Old 02-03-2008, 10:52 PM   #26
740tankDriver
Post-Hypnotic Sigma
740tankDriver's Avatar
Question
what's the thread callout for the bosch oxygen sensor?
(EDITED)---nevermind, M18 x 1.5.
740tankDriver is offline   Reply With Quote
Old 02-16-2008, 12:44 AM   #27
lummert
lummert's Avatar
Default Specifications 90 Volvo 760 GLE Turbo
Dimensions and weights 760 GLE Turbo
Length 188.4 in. (478.5cm)
Width 69.3 in. (176cm)
Height, wagon 56.7 in. (144cm)
Wheelbase 109 in. (277cm)
Track, front 57.8 in. (147cm)
Wagon, rear 57.5 in. (146cm)
Turning circle, between curbs 32.5 ft. (9.9m)
Cargo capacity wagons
With back seats up 39.3 cu. ft. (1.1m)
With back seats down 74.9 cu. ft. (2.1m)
Curb weight wagon 3263-3265 lbs (1480kg)
Gross vehicle wagon 4295 lbs (1950 kg)
Capacity weight wagon 1035 lbs (470 kg)
Permissible axle weight, front (Turbo) 2070 lbs (940 kg)
rear wagon 2335 lbs (1060 kg)
Max roof load 220 lbs (100 kg)
Max trailer weight 3300 lbs (1500 kg)
This is from 1990 Volvo 760 Owner's Manual
Hope this helps you.
Old 02-16-2008, 12:48 AM   #28
Mike Allen
Da' Pipe Fitter.
Mike Allen's Avatar
Thanks, great info....anyone got a spare owners manual for a 90 SW?
Mike Allen is offline   Reply With Quote
Old 02-16-2008, 04:15 PM   #29
lummert
lummert's Avatar
Default 90 Volvo 760 Specifications
I got my manual download from Volvo:
new.volvocars.com/ownersdocs/1990/1990_760/90760_00.htm
That is the first page.
Maybe you should look in :
www.volvocars.us/
I Tried the first one and no match was found.
You can find Volvo Owner's Information there.
Old 02-22-2008, 12:57 AM   #30
towerymt
the real Towery
towerymt's Avatar
Just measured a flywheel bolt from a B230F for someone.
~31mm long (25mm threaded section)
M10x1.5
Old 02-25-2008, 08:59 PM   #31
foggyjames
Ryan's spanner monkey
foggyjames's Avatar
...I take it that's for a dished flywheel? As we found out recently, they're different for a dual mass...and I believe also for a flat flywheel
cheers
James
'05 V70 D5
'88 360 Turbo Intercooler
'84 360 GLT
'81 343 GLS R-Sport
'80 343 DL
'69 164
PM me if you're looking for Euro parts!
foggyjames is offline   Reply With Quote
Old 05-02-2008, 07:06 PM   #32
Lord Tentacle
Anime Lord
Lord Tentacle's Avatar
whiteblock drain plug M18x1.5 x 20mm
Tentacle SUV 12 xc90; stuff including v8 and towbar etc... Powered by Beetroot
recently crushed Volvo's
Old 06-13-2008, 11:24 PM   #33
white240glt
I am looking at a 90 760 Turbo Wagon as my next project. Can anyone point me towards a list of stock specs? (Wheelbase/track/overall length/weight and such)
Any special problem areas to look for??
Thanks
Mike Allen
San Antonio, TX
Former 914 Driver
Current BMW E30 Driver
Future 760 Turbo Wagon Driver
Founding Member;
Old Pfart's Racing Team
(Indoor Beer Consumption Division)
whats up fellow san antonio dweller. ive picked up a white 240 glt as my project... but its really more of a light matinance required vehicle. its in suprisingly nice condition, albeit a few smaller than dime size rust spots. ive already begun sanding them down and am gonna do the paint job on my own. friend who owns a fish store has a garage thats converted into a paint area, complete with gravity-fed guns.
white240glt is offline   Reply With Quote
Old 06-19-2008, 04:38 AM   #34
Yeedogga
Yeedogga's Avatar
240 steering wheel nut- 27mm deep socket (hope not a repost)
1985 240GL- B230ET, IC, 3", LH2.2, M45, 120rwkw SOLD
1985 760 Turbo Wagon
Yeedogga is offline   Reply With Quote
Old 06-19-2008, 04:43 AM   #35
JW240
All idiot, no savant
JW240's Avatar
cheers
James
yeah, duall mass has bolts of like 50 mm long.
Always 12.9 quality!
240 | 1991 | 326 KKm | B230F+T | Cossie T3 60/63 | M90 | TrueTrack
Husaberg FE450 '12
Old 08-16-2008, 04:56 PM   #36
itb242
itb242's Avatar
Would someone confirm the head bolt size? I'm getting some thread chasing taps and I'm not at my garage space.
David
itb242 is offline   Reply With Quote
Old 08-16-2008, 05:25 PM   #37
JW240
JW240's Avatar
www.gewinde-normen.de is a nice site for all kinds of different thread sizes.
My addition:
EGT sensor B204FT/GT engines is M12x1 thread, like more OEM EGT setups have.
Normal T3 turbo's have M18x1.5 thread for the watercooling, the Volvo ones M16x1.5.
An 850 oil drain plug is M18x1.5, usable for plugging oxygen sensor holes (eg when you aren't using a wideband or whatever and need to plug the hole). Or use an old oxygen sensor as a drain plug on your 850!
Mitsubishi turbo's also use M12x1.5 for the coolant lines as well (same as oil feed). Same thread on the T3 of the B204FT. Block side is M14x1.5 iirc.
redblock oil drain thread is the same as tjhe oil filter thread.
Old 09-18-2008, 12:53 AM   #38
SlowRide
Cold War Crumple Zones
SlowRide's Avatar
Size and pitch of the bolts mounting the power steering pump 86 (mine is 89) and up?
- Justin
1980 242 DL
Feedback
SlowRide is offline   Reply With Quote
Old 10-19-2008, 02:55 PM   #39
surfbug
torque specs for rear end differential cover 1988 765 ti?
Originally Posted by amargill19 View Post
Yup, that's a mull. And it's a pretty high rater - Pure business up front, party out back. Excellent.
Originally Posted by WheyDey View Post
...its so nice to have a mullet expert on board, isnt it?
CURRENT RIDE->'88 765ti 10/08 222k. OLD RIDES->'89 765ti 207k 10/07 to 2/09, '87 765ti 9/06 to 10/07. FAM RIDE->'98 v70 awd xc 6/08-- 8/13 new addition! - '94 944ti 248k current DD. also...2002 e46 325ci conv 58k miles..for sale now! pm for info
surfbug is offline   Reply With Quote
Old 12-31-2008, 04:52 PM   #40
740tankDriver
Post-Hypnotic Sigma
what are the bellhousing bolt thread sizes for redblock(b230)?
nevermind...m12 x 1.75
Old 03-21-2009, 05:14 AM   #41
nickm
nickm's Avatar
flex disk/guibo nut and bolts whats size are these?
nickm is offline   Reply With Quote
Old 03-21-2009, 08:02 PM   #42
foggyjames
foggyjames's Avatar
Fairly big. M12 or M14. 19mm heads, IIRC.
cheers
James
Old 03-22-2009, 10:26 PM   #43
Texas240
Prius Owner
Texas240's Avatar
what size bolt head is the oil drain plug on oil pan?
93 245 LS Engine Swap Project
Old 03-22-2009, 11:16 PM   #44
NotSoFresh
Sick ****** T-Brick Prick
NotSoFresh's Avatar
this thread should be moderated to eliminate questions if they are already answered.
Old 03-22-2009, 11:48 PM   #45
v tech
this helped me out :D gonna get some exhuast manifold bolts crossreffrenced thanks again :D
v tech is offline   Reply With Quote
Old 03-23-2009, 07:15 PM   #46
foggyjames
foggyjames's Avatar
I believe the sump plug on a 2/7/900 with a B200/B230 has a 24mm head.
On a 360 with a B200 and the ally sump, you use a 3/8" drive rachet.
cheers
James
Old 03-23-2009, 08:16 PM   #47
Texas240
Prius Owner
Texas240's Avatar
cheers
James
that is one socket that i dont have in my tool box...TOOL SHOPPING TIME!!!!!
Old 03-23-2009, 09:29 PM   #48
NotSoFresh
NotSoFresh's Avatar
cheers
James
the strut nut is 24mm also.
Old 04-26-2009, 01:32 PM   #49
BDKR
Section 9
BDKR's Avatar
How about power stage info? Anyone care to add those part numbers?
For all you Dijkstra fanboys:
Old 05-12-2009, 01:31 PM   #50
nitroboie
Mine is actually 25mm or 1"
Correct, or 15/16". Crank bolt is the same size. I wish the drain plug was 24mm, that way I'd have more than two uses for that socket, but I always buy whichever socket is cheaper
nitroboie is offline   Reply With Quote
