Old 01-12-2018, 02:56 PM   #1
MightySteelcorePen
Question (Noob) First "major" job. Hard Wiring rear lights
Alright. I have been reading up on how to do a hard wire for my rear lights. My turn signals just stopped working, and only enough tail lights work for the car to be road legal. I want to fix up the tailgate lights. I have a 1990 240 DL. Any advice for me on how to do it? "Obvious" pitfall that come with experience? I have also never soldered anything before. Any beginner pitfalls to avoid on that?
MightySteelcorePen is offline   Reply With Quote
Old 01-12-2018, 03:26 PM   #2
KeizerBrickGuy
Sh*t pot stirrer
KeizerBrickGuy's Avatar
Best advice: Don't rush and don't be cheap with solder and flux(ie get the leaded rosin core stuff). Make sure you've got good wire for your grounding efforts.
-Stephen
#mclovethesenuts
Old 01-12-2018, 03:57 PM   #3
Rusty_ratchet
Rusty_ratchet's Avatar
In regard to soldering, I would add extra flux to each connection before soldering and clean off the residue when done. I would also get in bit of practice before doing anything on the car. If you need to use connectors for anything, then consider using Weather Pack, Metri-Pack, or Deutsch connectors. They are weatherproof and are less likely to get corroded compared to other types of connectors. WayTek Wire is a good source for automotive grade electrical supplies.
Rusty_ratchet is offline   Reply With Quote
Old 01-12-2018, 04:18 PM   #4
EivlEvo
Soldering is stupid and I hate it. You said tailgate? Do you have a wagon? If you have wagon, the hardwiring is different because the stuff that sucks is the wires going through the hinges. You can fix these with crimps or bullets or w/e. If you have non-wagon... hardwiring is correct. It's also still sort of finicky.
Old 01-12-2018, 06:18 PM   #5
nel621
If you are talking about a sedan you have 2 choices. Either solder them or use male female connectors on the bulb sockets. You will find that the male connector on the bulb sockets are not a standard size. What I did for a friend was to trim the tabs just enough so they would hold a female connector very tight, no solder needed. Worked for me. YMMV
Old 01-12-2018, 06:24 PM   #6
alschnertz
Enough already!
alschnertz's Avatar
Why?
Old 01-12-2018, 06:25 PM   #7
nel621
Also try and use the same color wire for the corresponding light in the circuit.
https://www.google.com/url?sa=t&rct=...VnUehvoNfeN8Qp
or a visual
https://www.google.com/url?sa=t&rct=...ItzWtglKdjqGLG
Old 01-12-2018, 08:24 PM   #8
EivlEvo
Originally Posted by alschnertz View Post
Why?
bc I always had bad equipment and thought I was bad at it.
Old 01-12-2018, 09:05 PM   #9
Mr. V
Mr. V's Avatar
Why hard wire?
The acetate electric grid thingamabob should still be available aftermarket.
Old 01-12-2018, 09:20 PM   #10
TestPoint
TestPoint's Avatar
The tail gate wiring breaks at the hinges from 30 years of flexing. IPD sells a replacement harness but it is not the fine wire of the OEM Volvo harness and will not survive another 30 years. There is slack in the harness both above and below the hinge. Pull the cable through one way or the other to move the damaged point out of the hinge area and solder and insulate the individual wires.
Owning and maintaining the car since new in '82 I have repaired the harness twice using slack in both directions so I no longer have that repair capability. Bought the IPD harness and plan on splicing a 2 foot section of the original fine wire from further down the harness into the aftermarket cable. That should give me another 30 years of working tail lights and wiper operation.
This is not all that difficult a repair.
Ford V8 Conversion Manual -
Old 01-12-2018, 11:26 PM   #11
Mr. V
Mr. V's Avatar
Hey OP: wagon or sedan?
Old 01-13-2018, 04:55 AM   #12
Otto Mattik
Otto Mattik's Avatar
or a visual
The 240 series are old enuf now that kids typically drive them (and few, if any "family folks/collectors"), consequentially many non-urban authorities aren't as forgiving regarding the silly Volvo taillight soap oprah
Originally posted by Jack
_________________________
