Old 12-30-2004, 01:02 AM   #1
n xntrx volvo
n xntrx volvo's Avatar
Default hardware/ threads faq
alot of the same q's come up, if you know any, let me know and i'll throw them in.
Head
Thermo Time Switch = 14mm x 1.5
ECU Temp Switch = M12 x 1.5
Exhaust Studs = 8mm x 1.25
intake nuts = 12mm head
Thermostat Housing = 10mm Head
Valve Cover = 10mm head
Timing Belt Tensioner = 17mm Head
Camshaft Gears 17mm Head
8v valves
Head diameters 1.732" intake/1.378" exhaust
overall lengths 4.350" intake /4.365" exhaust
7.955-7.970mm Stem diameter
Std four keeper groove
Valve seat angle 44.5 deg
seat width in cyl head, 1.3-1.9mm intake, 1.7-2.3mm exhaust
b230 fuel rail fitting = m14 head, m6 thread
Block
Oil Pressure Sender B230 = M14 x 1.5
Oil Drain = 3/4" 16tpi
Oil Filter = 29mm head 3/4" 16tpi thread
Turbo oil feed = 14X1.5mm
Crank Nose Bolt = M14 x 2mm pitch x 70mm l
Drain Cock = 18mm Head
Oil Pan = 12mm head
Oil Pump = 1/2 Head
Con Rods = 10mm Head, 12 point
Main Bearings = 19mm Head
freeze plugs (b230) = 40mm
dist block plug (b230) = 40mm
fuel pump block off m thread
aux shaft plug = 52mm
water pump = 10mm head x 6.0mm X 1.00mm.
motor mounts (on block) m thread
Turbo
TD04-13C oil feed = M12 x 1.5
Tranny
Bell housing Bolts = 3/4 head, 12mm x 1.75 thread
Radiator/ IC
Screw in temp sensor = M22x 1.5
Powerstroke ic = 3.25 in/out
Chassis
Lower Cherry Brace Bolts = 10mm x 1.5 pitch x 25mm l
Lug Nuts 240 = 1/2" x 20tpi
Lug Nut 700 + newer = 12mm x 1.5.
Springs
700 sedan (4 cyl), Front 6.5"d, .540" wire, 5 active coils. 118
lb/inch. Rear 4.75"d, .405" wire, 7 active coils. 70 lb/inch.
700 wagon (4 cyl), Front 6.5"d, .571" wire, 5 active coils. 147
lb/inch. Rear 4.75"d, .495" wire, 7 active coils. 156 lb/inch.
700 rear (irs) 5"d, 11/32" wire,
200 diesel, Front 6.5"d, .550" wire, 5 active coils. 127 lb/inch.
strut tubes, 53mm (2.086")
Other
Fuel Filter = 12mm/out 14mm/in
700 Dist Cap = 8mm head
AN Fittings FAQ
AN (Army-Navy)
The AN (Army-Navy) standard was established many years ago by the US
military to set a common measurement for hose and fittings. It designates
the outside diameter (O.D.) of the ridged metal tube that is compatible
with each size of fitting. Still today, this AN dash standard is the
benchmark measurement for military, industrial and the performance hose
applications. These dash sizes are expressed as the numerator of the
fraction, with the denominator always being 16. For example, a -04 port is
4/16 or 1/4-inch.
its all cut/ paste, so it may/ may not be correct.
-Aaron
my cars (click me)
I'm not here, Please leave a message after the tone........(or email me).
n xntrx volvo is offline   Reply With Quote
Old 01-10-2005, 06:44 PM   #2
n xntrx volvo
you guys dont know any of this? fine, i'll add as i run across.
Old 01-10-2005, 06:48 PM   #3
Morley
Barbie Ken
Morley's Avatar
we're not that stupid. We know SOMETHING.
Wheel nuts, 19mm head.
Morley is offline   Reply With Quote
Old 01-10-2005, 10:21 PM   #4
Three Fat Tigers
Three Fat Tigers's Avatar
Location: ↓ Lynchburg, VA →| '89 740Ti | '90 760Ti | '92 240 | '94 940T | '96 960 | '96 M1
I would include the stud size and pitch when describing nuts.
Water pump bolts, nuts and other 10mm head hardware are 6.0mm X 1.0
Three Fat Tigers is offline   Reply With Quote
Old 11-30-2005, 06:29 PM   #5
tjanson
tjanson's Avatar
Default Head bolt head size
What size socket is needed for the head bolts?
I'm doing my head gasket this weekend and wanted to make sure I have a 6pt 1/2 drive socket handy....
1978 242 GT; B230F LH 2.2, M47
1993 245 DL; LH2.4, M47
tjanson is offline   Reply With Quote
Old 11-30-2005, 06:46 PM   #6
MikeHardy
The Sirius/Nova Police
MikeHardy's Avatar
exhaust studs are M8 (older stuff is 1/2" head later stuff seems to be 13mm or has been replaced by that on most i see)
intake are the same
thermostat and cam cover are M6
gauge temp sensor is 5/8" unf (same throughout all models even 16V)
MikeHardy is offline   Reply With Quote
Old 12-12-2005, 04:23 PM   #7
240Psycho
still trying
240Psycho's Avatar
Default i know this is an old post but its a good one
what size is the oil passage thats at the front of the motor by the water pump.
important info for the +t people who like their stock sensor where it is.
..::VFBG::..
Kyle with a
'91 244 2.5L 16V turbo
00 S70 T5
81 242 T
79 242 GT
240Psycho is offline   Reply With Quote
Old 06-07-2006, 09:29 PM   #8
foggyjames
Ryan's spanner monkey
foggyjames's Avatar
Random bump...sticky icky icky?
cheers
James
'05 V70 D5
'88 360 Turbo Intercooler
'84 360 GLT
'81 343 GLS R-Sport
'80 343 DL
'69 164
PM me if you're looking for Euro parts!
foggyjames is offline   Reply With Quote
Old 06-07-2006, 09:44 PM   #9
mikep
The MP
mikep's Avatar
The timing belt uses sprockets, not gears.
I will butt chug a beer for all my sober homies on TB.
Originally Posted by centason View Post
Trap queen.
Old 06-07-2006, 09:48 PM   #10
Homer
OEMplus++
Homer's Avatar
Crank pulley bolt is 24mm. B2xx
Front brake caliper bolts: 19mm 240
-Jacob:
2006 A4 - Comfy DD
Old 06-07-2006, 10:04 PM   #11
765tiME
765tiME's Avatar
banjo bolts for fuel filter/turbo oil feed?
765tiME is offline   Reply With Quote
Old 06-07-2006, 10:51 PM   #12
kahluaTDI
kahluaTDI's Avatar
the bell housing bolts are 19mm heads, and the torque converter plate uses 14mm.
the headbolts are 14mm .. or were they 13.
the throttle position sensor is held on with 2 7mm allen headed bolts.
SEO Baby!
Home Inspections in SW Washington
kahluaTDI is offline   Reply With Quote
Old 06-07-2006, 11:19 PM   #13
burgandybrick
burgandybrick's Avatar
thanks guys this thread is very helpful!!
Originally Posted by phillazenby740t View Post
what the hell kinda car is that? Sounds like my lawnmower on bean burritos
burgandybrick is offline   Reply With Quote
Old 06-08-2006, 12:21 AM   #14
blarf
blarf's Avatar
The head bolts have 14mm heads (new style) or InHex 10mm(?) (old style). 700 series brakes use 10mm InHex bolts to fasten the calipers to the strut housing, and 5mm InHex to fasten the ABS sensor. I'm pretty sure the Bilstein HDs use a 7mm InHex fitting at the top. Crank pulleys are 22mm / 7/8"(?) (B19/B21/B23) or 24mm / 15/16" (B200/B230).
Manuals moved here: http://gaz.inferiorhumanorgans.com/greenbook/
blarf is offline   Reply With Quote
Old 06-15-2006, 07:12 PM   #15
Tabor
volvoholic
Tabor's Avatar
Head bolts M12x1.75
1983 Volvo 245T with too many mods to list
1975 Volvo 242DL PARTING OUT pm me for parts!
Tabor is offline   Reply With Quote
Old 06-15-2006, 07:27 PM   #16
745 TurboGreasel
745 TurboGreasel's Avatar
How about torque specs with this fancy list of bolts?
followed by 'Locktite, teflon, oiled, or dry'
Nice reference so far tough
Feedback
Old 06-15-2006, 08:01 PM   #17
blarf
blarf's Avatar
Nice reference so far though
https://gaz.inferiorhumanorgans.com/...TP30871_1/p009
https://gaz.inferiorhumanorgans.com/...TP31003_1/p003
https://gaz.inferiorhumanorgans.com/...TP30838_2/p007
https://gaz.inferiorhumanorgans.com/.../TP31201_1/p06
https://gaz.inferiorhumanorgans.com/...TP11584_1/p030
https://gaz.inferiorhumanorgans.com/...TP30000_1/p001
https://gaz.inferiorhumanorgans.com/...TP30001_1/p003
https://gaz.inferiorhumanorgans.com/...TP30001_1/p004
That should keep you busy for a bit.
Old 07-25-2006, 07:37 PM   #18
Lord Tentacle
Anime Lord
Lord Tentacle's Avatar
update for you to add in
td04HL-15G-7 with the conical outlet has an oil inlet port that is 12mm x1.5
(i just found this out the hard way )
turbo for reference is from a 95 T5-R
Tentacle SUV 12 xc90; stuff including v8 and towbar etc... Powered by Beetroot
recently crushed Volvo's
Old 08-14-2006, 04:36 PM   #19
steelels1
My alternator tensioner bolt snapped last week for whatever reason and replacement was an M6 x 1.0. I used a bolt 70mm in length, but you could probably give or take a little.
-1992 Black Volvo 940 Turbo
-1992 Mitsubishi 3000GT VR4
-1999 Medium Blue Metallic Pontiac Trans Am LS1 (SOLD)
steelels1 is offline   Reply With Quote
Old 08-15-2006, 01:07 PM   #20
n. rippe
n. rippe's Avatar
torque specs would really be kick *ss
1991 744 Turbo
2008 C70 T5
n. rippe is offline   Reply With Quote
Old 08-15-2006, 01:48 PM   #21
Can play the blues
Default There are a lot of changes
During the late 80s Volvo started trying to save some weight in the cars. One of the ways they did that is to reduce the head size on a number of fasteners in the suspension and on the engine. Bolts that were 17mm like the timing belt tensioner are reduced to 15mm. I think they did this around 1989 for the 240 series.
Shock bolts for the rear lower shock mount went from 19mm down to 17mm on the head and 18mm on the nut. The large suspension bolts like the rear trailing arm bushing are changed from 22mm down to 21mm. Just a couple of examples. There are many changed sizes that adds upto some weight loss for the car.
The best thing is to be sure you have a complete range of socket and wrench sizes and as you work on newer cars you'll need tools for torx fasteners for more and more fasteners on the car.
Old 12-15-2007, 12:20 PM   #22
thelostartof
unbalanced chemical
thelostartof's Avatar
bump for those that do not know about it
tho i do have a question ... for the fuel rail ... m6 thread ... what kind of fitting do i need to T into the stock line @ the rail on a 7/9 series?
thelostartof is online now   Reply With Quote
Old 12-15-2007, 03:03 PM   #23
Lord Tentacle
Anime Lord
there really isn't anything
its a volvo/euro proprietary fitting thats just not used on anything else
i've got a modified fuel line you can have if you want
its got the special compression fittings to connect to the stock lines, gives you a 1/8th npt femal connector. right now i have a 6ft section of parker fuel hose on it with a plug on the end to quiet the system
a far better option is to clip off the stock input line, braze the hole shut and then get a steel weld on barb fitting and have it welded to the ass end of the fuel rail
then run some 3/8th line to the fuel filter
Old 01-16-2008, 04:10 PM   #24
wolf_walker
How about the CSB bolts, for when you have to screw with it to get it to not knock around on takeoff.
One more Radar Lover gone..
82 VW Caddy AAZ, 400K
wolf_walker is offline   Reply With Quote
Old 01-26-2008, 01:15 PM   #25
Mike Allen
Da' Pipe Fitter.
Mike Allen's Avatar
Default 90 760 Turbo Wagon Spec Sheet
I am looking at a 90 760 Turbo Wagon as my next project. Can anyone point me towards a list of stock specs? (Wheelbase/track/overall length/weight and such)
Any special problem areas to look for??
Thanks
Mike Allen
San Antonio, TX
Former 914 Driver
Current BMW E30 Driver
Future 760 Turbo Wagon Driver
Founding Member;
Old Pfart's Racing Team
(Indoor Beer Consumption Division)
Mike Allen is offline   Reply With Quote
