Fred, you wrote:
And you are running E85, right? With E85, up to 300% extra cranking enrichment may be needed for some engines depending on the temperature. 50-100% extra is pretty normal for a redblock though.
Was half a joke, joking in english is not so easy though (learning: do not translate german phrases 1:1 in english). I meant that you want to tell me, that 50-100% which is normal for a redblock is enough to start with E85 even when it is cold. There is no chance to get 300% more from the ECU, which is needed with E85 to get a noticable better result, right?
Back to the theme: I have 'improved' my fuel yesterday evening with a extra portion of 5 liter gas to see this morning what happens. The EZK is still 3 degrees advanced, this morning we had here in Bremen -3 degrees cel. - guess....... starts up like a young Lady
3 degrees EZK advance are possible by increasing the gas part. The mixture before was 90% E85 and 10% gas. At the time when i filled in the extra 5 liter gas, there was a rest of 50 Liter 90%/10% mixture in the tank. As result it should be now a ~80%/20% mixture.
Now i must find out, how much the gas part can be reduced without loosing the good new starting abilities
