Old 04-28-2018, 12:15 AM   #1
Rusty_ratchet
Rusty_ratchet's Avatar
Default Door Latch Replacement | Must be Missing Something Obvious
1997 Volvo S90
I replaced the little arm on the front drivers side door latch, and am having trouble getting everything back together. I can get everything in place, but the little lever stays in.
I checked to make sure the replacement arm is the same size as the old one (it is):
The wire that goes through the hole is in the door as shown below:
From the driver seat the wire is situated as shown below:
When I pass the wire through the lever/arm, it is situated as shown below:
With everything together, the arm stays in:
This is in contrast to the way it was before (rear drivers side latch shown here):
I can still open the door, but need to push the latch lever towards the car, as shown in this video.
I would think that the wire needs to be adjusted, but the part I replaced is the same as what broke.
Rusty_ratchet is offline   Reply With Quote
Old 04-28-2018, 09:34 AM   #2
Rusty_ratchet
Fixed it.
The little lever can be mounted two ways. I assume this is so the latch can be used on the driver or passengers side of the car.
In any case, I had it mounted the "upside down".
