12:23 PM   #207
Duder
His Dudeness, El Duderino
Duder's Avatar
My coil bracket project went to the far back burner - sorry about that...
I think you're on to something with the M47 assessment. For these old cars it seems lot of transmission life (after turning up the boost) depends on the driver. I'm not too hard on my 242 since it's mostly a DD, and my 300k mile M46 is holding up fine behind the B230FT swap. It might be making around 175hp at the flywheel. M46 still shifts cleanly and doesn't make much noise at all. As soon as I start cranking up the power I'm sure its remaining lifetime will be reduced, but until then, I'm having fun but not abusing the thing.
Old 07-05-2018, 06:55 AM   #208
DET17
Reformed SAABaholic
Missed this post; if you are referring to my Eurosport Tuning air box, it looks identical to the BSR which the OP has in his 9. I suspect Frank setup a buy with private branding for their business...... mine came from an AZ partout years back. Well made and engineered piece, whomever designed it did well.
Old 07-22-2018, 05:51 PM   #209
soclosenotnear
My younger brother came by to drop off this wasted spark coil bracket. It came out pretty nice so thanks to him for that.
We popped the hood and cleaned the majority of my under hood grounds for gp. Redid a couple entirely also. They were all in poor shape. I'm not sure if it helped any but it couldn't have hurt.
I'm gonna make a post on it soon but what is the company these days to get a 19t upgrade kit from? Is ard tuning still the go to? There are cheaper eBay options. Curious to hear experience on "upgraded" 19t's?
Old 08-01-2018, 08:38 PM   #210
soclosenotnear
Wasted spark bracket installed, again, courtesy of mbeas96. That finally puts me at about 99% completion on that project. It looks much more finished and in it's final resting place, just needs some sheath around the wiring and would be right at home for the most part.
Engine bay is filthy and my new telephone takes terrible pictures, which is ironic since I bought the phone for what was supposed to be a good camera.
Old 08-09-2018, 09:36 PM   #211
nitroboie
I believe the general consensus is ard, but is there really another option other than kinugawa? I don't think you could go wrong with either one as you're just needing the compressor wheel and housing. Make sure the wheel you get is 56mm exducer!
nitroboie is offline   Reply With Quote
Old 08-10-2018, 01:49 PM   #212
soclosenotnear
The ebay option is not Kinugawa. I'd have to look it back up to figure out who was selling that one on ebay. So maybe there are three available options, but everything I've read points to ARD being the ticket, so I think you're right.
Old 08-11-2018, 03:18 AM   #213
Acke
I've been running a kinugawa fwd 19t upgrade on a straight 7 hotside for two years now, and it works fine. The kits o-ring that seals the compressor housing was too thick/hard and I had to get an original mitsubishi one. Building a bracket for the actuator was not fun, in retrospect, I should have bought a rwd 19t/20t housing.
Old 08-11-2018, 12:39 PM   #214
soclosenotnear
Have you two (or others) been satisfied with your 19t turbos? I'm hoping that's a 'final' turbo for this car. I'm wanting decent power and good reliability. Did it leave you wanting more, I guess is what I'm asking?
Old 08-12-2018, 03:24 AM   #215
Acke
Can you ever bee satisfied when it comes to power? It provides decent power and fast spool, and beeing bolt-on is nice. I'd say its a really good choice for a daily. As long as I'm summer dailying my 9 I'm going to stick with the 19t. For a pure fun car I'd probably pick something bigger, from what I've heard the TD05 series is nice, too.
Old 08-19-2018, 11:52 AM   #216
soclosenotnear
Oil change this morning at 255,962 miles. It's been a bit less than 3k miles since my last one, I think, but it's been longer than a year so it was over due. Old oil looked fine, but I had burned a bit off and I have a minor leak somewhere turbo related. It's not a pressing issue.
I ordered some blank chips as a local friend recently got a burner. I'll be happy to experiment with different chipsets. The chips I have been running are old; I believe Fred's. Although they've been working ok with my injectors/amm combo, I think something new might be fun.
Old 08-19-2018, 01:15 PM   #217
Mbeas96
Mbeas96's Avatar
you didnt tell me this...but sweet!
do you think changing the EZK chip will be necessary? or just the fuel chip?
Old 08-19-2018, 02:29 PM   #218
soclosenotnear
Yeah, they came in a couple days ago. I'll get them to Sam sometime this coming week. And I doubt it's necessary, but I'll likely swap them out so they'll be a matched pair just for gp.
Also, I didn't use a Mann oil filter for the first time in my whole Volvo "career". Just didn't feel like ordering online when I didn't need anything else. Do you guys find these locally anywhere? Also, are there any thinner diameter filters for clearance purposes?
Old 08-22-2018, 10:24 PM   #219
nitroboie
I've seen the Manns locally here a few times at advance auto parts.
Old 08-25-2018, 05:01 PM   #220
soclosenotnear
I usually go to O'Reilly's or Park's but might check with advance next time. Thanks for the tip.
It's been a somewhat productive couple days with my car. I got new tires mounted and balanced for the front. Went with a 215/45 tire (256,030 for reference). I plan on picking up a pair of 235/45 for the rear when money allows.
Also, my wastegate actuator arm fell off the flapper. No boost to speak of. I'm not sure if my cotter pin broke or just fell off but it was missing in action. I put it back together and slipped another cotter pin on. I need to find a better quality cotter pin at some point.
Lastly, I got a decent pressure test done to actually check for boost leaks. I fixed 6-8 very minor leaks I found at various hose connection points. I also found three I still need to address: the egr vacuum line "T", the egr pipe that meets the intake manifold and my cbv. I'd like to get rid of egr and/or replace the gasket/t. I have never taken a cbv off though. Is there also just a gasket that needs replaced?
Old 08-26-2018, 07:28 AM   #221
Sjeng
Sjeng's Avatar
Stock ezk maps are not too bad if you want to run 1 bar boost or less on a stockish redblock.
For higher pressures (where these cars become fun) I would reduce timing in the highest load cells in order to be safe.
Low loads you can advance a bit for a little more torque and better response.
I am currently running a 18T 7cm on my 940. At 1.4 bar it is quite a bit quicker than my C70 T5. Response is good, wide torque curve. Imo it is a very nice, reliable turbo for these engines. Just like you I have a 250k mile engine and it takes it very well.
I have a HY35 10cm right here but am not (yet?) motivated to put it on, because it already is performing very well.
BTW I just buy aliexpress chips. Works like a charm, although they are only one time programmable. But very very cheap.
Old 08-28-2018, 10:42 PM   #222
nitroboie
There's no gasket for the cbv between the cover and compressor housing. Just remove the 3 bolts and it comes right off. Hopefully your cbv cover isn't bent. It can happen pretty easily if you have 1 bolt holding the cover on... Best to remove them evenly or hold pressure on the cover until you get the last bolt completely removed. Kinda hard to describe but you'll see once you get in there.
Old 09-30-2018, 05:13 PM   #223
soclosenotnear
Got around to changing the water pump gaskets. Hopefully my leak is gone. Note that it's great to have a second set of hands to lift up on the water pump as you tighten it against the block.
Fresh gaskets, but old (sub-10k miles hepu) water pump.
I'm starting to smell a little oil at high rpms/high boost. Probably should start looking at ccv stuffs for that. I imagine it only gets worse with bigger turbo and more boost. A couple other things are starting to need attention now that I've been driving this car every day for a few months now.
Old 10-21-2018, 12:11 PM   #224
Fast740fromSC
Fast740fromSC's Avatar
This is a sick build. I might have to take a road trip down to chuck town after I’m done my trans swap and check it out.
Fast740fromSC is offline   Reply With Quote
Old 11-04-2018, 12:02 PM   #225
soclosenotnear
Thanks man. Making these cars have three pedals is the best mood you can do.
So, I've been leaking oil and decided to try and track it down. I spent a couple hours pulling the timing components off followed by ripping the turbo off. Everything went smoothly. So far, I've confirmed a leak at the cam seal. I think I also have a leak at the front main seal cover, although not leaking through the main seal. I had a puddle dripping off the oil filter, which I believe is my main leak, but I haven't felt like getting under their to investigate that further. Here's where I'm at.
I'm going to take this opportunity to advance my cam gear a little more. I think the next increment is 5° advanced on the ipd gear, so I'm going to give that a try. Having it all apart presents a nice time to put a 19t together. So, hopefully I can scrounge a few dollars to make that happen.
Until next time...
