Old 05-10-2018, 03:15 PM   #101
Originally Posted by rporzio View Post
Don't know how much current but I have blown no fuses since this all started. So if the tank is vented properly I shouldn't hear anything when I pop the tank cover open?
I recommend measuring current.
Old 05-10-2018, 04:09 PM   #102
rporzio
rporzio's Avatar
Now I want to know more about this Roll Over Valve. Part number 1255422? Haven't been out to the car yet but can't seem to find an exact location anywhere. Hmmmmm....
Ralph
1984 242 DL (Phase 7 maintenance and upgrades underway)
http://242vision.clearascent.com
2007 S80 V8
rporzio is offline   Reply With Quote
Old 05-10-2018, 04:19 PM   #103
Yep, that's it.
it's underneath the car above the rear axle on the bulkhead near the tank. Also check for a plugged or melted plastic hose that goes to the charcoal canister from the roll over valve.
Had I seen this thread earlier, I would have offered you this NOS fuel pump harness.
Old 05-10-2018, 04:59 PM   #104
rporzio
rporzio's Avatar
thanks for the offer on the harness but I'm all set now. I did get under the car and in the trunk and it appears that I do not have this valve. I can see and feel the very hard tube coming from somewhere in the front of the car, above the axle and above the lip of the gas tank and I think it goes directly into a metal tube that does a little loop and ends up in the tank filler tube. Possibly taken out in it's earlier life? At any rate tomorrow awhile and remove the cap while it's running to see if I hear anything, although I think Mike and I did this test some weeks ago with no noises heard but we'll see.
Old 05-10-2018, 05:05 PM   #105
lummert
lummert's Avatar
The main in-line pump can out pump the in-tank pump. I'm running an Aitex low pressure (maybe 12 psi), high volume in-tank pump meant for a Chevy S-10 with 4.3 liter Vortec V6 engine. This type pump should be the same in-tank pump used with throttle body injection.
Old 05-10-2018, 05:13 PM   #106
rporzio
rporzio's Avatar
thanks lummert, I bought an Airtex E8778 but have not put it in the car at this point, we disconnected the fuel line to the main pump and there seemed to be plenty of fuel being supplied so I abandoned that thought for the now.
Old 05-10-2018, 09:34 PM   #107
oldschoolvolvo
oldschoolvolvo's Avatar
I assume you physically looked at that vent line in the trunk the whole way back to the filler neck...reason being is that in my car the valve wasn’t visible but was tucked up where the metal line does the loop. Only when I pulled the line out to see if it was clogged did I realize it was there.
-Mike
1998 V70 T5
|Feedback|
Old 05-10-2018, 10:14 PM   #108
The valve in the trunk was only used until '79 IIRC.
Old 05-11-2018, 11:04 AM   #109
rporzio
rporzio's Avatar
Test drive today produced exactly the same results; fuel pump starts to hum after 1/2 hour or so but gets no louder and is very responsive to the throttle even when I floored it for a short time from 50-70mph. When I parked the first time I left it running and opened the gas tank but heard nothing and did the same thing when I got home just now. One note though, the first time was outside and as I was reaching in to turn off the key I come smell fuel faintly. Another note is that there has been no failures to this point either so I'm guessing I'm making progress?
Old 05-11-2018, 12:07 PM   #110
rporzio
rporzio's Avatar
I jacked up the car and found the roll over valve, pretty well gummed up so I'll get a new one but did find this on the hose that leaves the valve going to the tank filler tube. Pics show both ends, I replaced it and idled the car for a bit, still moaning somewhat but very responsive to the throttle. Could be why I was smelling fumes?
Old 05-11-2018, 12:26 PM   #111
rporzio
rporzio's Avatar
Do you all think the roll over valve is serviceable or should I just buy a new one? 48 shipped from volvopartswebstore.com Ralph
Old 05-11-2018, 12:37 PM   #112
oldschoolvolvo
Or delete it
As I understand it, the only purpose is to prevent fuel from leaking out of the vent line in the event of a vehicle rollover.
Old 05-11-2018, 12:41 PM   #113
rporzio
rporzio's Avatar
that's a good point. Replace it with a 3/16" female/female pass through?
Old 05-11-2018, 12:47 PM   #114
oldschoolvolvo
Not sure of the exact size, but if that fits the line it will be fine.
Old 05-11-2018, 02:10 PM   #115
rporzio
rporzio's Avatar
Dave Samuels of Wagonmeister is shipping me a new roll over valve so at least that will be taken care of.
Old 05-15-2018, 11:50 AM   #116
rporzio
rporzio's Avatar
First thing this morning I replaced the roll over valve as well as another rubber hose feeding the hard plastic line to the charcoal cannister. I didn't expect the fuel pump to be completely quiet during today's errand running but it was a little better. Still making noise after 1/2 hour or so but quieter this time. I'm holding off on installing the Bosch unit for now and trying to find the perfect moments to get him out for a longer drive...
Old 05-15-2018, 03:08 PM   #117
If you measure current before and after any repair, you may see changes. Like, instead of swapping the rollover valve, measure current then take off the fuel cap and recheck. Idk. Just ideas.
Old 05-15-2018, 03:25 PM   #118
rporzio
rporzio's Avatar
Thanks zvolv, I've been thinking about what you said about measuring current and trying to figure out the easiest way to do that. I suppose under the seat? Just break the connection there and insert my VOM set on DC Amp?
Old 05-15-2018, 03:30 PM   #119
Don't damage the pins for the fuse or other terminals front probing with a meter. We use terminal test tools that are the exact male terminal that corresponds to the female terminal.
I also have an amp clamp with a BNC connector to hook it to a scope. There are also clamps with a display built in.
Or use a meter, but a cheap meter may not be very accurate or even work at all. I had to cough up the $400 for a Fluke to do accurate parasitic battery drains.
If you do use a meter, yeah, maybe do it between the connector at each fuel pump. Backprobe if possible. Or find a way to avoid terminal damage. These old Volvos have overbuilt terminals, but if you front probe on a modern car it's very easy to damage the tiny terminals. If you have to, use a needle probe. They even come with 4mm banana terminals to connect to meter leads. Or go raid grandma's sewing kit and get some of those "T" needles and use alligator clips connected to them.
Here is a waveform of the main fuel pump on my 1990 240. This was about 2 years ago. It's not as pretty as I would like. With graphing the waveform you can see each of the 8 commutator current humps and also the average current draw. Since this pic, my 1990 240 knocks on accel and fuel pump is also getting loud. It may be dying. I am curious to see what the current waveform looks like now. It looks like I was around 2 amps in this pic. (Tough to see. I know. Sry.)
In your case, consider checking the fuse connections and crimps. Grounds and terminal connections and under car wiring too. Bad wiring can cause excess resistance and heat and cause components to fail. Such as blower motors pulling too much current, then causing the resistor to overheat and fail. A new resistor will fix it, but fail soon.
Old 05-15-2018, 03:41 PM   #120
rporzio
rporzio's Avatar
Interesting, never heard of probing in either direction. I was just going to insert the meter into the path of the 12v wire going to the main pump and set it to the highest Amperage setting and I think that's 20 on my meter... Unless of course I'm way off base...
Old 05-15-2018, 03:48 PM   #121
Front probing is a bad practice.
I edited the above post so recheck it for some ideas. Needle probes, sewing needles, terminal test tools, or make a test lead from old components is a good idea too.
Set it to amps and run it inline. I would probably go for the fuse since it's easy to access. This is a 240. Pull the fuse and attach an alligator clip onto each side of the fuse holder and measure. Crap, the fuse may only be for the rear pump. Maybe go under the rear seat and do your main fuel pump tests there.
Also, measure resistance of the ground circuit. Another advanced test is the voltage drop test. V
It's a very strong test for measuring a circuits ability to carry a load. Learn to do that too. It's how you find bad terminal crimps and wires that externally look ok and pass resistance tests.
Old 05-15-2018, 04:10 PM   #122
rporzio
rporzio's Avatar
ok, good advice, thanks. Ralph
Old 05-16-2018, 08:33 AM   #123
rporzio
rporzio's Avatar
3.10 Amps draw from the fuel pump on a cold start.
Old 05-18-2018, 11:26 AM   #124
rporzio
rporzio's Avatar
Starting to feel a little bit better about this challenge we've been going through. Took him for my 1/2 hour of errand running and the car ran great, no noise till after that 1/2 hour mark but even then he still ran fine even under hard acceleration. Got him home shut it off and connected the VOM inline to get a reading of draw. Restarted and the draw was 3.9 down to 2.9 on occasion and sort of went with the whine of the pump and did not draw more even when I pressed the accelerator. I still don't trust him so haven't taken it out any further and at this point and wondering if all I'm dealing with is a louder than a Bosch fuel pump. R.
Old 05-18-2018, 12:57 PM   #125
M.H. Yount
M.H. Yount's Avatar
Guys - can he put a single/in-tank pump on the 84 OEM Volvo F.I. system, do away with the inline pump?
