mschultz373
- Mar 11, 2020
- dirty coast
My '85 240 distributor hall sensor (i think?) has been causing an intermittent problem where the engine will die, or fail to start while cranking normally. I just put a new engine wiring harness in today and the problem persists. My question is if I should replace the entire distributor or if replacing just the ignition pickup would be sufficient?
Here's a quick vid of the problem: https://www.youtube.com/watch?v=RsC8I2n3N1g
and the part from FCP: https://www.fcpeuro.com/products/volvo-distributor-ignition-pickup-240-244-245-1237031292
