Old 05-13-2009, 06:46 PM   #51
foggyjames
Ryan's spanner monkey
foggyjames's Avatar
Actually, I think you're right - it is 1". I have a feeling a 24mm fits (I could be talking nonsense...!), but a 1" socket is the intended tool.
cheers
James
'05 V70 D5
'88 360 Turbo Intercooler
'84 360 GLT
'81 343 GLS R-Sport
'80 343 DL
'69 164
PM me if you're looking for Euro parts!
foggyjames is offline   Reply With Quote
Old 05-13-2009, 11:45 PM   #52
Raz
I wake and bake every day
Raz's Avatar
if it's 1" it's 25.4mm, no a 24mm shouldn't work, 1.4mm variance, that's some loose sockets
Living for a living
Driving an 83 Mercedes Hymer Camper around europe for a year
Raz is offline   Reply With Quote
Old 05-14-2009, 06:02 PM   #53
foggyjames
foggyjames's Avatar
Probably nonsense on my part, then
cheers
James
Old 05-15-2009, 12:00 AM   #54
Raz
Raz's Avatar
it's all good
Old 06-21-2009, 07:26 PM   #55
blarf
blarf's Avatar
Oil filter adapter uses a 32mm head where it bolts into the block.
Manuals moved here: http://gaz.inferiorhumanorgans.com/greenbook/
blarf is offline   Reply With Quote
Old 06-23-2009, 11:11 AM   #56
Ursan
الله الفول السوداني شطائر
Ursan's Avatar
Anyone know offhand the size of the bolts to mount the CBV to the head & those that attach the lower turbo (90+) manifold support the the block?
how psi a stock can support?
I think this might be my chariot if I can jew the price down.
Old 07-04-2009, 01:25 AM   #57
greymatter
Thats the funniest image i've seen all week.
greymatter is offline   Reply With Quote
Old 08-01-2009, 02:47 PM   #58
volvogeek
http://forums.turbobricks.com/showth...cooler+threads
Thread mentions they're BSP (British Standard Pipe), measured the fittings on an oil cooler I have... Cooler itself looks to be 3/4 BSP, soft lines are 5/8 BSP. See http://www.pegasusautoracing.com/thr...ting-guide.asp for infoes... Pegasus also has BSP to NPT or AN adapters, so no need to hack and weld your oil cooler fittings.
volvogeek is offline   Reply With Quote
Old 08-13-2009, 01:10 AM   #59
smokeyfan1000
Guest
What sisze is OEM WT senderfor the IC "no numbers" WT gauge?? 3/8-18?? or metric?
Last edited by smokeyfan1000; 06-10-2010 at 09:59 PM.. Reason: incorrect size in original post
Old 09-17-2009, 12:04 PM   #60
Cameron
ドクターマリオ
Cameron's Avatar
Courtesy of mr. volvo --
240 fuel filter = 14mm x 1.5 inlet & 12mm x 1.5 outlet
Cameron is offline   Reply With Quote
Old 11-20-2009, 06:48 AM   #61
v tech
flex lines pitch and sizing? i know t accepts a bubble flare. but i got the tools at home too make my own stainless lines although not dot approved :(
v tech is offline   Reply With Quote
Old 12-14-2009, 12:02 AM   #62
HonestJhon
HonestJhon's Avatar
upper panhard rod mount bolt size and thread pitch and if it has a washer? lost mine driving to work.
HonestJhon is offline   Reply With Quote
Old 12-14-2009, 12:05 AM   #63
HonestJhon
HonestJhon's Avatar
also how long is above mentioned bolt
Old 12-17-2009, 10:16 PM   #64
aharvey4
aharvey4's Avatar
great thread, but adding lengths and shoulders would be pretty geektastic...
aharvey4 is offline   Reply With Quote
Old 03-09-2010, 10:11 PM   #65
nathaninwa
The Beloved Oarnge Juice
nathaninwa's Avatar
How about the thead and pitch along with seat on the stock front brake lines at the calipers on a 940? Already have ipd ss lines and need to get to 1/8 pipe thread.
962j 815/692@27psi
THIS IS FORSALE V
Old 03-17-2010, 10:14 PM   #66
cleanflametrap
cleanflametrap's Avatar
Old 04-28-2010, 06:47 PM   #67
PRBob
PRBob's Avatar
Anyone know the size/thread pitch of the petcock on B230s? I'm trying to find a bushing kit to install a stock temperature sender for a new VDO gauge.
Thanks
PRBob is offline   Reply With Quote
Old 04-28-2010, 07:13 PM   #68
foggyjames
foggyjames's Avatar
I'm struggling here. The coolant drain cock under/behind the exhaust manifold?
cheers
James
Old 04-28-2010, 07:43 PM   #69
PRBob
PRBob's Avatar
Yes, that one! It says 18 mm head on this thread (is that equivalent to M12 in all cases)
Old 04-29-2010, 02:13 PM   #70
foggyjames
foggyjames's Avatar
I don't know the answer I'm afraid...I thought it might help someone else assist. My gut feeling (from a rather dim memory) is that it looks more like an M14, but certainly don't count on that! I have a block on the floor I guess I could take a look at, but it's then going to be a case of working out what the hell the bolt I've got to engage with it actually is (particularly in terms of pitch..."weird" things like that may well not be the default pitch), as I don't have a set of thread gauges!
cheers
James
Old 04-29-2010, 03:08 PM   #71
smokeyfan1000
Guest
The block drain thread is a Pipe thread if I'm not mistaken.
Old 05-05-2010, 11:09 PM   #72
dbarton
Bored Member
dbarton's Avatar
Default RWD Ring Gear to Diff Bolts
Anyone recall the thread size for the RWD ring gear to differential bolts? I recall them being 10mm or larger.
Dave B
'84 242ti, owned since 2003. Always garaged since brand new. Old-school round headlights because they look great. B21FT, EMS: SDS EFI and IGN, TD04HL-15G, T5Z trans, Cooling Mist water/ethanol injection.
April 2018: Volvo seeks Divorce from the Volvo Enthusiast Community: www.prancingmoose.com/#novolvo
Old 05-11-2010, 07:23 PM   #73
smokeyfan1000
Guest
I just ordered some metric adapter bushings. I'll hopefully know tomorrow, if one of the bushings fit the hloe & threads.
Old 05-25-2010, 07:44 PM   #74
volvogeek
A little research tonight gave up that the '86-92 RX7 oil coolers have 18x1.5mm thread. And also that anplumbing.com has 10an to 18mm adapters for ~$11.
edit: installed said adapters into my cooler today, fits like a glove. http://www.flickr.com/photos/rlangis/4667715174/
Old 06-09-2010, 05:19 PM   #75
smokeyfan1000
Guest
If you're gonna use a 1/8-27 VDO sender, you'll ned to remove the whole deal. I used a NPT adapter in mine, but not sure what size it was.
