88745ti
- May 19, 2005
- St. Lucie County, FL
I need some help with a no-start condition on the wife's 91 240. I have spark at the coil, pump not turning on with ignition, fuses good. Jumper wired fuses 3&4 in tank pump turns on. So relay is bad right? White relay clipped onto the ecm under passenger side dash correct?
One thing that has me stumped however, is even when the fuses are jumpered the car still won't start. Is this because the other pump is not turning on or do I have other issues besides the relay? The in-tank pump was replaced about 6 months ago or so.
