Old 05-07-2018, 09:19 AM   #76
M.H. Yount
M.H. Yount's Avatar
Where on the car was that piece of wiring butcherdom Ralph?
Old 05-07-2018, 02:42 PM   #77
rporzio
rporzio's Avatar
harness to the main fuel pump under the car. This portion was hidden in the grommet. The test drive started out good but ended up with the pump making noise louder than when I started and pulsing a bit but no failure. 20 mile round trip.
Ralph
1984 242 DL (Phase 7 maintenance and upgrades underway)
http://242vision.clearascent.com
2007 S80 V8
rporzio is offline   Reply With Quote
Old 05-07-2018, 04:11 PM   #78
rporzio
rporzio's Avatar
can anyone offer advice on how to replace these fuel pump tray cushions?
Old 05-07-2018, 04:27 PM   #79
M.H. Yount
M.H. Yount's Avatar
It's like a grommet Ralph -- you just work your way around pushing the them through the hole, and the opposite going back in. Are new ones available? If I'd known -- threw mine in the trash after taking apart that tray to support my new filter/regulator....
Old 05-07-2018, 04:29 PM   #80
Uncleknucklez
bruspeed
Uncleknucklez's Avatar
Ugh, no fun, some lubricant and elbow grease, I cussed a bunch, had a beer, then cussed some more but eventually they go in.
1980 242 Turbo
2004 V70R
Old 05-07-2018, 04:32 PM   #81
rporzio
rporzio's Avatar
Ok, thanks to both of you, I'll get under there tomorrow. Yes Mike, new pieces are available, I got 3 off of Ebay...
Old 05-07-2018, 04:34 PM   #82
rporzio
rporzio's Avatar
BTW, Uncle, did you drop the tray or work with it in place?
Old 05-07-2018, 04:46 PM   #83
Uncleknucklez
bruspeed
Dropped the complete tray, only way to fly. I also cleaned it while it was out.
Old 05-07-2018, 05:02 PM   #84
rporzio
rporzio's Avatar
Darn it, that's what I was afraid of...
Old 05-07-2018, 06:30 PM   #85
M.H. Yount
M.H. Yount's Avatar
Might as well change the pump again while there Ralph. (Chuckle)
Old 05-07-2018, 06:35 PM   #86
rporzio
rporzio's Avatar
I was thinking the same thing. I have a brand new Bosch instead of the Napa device now in there, can't decide. The Napa guy is still warranted but the Bosch might solve my noise issues...
Old 05-07-2018, 07:27 PM   #87
M.H. Yount
M.H. Yount's Avatar
As we discussed - something is killing the pumps - you’ll find it.
Old 05-08-2018, 10:31 AM   #88
rporzio
rporzio's Avatar
Uncle, you were right, it was tough to get those rubber supports out. I did manage to get the whole tray down, cleaned it up a bit and got the 3 supports into the bottom of the tray (larger holes). Unfortunately, laying under the car I just wasn't able to snap the smaller ends into place, not enough correct leverage. For now they're just resting on the thickest part until I can get the car up on a lift and use some plastic pry tools to help them get into place.
Started the car up and while sitting inside noticed right away it was quieter so I'm keeping my hopes up when I take him for a test drive later today... Ralph
Old 05-08-2018, 02:11 PM   #89
rporzio
rporzio's Avatar
just back from the test drive. Silent for the first 1/2 hour then a hum started and got louder but not more than yesterday and no louder for the whole trip... Now I wonder if I'm just dealing with a noisy pump that gets louder when it warms not; it's not hot to the touch after the drive and is covered with a rubber sleeve.
Old 05-08-2018, 02:38 PM   #90
XxJenoxX
Skin Suit
XxJenoxX's Avatar
That wiring would be one hell of a red herring if it turned out to not be the problem.
AND THEN THERE WERE TWO (and a half)
2008 XC70 3.2: Stubborn sensor on wheels
1992 M47 240 Wagon: Why did anyone let me have anything this nice?
1990 240 DL: Parts car
1983 242 TIC +M46: Ticket to the 242 Crush Club
I have no idea what's going on, but I think I can fit more 8====D in my mouth than 240240
Originally Posted by Wilford Brimley View Post
Mmmmmm curvy girls and cock excess
XxJenoxX is offline   Reply With Quote
Old 05-10-2018, 12:32 PM   #91
rporzio
rporzio's Avatar
another test drive today, about 45 minutes long running errands with 2 or 3 shutoffs in between. Same as yesterday, completely quiet for the first 30-45 minutes and then the hum starts to creep in but gets no louder and a bit quieter than before. Tomorrow I'm going to run a few errands with a jaunt on the highway on the way home. At this point, with my limited mechanical ability, I'm thinking it's the main fuel pump itself just being noisy. I ordered connectors/pigtails for my Bosch pump from Dave Barton and want to give that a try sometime next week. Why else would the pump run quiet for so long and then consistently start to make noise, to me it's not a fuel supply or power or ground issue, do you agree?
Old 05-10-2018, 12:42 PM   #92
M.H. Yount
M.H. Yount's Avatar
My initial thought is that over time, something is making it harder to get fuel from tank to the suction side of the inline/under-car pump, and you’re hearing the inline struggle to overcome that impedimemt. Just guessing though. Sure the tank is vented properly?
Old 05-10-2018, 01:47 PM   #93
rporzio
rporzio's Avatar
Ok, I like how you're thinking (keep in mind that it has improved with the new wiring and new rubber cushions) and I'm not sure how to check if my tank is properly vented, help? R.
Old 05-10-2018, 01:50 PM   #94
M.H. Yount
M.H. Yount's Avatar
One thing to check -- when on those 30-45 minute drives and you start to hear the pump, stop car, leave it idling and open fuel door and unscrew the cap. See if you get a big inrush or outrush of air from the tank.
Old 05-10-2018, 01:55 PM   #95
rporzio
rporzio's Avatar
ok, will do tomorrow...
Old 05-10-2018, 02:01 PM   #96
How much current is the circuit pulling?
Old 05-10-2018, 02:06 PM   #97
oldschoolvolvo
oldschoolvolvo's Avatar
+1
If so, something to check is the “rollover valve” attached to the tank vent line coming off of the filler neck (at least that’s where it was on mine). Mine was stuck/inoperable and was not allowing the tank to vent properly. I was getting the “woosh” sound after driving and then opening the fuel cap.
-Mike
1998 V70 T5
|Feedback|
Old 05-10-2018, 02:09 PM   #98
rporzio
rporzio's Avatar
Don't know how much current but I have blown no fuses since this all started. So if the tank is vented properly I shouldn't hear anything when I pop the tank cover open?
Old 05-10-2018, 02:11 PM   #99
oldschoolvolvo
Correct. No “woosh” sound is normal.
Old 05-10-2018, 02:54 PM   #100
M.H. Yount
M.H. Yount's Avatar
Shouldn’t be any significant positive pressure or negative (vacuum) in the tank.
