i intended to run M rods, but one failed the magnaflux test. E rods it is, for now. i've talked to a couple guys running them with a moderate bit of abuse... of course they're only running them for one season, then seem to rebuild after a couple months
this thing isn't my daily driver... i've got other cars/motorcycles... just a toy. if it breaks, it breaks.
i'm planning on staying with the 6 bolt, but long H beams and forged bits are in it's future.
i had a '74 8 bolt block/crank, but the bores are ovaled. got another... same thing. checked out a third... damnit, same thing. every 6 bolt i see looks good. seems that with proper rods/pistons, the 6 bolt is plenty good.
last year i ran the around town for a bit with a t3/t4e with a cosworth hot side.
it was a hoot, but not what i really wanted... wasn't intercooled, was just kinda tossed together.
off came the wee t3, in favor of the Holset... which is f'ing huge in comparison.
where the t3 fit easily under the intake... the Holset required a lot of clearancing with a BFH, lots of moving sheet around.
alternator on the driver's side:
<img src="https://lh3.googleusercontent.com/-dtKFrYVeBMw/TfY_7L5Ex_I/AAAAAAAABYQ/aw29Gi8zdyg/s800/IMAG0032.jpg"/>
some weld els, sch 40... the entry angle to the turbo looks much more severe in the photo than it is...
<img src="https://lh4.googleusercontent.com/-edPqK3t4a9Y/TfZCrABBWoI/AAAAAAAABYg/t3afs8Id0kE/s800/IMAG0028.jpg"/>
manifold isn't done... fitting the wastegate flange still, as well as proper brackets to help hold the turbo's mass up. damn thing is
heavy...
and yes, i'm still running the stock d-jet cold idle control deal. MS is setup for a stepper, but one thing at a time. the COPs are enough for my brain to figure out, for now
VR sensor was hanging out on the passenger side. turbo adapter/exhaust all in the way, so had to move it. as a note, the timing covers seem to be made from an alloy of aluminum and ass. weld like utter crap, i tell you:
<img src="https://lh3.googleusercontent.com/-xel442x6KwQ/TfY_7L2s7kI/AAAAAAAABYU/zRsZzJhKvXk/s800/IMAG0033.jpg"/>
turbo oil drain now in the timing cover...
<img src="https://lh5.googleusercontent.com/-SjxVnzvZbIs/TfZC8n3Yq8I/AAAAAAAABYo/VKB3tD6DVsM/s800/IMAG0030.jpg">
(the fitting that's there isn't the one being used... just had the right thread size/pitch)
