Go Back   Turbobricks Forums > Symposium > article composition
Old 07-27-2017, 09:36 AM   #351
thismachine13
Nothing to add specifically to your post but with regards to plugs, I'm going to use the Denso TT plugs. If I understand it correctly the ground electrode sees the "wear" on the exhaust stroke in wasted spark application.
Figure I will want longer wearing electrodes on both ends.
thismachine13 is offline   Reply With Quote
Old 07-27-2017, 07:58 PM   #352
Originally Posted by lookforjoe View Post
Curious about this - as I just put in WR7DP's about 80 miles ago & now have a 'breakup' that occurs during a steady throttle increase run - I was just trying to figure out what variables could cause the breakup, and forgot that I had put these in. I'll switch them back out for WR7DC's to rule out the plug, but I'm curious if anyone has specific notes plug types that induce erratic behavior?
When I said "Platinum plugs have a shortened center-to-outer electrode path such that the spark is always on the platinum", I really should have explained it as a sharpened center tip and (sometimes) a protruding disk on the outer electrode. And, I was only commenting on wasted spark requirements. There's a whole different set of concerns for high boost/racing, and I'm way out of my comfort zone here. The amount of bad internet info on this is huge. As a reasonable start, try:
http://www.hotrod.com/articles/spark-plug-guide/
Old 07-27-2017, 09:09 PM   #353
lookforjoe
lookforjoe's Avatar
Confirmed that WR7DP's DO NOT play nicely with the WS/EZK116 setup. Breakup is gone with the WR7DC+'s installed.
My XR July2013 - 446AWHP @ 8K rpm
Old 07-29-2017, 03:09 PM   #354
thismachine13
'89 245 N/A with Buchka board, LS2 coils, Yoshi daughter board with Turbtankshane chip for correct dwell. Got it all wired up and it will finally start but is missing. I've confirmed that my wiring coming out of the coils is correct.
When I turn the key to position II I can hear the pump prime and a couple of times the engine will jump as of a coil is firing before the car is started.
Any suggestions?
Old 07-29-2017, 05:36 PM   #355
thismachine13
Seems 1 & 4 are firing but 2 & 3.....not so much.
Old 08-10-2017, 02:31 AM   #356
thismachine13
Sent photos of my setup to Karl and Chris. I was using pins 24 and 25 on the EZK for the two outgoing logic wires. 24 seems to be ok but 25 is no bueno. After re-reading this thread it looks like pins 14 and 15 are safe so I've soldered outgoing on those pins. We'll see if that works tomorrow morning.
Old 08-10-2017, 11:15 AM   #357
thismachine13
All sorted and it runs great. Now to gut a relay and get the tach working.
Old 08-10-2017, 01:30 PM   #358
Duder
His Dudeness, El Duderino
Duder's Avatar
Great to hear you got it sorted out...I'm glad we could help!
Go out and enjoy it.
I still have to get my tach sorted out too - I'm procrastinating on that.
There's an original spark output wire from the EZK that "might" work to drive the tach even without a relay.
I'll report back if that works.
Old 08-10-2017, 09:04 PM   #359
nitroboie
Is anyone still making coil brackets like the BTI one?
Purchased a coil and powerstage last weekend, just waiting for the boards to return in stock.
'90 244
'94 945T ipd springs, sways, and brace, 11psi, TLAO chips
nitroboie is offline   Reply With Quote
Old 08-10-2017, 09:54 PM   #360
thismachine13
Yeah....let me know how that works out. I'm always looking to clean up the engine bay and if I could ditch even this little relay that would make me smile.
It always amazes me how I see things so abstract until I get my hands on things, then start piecing it together....suddenly.....it all makes sense and is simple.
Old 08-12-2017, 10:22 AM   #361
thismachine13
Is it possible that after installing the wasted spark that the fueling requirements could change? IOW additional fuel with a slightly larger injector?
Old 08-13-2017, 10:05 AM   #362
brian smith
Default kits to make ignition wires to length for the Bosch 2x2 coil are where?
It seems like there might be another option somewhere from the popular North American brands rather than using these?
Right now, I'm using 4 of the wires from the NGK kit for the V8 Land Rover in which that coil comes stock, and the lengths are a bit longer than ideal. At $20 for the 8-pack, I could source the shortest 2 wires from 2 kits, but it would be nice to see some large diameter wire options as well.
stuff:
one
two
brian smith is offline   Reply With Quote
Old 09-11-2017, 07:02 AM   #363
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
has any of you guys to experienced advantage in milage?
Old 09-11-2017, 07:15 AM   #364
thismachine13
I haven't seen any additional mileage gains, no.
Old 09-14-2017, 02:42 PM   #365
supreme940
For tach signal back, keep the wires on the coil or wire in a relay where it was.
88 740 Turbo Wagon - Parted / Crushed
89 740 16V - Parted / Crushed
92 240 Wagon - Sold
91 940 Turbo - Project
92 940 Turbo - Parts
91 940 GLE Wagon - Yard Ornament
GoldEZK (old) Feedback
Current Feedback
supreme940 is offline   Reply With Quote
Old 09-14-2017, 04:16 PM   #366
thismachine13
Yes.....currently using a gutted relay for my tach.
Old 09-15-2017, 09:56 AM   #367
Karlos_UK
Karlos_UK's Avatar
i thought the point of using the J702T unit was to use the tach driver onboard?
Karlos_UK is offline   Reply With Quote
Old 09-15-2017, 10:13 AM   #368
thismachine13
That is one of the perks of using that coil.....yes.
Old 09-15-2017, 11:10 AM   #369
Karlos_UK
Karlos_UK's Avatar
its the power unit, not the coil but anyway the above sketches are suggesting that the unit needs a relay?
Old 09-15-2017, 12:14 PM   #370
thismachine13
Igniter, my bad.
Old 09-16-2017, 12:54 PM   #371
nitroboie
Yes, however the earlier diagrams in this thread show the tach hooked to TAC.
Maybe people were having issues with it powering the tach and that's why the updated picture shows the relay method?
