Old 12-01-2010, 04:50 PM   #176
JordanTBoehm
Is this the end of the help I will get for my conversion? :(
JordanTBoehm is offline   Reply With Quote
Old 12-01-2010, 09:02 PM   #177
black 940
black 940's Avatar
The reason for lengthening the amm wires is that the sensor and air box is on the passenger side on a turbo and the driver side on the N/A. Thus you have to extend the wires to reach the amm to the other side of the engine bay.
-05 V70R M66
-93 945 Turbo, stock 15 G. Running great with a '95 Turbo engine, Sold and I know it will be missed, favorite one so far!
-94 940 N/A, bilstein struts and shocks, stock other than that. 207,000 miles and rising quickly.
SOLD and missed already
-96 965, stock, Sold
-86 944 Turbo, Tem, fun, good weather car.
black 940 is offline   Reply With Quote
Old 12-01-2010, 09:54 PM   #178
Mueller
Mueller's Avatar
pretty much...you have your service manuals, not hard to see what is different between a turbo version of your car and an n/a version, you can also use ipd or fcp groton online retailers to double check part numbers to see if one part was turbo or n/a or both
start doing it, once you run into problems, ask for help....it is all there in your haynes or chiltons manual
Old 12-01-2010, 10:33 PM   #179
JordanTBoehm
Okay, I will post any trouble I run into
Old 12-02-2010, 12:04 AM   #180
stylngle2003
stylngle2003's Avatar
turbos run 3.0 bar fuel pressure. NA cars run 2.5bar. you want the 3bar if it is in good shape. 2 bolts and an oring is all that holds it in.
850 turbo injectors are not bad, will be good for the time being.
-Billy
1990 Mazda Miata (track toy)
Old 12-02-2010, 10:10 PM   #181
JordanTBoehm
I just bought a 1986 760 Turbo to use as my donor car instead. It is being flatbedded to my house as I speak. $200 for the whole car. If 850 injectors are okay, what is better? Oh and yeah I will put in the turbo cars fuel pump.
Old 12-02-2010, 10:23 PM   #182
Mueller
Mueller's Avatar
the 850 are newer, so less use one could argue with, that and possibly slightly newer or improved design (spray pattern)...would you notice the difference? doubt it and hard to know if it would show on the dyno....save your money, use the parts from the donor car
great deal and the way to go if you have the space
Old 12-02-2010, 11:33 PM   #183
JordanTBoehm
Yeah.... but where is the ballast resistor pack located and where do I wire it into on my car? If I end up using the 760's turbo injectors.
Old 12-02-2010, 11:47 PM   #184
stylngle2003
it is on the driver's inner fender. looks like 4 ceramic cigarrettes in a metal cage.
be careful with the wiring harness on the 86. anything pre 88 or so is liable to have a degraded wiring harness, which can cause you nightmares. but by now, most have been swapped over to replacement harnesses.
Old 12-03-2010, 12:21 AM   #185
Mueller
Mueller's Avatar
wire it just like on the donor vehicle, look at it, trace the wires and copy
Old 12-03-2010, 02:51 AM   #186
JordanTBoehm
Someone is parting out their 1994 850 in my district..... I might as well get those injectors
Old 12-03-2010, 02:57 AM   #187
JordanTBoehm
Oh! and just out of curiosity, what are all the little blue light bulbs that slide into different interior plastic parts. They never turn on, so what are they!?
Old 12-03-2010, 03:35 AM   #188
stylngle2003
they are burnt out. common problem. scour junkyards for handfuls of replacements per car. they unplug pretty easily.
Old 12-07-2010, 04:50 PM   #189
JordanTBoehm
I plugged one of my highbeams back in, and when on, it glows a very very very faint orange glow inside. Bad ground, resitance, relay? Anyone here ever seen this?
Old 12-07-2010, 05:47 PM   #190
Canuckvolvo
Drunk as ****
Canuckvolvo's Avatar
threadjack much?
/threadjack
Currently Volvo-less
Canuckvolvo is offline   Reply With Quote
Old 12-08-2010, 01:13 AM   #191
JordanTBoehm
yeah your right... but problem fixed anyway
Old 12-15-2010, 09:07 AM   #192
mikee91
I wanna make my 940 turbo but dont know exactly what all to get i know i want a intercooler, turbo mani and turbo itself. what all should i add to my list? first car first time doing this. I have guides and ive done lots of reading up I have the b230f.
do I need new injectors?
Doing the conversion I would just like to know what i need to swap out.
mikee91 is offline   Reply With Quote
Old 12-15-2010, 07:58 PM   #193
JordanTBoehm
You can use the injectors off of a Turbo 740, 760 or 940 Volvo. But you need to wire in a resistor pack to use these injectors. These injectors are low impedance; you're original 940 injectors are high impedance.
To avoid the hassle of wiring in stuff, you can find Volvo 850 Turbo injectors. These are high impedance and they are high flow.
So you either get 850 Turbo injectors or use 740, 760 or 940 Turbo injectors. I am not going to try and locate 850 injectors for my project because I have 760 turbo injectors already from my parts car.
Old 12-15-2010, 09:14 PM   #194
mikee91
Old 12-16-2010, 03:45 PM   #195
FL_B21f
Just a question, although its not recommended, can I just run a +t without an intercooler? I'm only lookin for a mild boost in performance and at the moment don't really have a garage to work in, and I was only wanting to run 5-7 lbs for now, I'm no scared of wiring stuff up, I just don't have the time or space to pipe in an intercooler right now
FL_B21f is offline   Reply With Quote
Old 12-16-2010, 09:40 PM   #196
JordanTBoehm
I am currently doing the whole +T thing...... and.... in my opinion the hardest part is getting the oil pan out of the engine. I have an entire shop with a car lift and it is still hard to get it out. The intercooler took me about 20 minutes to install and plumb in. It was also one of the easier steps in the +T conversion. If you're going to put an oil feed and return for your turbo, why would you not add an intercooler while your at it.
If you don't have the time or space to put an intercooler into your car, then I really doubt you can weld the return pipe or bolt up a turbo manifold and downpipe. +T-ing a Volvo is easy compared to turbo-ing other cars, but it is still extremely hard, even if you have the time and space.
Old 12-17-2010, 12:10 AM   #197
FL_B21f
Oh we'll crap, ill just stick na for now then
Old 02-03-2011, 05:44 AM   #198
BradC
With what is going on in the LH2.4 tuning thread, do you _really_ need the Turbo LH and EZK or can you simply upgrade the software in the N/A versions with something read from the Turbo computers? Would be a cheaper upgrade for those of us that live in places where volvo wreckers are harder to come by.
BradC is offline   Reply With Quote
Old 02-28-2011, 01:28 PM   #199
swedish-rocket
Is the oil cooler nessary and will the turbo exhaust manifold clear the oil filter without having the oil filter adaptor?
swedish-rocket is offline   Reply With Quote
Old 02-28-2011, 01:39 PM   #200
Jeh
Wants a V12
Jeh's Avatar
No its not actually nesc, but nice to have. It will clear.
That's why I love this place.
Truly an information warehouse.
Originally Posted by kyle242gt View Post
I post not for information, but for ignorant entertainment.
1994 Jaguar XJ6
Jeh is offline   Reply With Quote
