Old 02-05-2018, 04:28 PM   #101
pat244ti
pat244ti's Avatar
Oh hey so this happened this weekend
Scrutineer really liked the cage.
Have not updated this - mostly been busy with work the past 3-4 months saving up money for rally season this year.
I quit my job at the Porsche shop I was at due to an ownership change.
The rally car has lived in my friends enclosed trailer the past few months.
Since moving on from the Porsche shop, 3 weeks ago I pushed the E36 project that belongs to my friend into the garage to complete it. Once its done, the rally car goes in the garage for paint and the rest of the work.
The e36 - 1994 325is. I sold him this car 9 years ago after buying it off my friends dad [he got it when we were in middle school, and it was always the car we would try and sneak out and joyride when that friend got his license], we had Evil Genius cage it 8 years ago, I stripped the rest of the car since as well as pulling and reinstalling the engine with all the work we have done to it.
The past 3 weeks I have spent planning the completion of the project for him - installing the suspension goodies, new brakes and the biggest project - a full rewire of the entire car. We hucked the old harness years ago. I found an engine harness at the junkyard from another 94 325is and started with that. I'm almost at the point where I can pull the harness out and can start adding protective sheathing to the looms.
What's done to the e36
M50....new gaskets and seals all around...VANOS delete, ARP head stud conversion, VAC racing timing chain (new guides too), VAC racing oil pump, VAC pan baffle, VAC oil filter housing with a large Setrab oil cooler and -10 Peterson inline oil filter, VAC underdrive pulleys, Racing Dynamics header, catless mid pipe, B&B rear exhaust, Euro 3.5'' MAF conversion, custom DME tune, ACS delete, solid engine mounts. Added a fuel pump on the drivers side to feed the passenger pump pickup to prevent starvation below 1/2 tank.
Getrag 5 speed...UUC aluminum flywheel, E34 M5 clutch, HD guibo, 3.91 LSD, fully reinforced rear subframe, Bimmerworld solid race shifter, solid trans mount, braided slave cylinder hose
E46 330i front brakes (325mm), E46 325i rear brakes (slightly bigger and vented discs), slotted discs all around, Porterfield R4 pads, custom brake duct setup, braided steel hoses all around
Adjustable 30mm front/25mm rear sway bars, Turner adjustable endlinks all around, H&R front coilovers, Ground Control camber plates, H&R rear race springs and Bilsteins in the back, adjustable rear lower control arms, upgraded rear shock mounts, front and rear shock tower bracing.
I think we are going to mostly be doing Lucky Dog Racing League with this car. Because of the modifications, it does not really fit an SCCA/NASA class that it can be legal or competitive in. I think it will kick ass.
- Patrick
83 244ti - road race
83 244ti - rally
73 1800es - resto
08 c30 T5 6spd - daily
97 dakota 5.2 4x4 single cab short bed - apocalypse mobile
pat244ti is offline   Reply With Quote
Old 02-06-2018, 10:38 AM   #102
tjanson
tjanson's Avatar
Nice move on the 5x114 bolt pattern. Enough material on the hubs and flanges just to add the new pattern? Running spacers I assume? Subaru M12 studs or Volvo 1/2"? or beefcake M14?
1978 242 GT; B230F LH 2.2, M47
1993 245 DL; LH2.4, M47
tjanson is offline   Reply With Quote
Old 02-06-2018, 01:25 PM   #103
pat244ti
pat244ti's Avatar
M12 studs.
No spacers actually - the Methods I found (evo fitment, stocked up and bought 10 from a guy who was selling them for like $120/pop) are ET 15 which is perfect. Had to have some 2mm hubrings made and that was it
Plenty of material between the two sets of holes I think.
Old 02-08-2018, 01:42 PM   #104
It really is a good step up. I can buy used Methods all day long for $50-100. We used to go through at least 1 OEM volvo wheel an event. We haven't gone through a wheel in 8 races since switching to the Method VT-Spec wheels.
We use the higher offset wheels and spacers currently, but we can run the 15mm offset wheels by just removing the spacers
Old 02-12-2018, 04:37 PM   #105
tjanson
tjanson's Avatar
So which cars are the +15mm offset meant for? From what i'm seeing Subarus are +50mm and Mitsubishis are 30-50mm. Is it just for being hella flush?
Old 02-12-2018, 10:18 PM   #106
https://www.methodracewheels.com/col...-rally-vt-spec
Old 02-12-2018, 10:58 PM   #107
tjanson
tjanson's Avatar
Yeah, I had seen that. The 501 wheel with +48 offset also says it's "ideal" for Subarus and Mitsubishi's and clears the same brakes...so I am wondering what the reasoning is behind the 15 offset. Just increase track width?
Old 02-13-2018, 01:47 AM   #108
I think is the "wide body STI" vs standard Impreza fitment.
Old 02-13-2018, 03:27 AM   #109
pat244ti
pat244ti's Avatar
The guy I bought them from that had a stack of 100 of them got them for an Evo he was putting together. He wanted 30 or something and had to buy 100 from Method to get a good deal.
I don't know if Karl [Buchka] is reading this, but he picked up the wheels for me from the guys house and has a funny story about it.
Old 02-13-2018, 01:50 PM   #110
Was his name Andrew by chance?
Old 02-13-2018, 04:36 PM   #111
pat244ti
pat244ti's Avatar
Bagio
